LOOKING FOR WIRING DIAGRAM WHITE/RODGERS 1F95-1277 TO AMANA RHF HEATPUMP/A/C AND GOODMAN GMV9570 FURNACE
5 Suggested Answers
22yooper
  • 828 Answers
SOURCE: we need a wiring diagram
http://www.amana-hac.com/ This site has a means of contacting them to get information under products, and heating.
Posted on Jun 08, 2008
wbwill
  • 68 Answers
SOURCE: how to set dip switches
Yes, it could very well be the lack of air flow, how to set the dip switches, need more info on the setup or diagram or instructions, write me at wbwill@sbcglobal.net, I will try to help you
Posted on Sep 16, 2008
  • 121 Answers
SOURCE: Wiring diagam for goodman heatpump
On your t-stat you have Y, W1, W2, R, O, G, B or C or X. Y is your cooling circuit and will be the same in the air handler and heat pump unit, use the yellow wire for this circuit. W1 and W2 are your back up elec. or gas heat. Depending on how many kws or heat strips you have and t-stat wires you will put the white wire to W1 in both the t-stat and air handler. W2 is for your second stage back up heat if air handler calls for it, this will be a tan or brown or black t-stat wire and goes to W2 on t-stat and air handler. R is half of your 24v control power from the transformer and is the red wire and goes to the t-stat, air handler, and heat pump. O is for the reversing valve in the heat pump that switches it from heating and cooling. You guessed it the orange wire connect to t-stat and heat pump. G is for the blower and is the green wire to the t-stat and air handler. B or C or X is known as the common which is the other half of control circuit from 24v transform it is the blue wire and goes to the t-stat, air handler, and heat pump.
Posted on Oct 09, 2008
  • 51 Answers
SOURCE: wiring diagram for Rheem rpka-31 jaz heatpump
TURN THE POWER OFF TO THE UNIT. TAKE THE BACK PANEL OF OF THE HEAT PUMP AND LOOK FOR A SQUARE PLASTIC BAG FASTENED TO THE INSIDE OF THE UNIT, IT MAY BE LOCATED BY THE CONTACTS AND SYSTEM WIRING OR ON THE PANEL ITSELF. REMOVE THE PAPER FROM THE PLASTIC AND THIS SHOULD CONTAIN YOUR WIRING DIAGRAM. ALSO LOOK ON THE BACK OF THE PANEL ITSELF FOR THE DIAGRAM. SOMETIMES THE DIGRAM IS PRINTED THERE.
Posted on Apr 13, 2010
How to test White-Rodgers thermostat 1f56w-499?
I cannot remember which three or maybe two. but you can cross these wires to see if the unit kicks in. If it does then your thermostat is bad and needs to be replaced. Someone else may know or remember which ones to cross to do this.
Feb 21, 2015 | Heating & Cooling
Wiring diagram white rodgers 1F82-51
Hi. This is Aaron Moratalla from White Rodgers. If you are looking for the wiring diagram of 1F82-51 see it in page 3 of the manual using link below:
http://www.emersonclimate.com/Documents/White-Rodgers/instruction_sheets/0037-5650rev_A.pdf
If you need more help please don't hesitate to call our Tech Support line at 800-284-2925. Thank you for choosing White Rodgers!
Jan 24, 2013 | White Rodgers White-Rodgers 1F85RF-275...
I need wiring diagram for thermostat white rodgers
Hi. This is Aaron Moratalla from White Rodgers. See this link for the copy of manual. http://www.emersonclimate.com/Documents/White-Rodgers/instruction_sheets/0037-6841.pdf
Wiring connections are on page 7. If you need more help don't hesitate to call Tech Support at 800-284-2925. Thank you for choosing White Rodgers.
Jan 17, 2013 | White Rodgers White-Rodgers 1F85RF-275...
LOOKING FOR SCKEMATIC WIRING DIAGRAM FOR GOODMAN GAS PACK #PCB120245-3
type in your browser Goodman GPG152407041 15 SEER / wiring diagram
Jan 18, 2011 | Goodman GPG152407041 15 SEER Packaged...
Thermostat wiring diagram for ARUF3642
There should be a wiring diagram inside one of the covers on your air handler. Here is a link to a site that I believe is for your model:
http://www.shop.thefurnaceoutlet.com/media/ARUFInstall.pdf
Jul 25, 2010 | Goodman Furnace Draft Inducer Blower ...
How does a 95% goodman gas furnace wire up with all fuel board & goodman heatpump 13.0 seer low voltage wiring
A picture is worth a thousand words. Check out this link for the best explanation.
http://www.alpinehomeair.com/related/diagrams_10.pdf
Sep 26, 2009 | Goodman GMS90703BXA Heater
Can you bypass piggyback system if you want to just use heatpump. John
I'm assuuming you are talking about your furnace or 2nd. stage heat, when you say piggyback system. Yes you can go to your thermostat or furnace and disconnect just the 2nd. stage heat wire(see furnace wiring diagram), this will not allow the heat to come on in the furnace but it will still allow the indoor blower to run and the heat pump.
Apr 20, 2009 | Goodman CLQ36AR49 Air Conditioner
Changing home thermostat
Couldn't find your thermostat based off the information you provided; find the model number and follow the link to the Contractor Support Page.
White-Rodgers Multi-Stage Thermostate Diagrams for Contractors
Nov 28, 2008 | Heating & Cooling
Goodman GMP100-5 Rev Furnace Manual
I don't know where you are located, but there is a Goodman distributor in Sacramento, CA. Also in Ontario CA. They are a distributor so they may be able to help you or tell where to find someone who will help. Goodman is also known as GMC or Janitrol.
Jan 07, 2008 | Goodman GMS90703BXA Heater
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
