Question about Nikon Speedlight SB-600 TTL Flash
Flash head tilting/rotating lockrelease button coming apart
The rubber flap over the flash head tilting/rotating lockrelease button on my Speedlight SB-600 is seperating from the unit. It appears that the glue holding it on is loosing it's grip. Rather than shipping it off for repair I want to glue it back into place. I am looking for a recommendation for the type of glue I should use. The existing glue looks like it might be rubber cement.
  • 62 Answers
Use a good contact cement but don't use super glue .
Posted on Nov 28, 2008
Where can I find a replacement flash head tilting/rotating lock-release button?
Hi Kaye, I reckon the only place you'll get one is from a Nikon Service Centre, or a discarded/broken SB600 from a camera shop.
Aug 16, 2013 | Nikon Speedlight SB-600 TTL Flash
The flash shooting distance range does not appear at horizontal position.
Please open flash cabinet again and check any Jack/ connector can be lose. Becareful while open tha flash because it has high voltage inside.
Aug 01, 2008 | Nikon Speedlight SB-800 TTL Flash
I have a Nikon D40x with a Nikon Speedlight SB-800. The speedlight is not working. I have the camera on, new batteries in the speedlight and speedlight on. Not powering up. Is there some secret battery...
With new batteries in the flash, and it being off camera what happens when you press the test button. If still it does not flash call Nikon 1-800-645-6689
Aug 14, 2010 | Nikon Speedlight SB-800 TTL Flash
Nikon SB-800 flash won't rotate any more
Your flash needs to be opened.There is a small pin which must have got stuck. In SB 800 we need to open both upper and lower portions of the flash. If you are good at opening gadgets, just try with proper tools. Careful not to touch the main Condenser terminals. If you are in India, I can help you out. 09341932677
Jun 19, 2009 | Nikon Speedlight SB-800 TTL Flash
Too many flashes and than nothing
just turn off red eye reduction (it fires 3 preflashes) and it will only fire once
Feb 26, 2009 | Nikon Speedlight SB-600 TTL Flash
580 ex speedlite
Turn on flash while pressing some of those buttons with good batteries
Try switching from Meter to Standard Mode and move head around.
Try move the flash head(flash tube) in Manual mode.
It's in electronic locked up because you're moving that flash tube zoom too much. 98% of photographers use that mode:-(
Alexander
atdlee@netzero.com
Dec 07, 2007 | Nikon Speedlight SB-800 TTL Flash
I had the same problem. You locked your flash by mistake if you have a lock symbol on your LCD. Press the ON/OFF & Sel buttons simultaneously & the lock symbol will disappear. Then reset your unit by pressing Mode & ON/OFF simultaneously for 3 second & you are good to go!
Nov 16, 2007 | Nikon Speedlight SB-800 TTL Flash
Built-In Speedlight (Flash) will not retract
I haven't heard of this problem but compliments of velocityreviews I came up with this. Follow the instructions below to attach an external Speedlight. Refer to your Speedlight manual for detailed instructions regarding Speedlight operation. 1 Make sure that both the camera and the external Speedlight are turned off. 2 Attach the Speedlight to the camera accessory shoe. 3 Turn both the camera and the Speedlight on. 4 Set the external Speedlight zoom head to an angle wider than 28 mm. If you are using a Speedlight with Auto Power Zoom, set the zoom head angle manually. The COOLPIX5700 does not support power zoom. 5 Set the external Speedlight flash mode to TTL. At this setting, the amount of light produced by the external Speedlight is measured by the camera?s photocell, and the flash shooting range adjusted automatically to ensure optimal exposure. D-TTL flash control (available with the SB-80DX, SB-50DX and SB-28DX) is not supported. 6 Take the picture If the Speedlight Options: Speedlight Control option in the SET-UP menu is set to Auto, only the external Speedlight will fire. If this option is set to Int & Ext Active then the external Speedlight and the builtin Speedlight will fire at the same time. The COOLPIX5700 does not support AF-assist illumination, or red-eye reduction using the red-eye reduction lamp on the external Speedlight. At a setting of STBY (standby), the Speedlight will turn on automatically whenever the camera turns on but will not turn off automatically when the camera turns off. Exact functionality varies with the Speedlight in use. Refer to your Speedlight manual for details. I hope it's of some help BMW
Jul 07, 2006 | Nikon Coolpix 5700 Digital Camera
Nikon Speedlight SB-600 TTL Flash Logo
289 people viewed this question
Top Nikon Cameras Experts
Steve
Are you a Nikon Camera Expert? Answer questions, earn points and help others
