Question about Sony Grand WEGA KDF-42WE655 42" Rear Projection HDTV
45 magnum issue
The other day i spilled a cup of hot coffee down the back of my rear proj tv. it went blank and the children started crying, they were watching spongebob. so i grabbed my 45 and shot the tv to remedy the situation as i often do.to make a long story short what can i do to get a tv repair man to come over to my house and fix my tv. help me
    Problem Solver:
  • 5 Answers
No repairman will come near your house as long as you and the 45 are there... ;-)
Posted on Aug 05, 2007
Leaks water from bottom
Is it really from the BOTTOM, or is it spilling out the overflow holes in the back, then running down to the counter? If it's just spilling out the overflow holes, don't put quite so much water into it.
If it's really leaking from the bottom, and it happens even if you put only one or two cups of water into it, then the little hose running from the heating element inside up to the top filter has cracked or come off. You can fix that by opening the bottom of the coffeemaker (UNPLUGGED FROM THE WALL). You'll see where the rubber hose connects to the heating element and runs up along the rear tank. Check the connection where it attaches to the heating element.
Jul 31, 2014 | Gevalia CM-500 12 Cup Coffee Maker
Is it bad to use heated water inside of a Keurig coffee brewer..?
I had to take the cover of the K-cup cover, this is done by removing the 2 screws out under the cover while the handle is in the open position and then snapping it off. Pull the hose off the k- cup puncturer and clean it out from the top down this will clear out all the packed coffee ground in it. You may be able to clean it from the point up if you can find a very small pipe clean or something like that but I didn't have one so I pulled off the cover and went from the top down. I'd love to know how many people threw away these coffee makers because off this repair, I know my mom did before she talked to me. Good luck people.
Jul 17, 2012 | Keurig B30 Mini Coffee Maker
I love my Cuisinart 10 cup coffee maker, but I hate my pot. Every time I pour a cup of coffee the pot leaks. I have tried removing the lid and the pot still leaks. Please help I am getting tired of...
Be careful! The top will soon disconnect from the bottom! I've had the same problem for the last few months. This morning (11/19/10) the top of the pot seperated when I poured a cup of coffee and half a pot of piping hot coffee spilled down my right leg. I'm on hold with their customer service department as I type this. Has anybody else had the same issue?
Regards,
Harry B.
Nov 11, 2010 | Cuisinart Grind and Brew 10 Cup Coffee...
Coffee spilling out the sides of the carafe
I had a Mr Coffee that did that. It was running across the brew pause arm and making a mess. I discovered that the position of the carafe had a lot to do with it. If I brewed with the handle pointing out towards me, very little leaked out. I finally tore the brew pause arm off of the bottom of the brew basket. I works great and hey, I can wait ten minutes for a cup of coffee! However, if yours is new and doing this, I would contact the company and see if they'll make it good.
Jan 04, 2010 | Mr. Coffee 072179228578 12 Cup Coffee...
Sony rear proj; kdf 55
If there is no picture but sound is audible then replacing the projection lamp will do otherwise, the TV requires to be diagnosed for any other hardware damages.
Aug 27, 2009 | Sony Grand WEGA KDF-55WF655 36" Rear...
Coffeem maker not working
I a similar problem with my machine. I went 3-4 days without making coffee before i went to take it back. However, when i unplugged it, then plugged it back in, it worked. I didn't figure out why, but i've had to do this twice now. (Hasn't happened in a while.)
Good Luck
Sep 14, 2008 | Cuisinart Grind and Brew 10 Cup Coffee...
Temperature adjustment?
the rear temp sensor is in charge of the brew temp. To increase the temp, lift sensor and clean out the thermal paste. To further increase, insert some fine metal mesh between sensor and boiler. The front senser is for emergency (overheat) cut off. Don't tamper! Brought to you by Jim Vonkas
Mar 16, 2008 | Breville Die Cast 800ESXL Espresso Machine
Quisnart DCC-2000 12 cup (leakage)
If the DCC-2000m is filled past the 12-cup mark, there is a spill gauge at the back that will allow the coffeemaker to keep the cup count exactly at 12 cups.
Dec 11, 2007 | Cuisinart DCC-2000
RCA 52" Big Screen TV model;P52920BL Chassis;PTK195KB PICTURE BOWED AFTER FUSE BLOWN.
You have bad convergence IC's.. If your not experienced in troubleshooting electronics or soldering, you should have a trained tech take a gander at the set. Its not worth risking life and limb to save a few bucks, Good Luck
Jul 30, 2006 | RCA P52920BL 52" Rear Projection...
Sony Grand WEGA KDF-42WE655 42" Rear Projection HDTV Logo
101 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
