Question about Crosley CDG6000 Gas Dryer
Soot in dryer
I have a Crosley natural gas dryer that suddenly has a film of soot all over the inside. The clothes that come out of it are gray. I have checked the vent, both from the dryer to the outside vent and looked inside,they do not appear to be clogged. Lint in the lint trap is saturated with black soot. Help!!!
  • 2 more comments
  • Anonymous Dec 29, 2007
    i have soo on the beck vent inside the dryer checked all over even had a repair man check says he doesnt know what the problem is has my wife using soft scrub to clean aff ever time she uses the dry
  • lilac2155 Oct 24, 2008
    i have the same problem and am about ready to just buy a new machine- mine is a kenmore and sears came out twice and no one seemed to know what was wrong-- wondering how your issue was resolved.
    would prefer to get this fixed and not have to spend the money on a new one,- my dryer is barely 7 years old!
  • tavvi Feb 28, 2009
    We have a crosley gas dryer and my clothes are turning gray the inside of the dryer door is black and it does rub off a little on my skin
  • Anonymous Mar 04, 2009
    Same thing with my Admiral Dryer. It is so frustrating. Some of our clothes are ruined. Has anyone had this problem fixed?
  • 164 Answers
Sounds like you migt have had a flash fire in the vent line. you need to open the dryer and clean out the vent line
Posted on Aug 20, 2007
SOURCE:
Black soot causing whites to be gray
I too have the same problem with my Admiral dryer. Have come to the conclusion that the soot is making all my clothes greyer, but just noticed it with my whites. Took apart my dryer today and first of all found that the outlet below the lint vent was plugged. There is no soot on the outside of the drum or the dryer housing...however there is soot within the metal tube that surrounds the gas burner. Seems the gas is not being burned properly or the plugged lint trap was not letting the burned gases escape??? Laura
Jul 17, 2010 | Maytag PYG2300A Gas Dryer
I converted my dryer from natural gas to propane and there are no leaks but it's producing soot and melting my drier filter HELP! WHAT DID i DO WRONG?
did you do it your self or did you have it done by a gas tech i suggest if you did it you not use it until you have it checked out and corrected b4 you have a fire or worse
Dec 22, 2009 | Crosley CDG6000 Gas Dryer
Clothes are getting soot during drying cycle, is there a leak somewhere? Amana gas dryer, model LG8459
soot?
i would have to ask if you using naturasl gas or lp from a bottle
soot is usually from the heater if your set up for the wrong gas you dont get a clean burn and soot is deposited in the dryer
Oct 07, 2009 | Amana ALG331RAW Gas Dryer
Gas dryer leaves black grease spots on clothes
the soot is coming from the flame at the gas heater box the drier needs to be converted to propane the flame is too large without the conversion kit installed and thus creates soot at the vent. contact a local repair place for this one it can be tricky.
Sep 12, 2009 | Whirlpool LGR5636L Gas Dryer
Black carbon/soot on the door and lint filter of my dryer
Soot would mean lint is circulating around in your machine, and getting to the combustion area. Take the machine all apart and clean it thoroughly, including taking the cover off the fan and cleaning it too. A dirty fan will slow down the whole works. Check with your hardware store for a chimney-sweep's brush. I once bought one that could be tied to ropes and pulled up and down a flue. If they have a brush the right size, you could do that and really clean your dryer vent.
May 12, 2009 | Crosley CDG6000 Gas Dryer
Black soot/film in dryer
Is this a gas dryer. If so, check the burners. It could not be combusting properly. The valves may be dirty. Get them cleaned by a professional or someone who is familiar with cleaning gas orifices.
Jan 03, 2009 | Maytag PYE2300AY Electric Dryer
Soot from gas dryer!
have you recently changed from natural gas to liquid propane, or visversa? if so, this could be the problem. especially natural gas to lp.
Oct 28, 2008 | Kenmore 98702 Stacked Washer/Dryer
Maytag dryer PYG4557AWW
sounds you have a gas issue for sure, did you recently change from nat gas to bottle gas??? is this a new purchase??? sounds as if your burning a natural gas setup on lp gas call back the installer if thats the case
Mar 13, 2008 | Maytag PYG4500A Gas Dryer
Black soot in dryer
There are several possible causes: a)  exhaust vent is restricted forcing the lint to enter the dryer shell and overheat and/or be picked up by the blower -- you seem to have inspected this b)  check the hot gas inlet to the drum.. on some dryers, lint buildup can occur in tight spots and it will overheat and char c)  ducting is not intact or leaks allowing lint to leak into the dryer shell -- this will occur over time, and all dryers should be taken apart and cleaned out on a regular basis... also, all ducting should be inspected and sealed as needed d)  verify that the inlet vents to the dryer shell are not blocked and allow adequate air flow to the burner assembly -- natural gas normally won't smoke due to incomplete combustion, but..  likewise, verify the room has adequate ventilation particularly if the utility room or closet is very small,  e)  check the drum drive belt, as it gets old, it will release dust and minute pieces which will be picked up by the blower -- replace if needed... f)  verify that the seals on the drum are still good -- replace as needed g)  as 'washer-tech' advised, do a thorough cleaning and inspection... put it back together with all ducting tight and free flowing
Jun 28, 2007 | Whirlpool GGW9200L Gas Dryer
Soot in gas dryer
it sounds as though your dryer may need to be converted for the use of lp gas.or you might have a burner problem.
May 28, 2007 | Whirlpool GGW9200L Gas Dryer
Crosley CDG6000 Gas Dryer Logo
374 people viewed this question
Top Crosley Dryers Experts
Archie Ferrarini
Archie Ferrarini
Craig Butler
Craig Butler
jimorris77
Are you a Crosley Dryer Expert? Answer questions, earn points and help others
