Xerox 3535 color alignment
I had the error 010-350 i changed the nvm settings to 0, so the problem was resolved but then after that megenta is not alligned properly. When i print something megenta is out of the image, more towards the left. Have tried auto gradation but i do not think it is for this purpose.
So please help
  • usmankjadoon Nov 20, 2008
    Is there anyway i can do the diagnostic, as the engineers are charging me alot. I did reset the NVM but i do not know what will happen if i initialize the nvm harddisk?? Please do comment
Thanks for the suggestion but this machine has not worked since i bought it, so it is just eating money and have not contributed towards anything.
I know the diagnostic tool in the machine setup but is there any other external diagnostic tool??? If there is any such tool where can i get it from?? I mean can i download it from any site???
Call out engineers are charging me alot.. so please suggest from where can i download the diagnostic tool or is there any manual that has all the settings in it as i looked in the user guide but there is nothing related to it.
Posted on Nov 22, 2008
  • 62 Answers
You need a friendly engineer to do a diagnostic regicon. It is pure guess work if you manage it any other way. It doesnt take long and relatively easy to do, you just need the diagnostic tool on a laptop
Posted on Nov 19, 2008
  • oooimstuck Nov 20, 2008
    not much that you will notice will happen, it just resets certain parameters. Try it and see, there must be a reason for the colour misregitration in the first place. You should only need to pay a call out fee as no parts are required and is reasonably quick to do. If you are in a graphics enviroment then all i can say is that it will have payed for itself relatively quickly.
    There's nothing i can tell you to do if you haven't got the diagnostic tool. Sorry for the lack of solution but there isn't really one you can do.(or i'd have told all my customers how to do it by now)
How can i resolve error 010-333 for xerox 7232
Fuser unit change problem continue nvm change 744-004 change value 0
Feb 09, 2014 | Xerox WorkCentre 7232 VSE All-In-One Laser...
Solution to solve error 010-320
We used to get lots of these messages on our DC240 & were told it was a room temperature issue. The following worls
10-320 error
DC 240 error, Caused by fuser being too cold
1) Press & hold "0" for over 10 seconds
2) Whilst keeping hold of "0", press START
3) Password is 6789, Confirm
4) Press key shaped key on keypad
5) System Settings
6) Common Settings
7) Main/Diagnostics
8) NVM Read Write
9) 744 350 Confirm/Change
10) Enter "0" into New Value, Save
11) Close, Exit, Close
12) Reboot
Apr 09, 2013 | Xerox DocuColor 3535 Copier
Dc 236 machine has a fault code 010-320. fuser is new, lvps is new and so the small board, i dont know the name of that board... but still 010-320 is there... trying to reset the value of nvm from 2 to 0,...
Well since you know how to enter diagnostics. Go to DC132 and select all copier nvm. Do an all copier nvm initialization, it will correct any default errors in the memory.
You will just have to then reset things like the power save timers and I would also go in and do a dc604 registration adjustment.
Apr 18, 2011 | Xerox DocuColor 3535 Copier
Xerox DocuColor 3535 103-208 error I accidentaly
There isn't much you can do, except perhaps buy at least one new board. But those are expensive
In this case, a better solution is to call Xerox. This correction must be done by an Authorized Xerox technician, with their proprietary laptop called a PWS.
They will run the procedure called GP-10 Replacing Billing PWBs.
Whit Item, Inc.
Nov 19, 2010 | Xerox DocuColor 3535 Copier
Hello, after a NVM reset my ADF stop working and color where in wrong places. I resolve the color problems but ADF is not working is this activated by a NVM code? Regards, Hugo
How did you resolve the color problem? I am having the same issue on a Xerox Workcentre 24. After initializing the NVM, the auto-feeder does not work and the colors are off. How did you resolve the colors being offset?
Feb 02, 2010 | Xerox DocuColor 3535 Copier
Error 010348
over heting of fuser unit
can be reset by NVM read/write
744-003 set to 0
Jan 11, 2010 | Xerox DocuColor 3535 Copier
Reset fault code 010-348 xerox 3535 copier i have replace the fuser with new
wait until the machine is in the 'Ready' state, then on the Control Panel, select [9] and [AC] simultaneously. A message will be displayed asking if the Fuser Cartridge was replaced, select [Yes].
Jan 01, 2010 | Xerox DocuColor 3535 Copier
Error-9-354
User Interface (UI) DIAGNOSTIC ENTRY:
Turn on the power… then while holding down the ‘0’ button, press ‘Start’.
The screen will prompt you for an “Access Number”… use the keypad to enter ‘6789’ which is the Default Access Number.
This should bring you to a menu of options to choose from:
• NVM Reset (Non Volatile Memory) / NVM Initialization
• NVM Read / Write (memory adjustments) you will need to know which codes do what
• Component Control (for testing sensors, motors, etc.)
• Print (for running Test Patterns from Diagnostics)
• Subsystem Check (for fuser nip measurement check out, and developer unit check out)
• Max Setup (for setting up copy quality)
Set NVM to 776-060=0 and 776-372=0
Hope that helps
Mike
Sep 23, 2009 | Xerox DocuColor 12 Color Copier
Xerox docucolor 3535 - error 010-348
Hi, you have to reset this code entering into diagnostic mode, If this fault is declared 3 times in succession, print and copy mode will be disabled. In order to clear this condition, reset NVM location 744-003 to 0. Saludos from mexico
May 10, 2009 | Xerox DocuColor 3535 Copier
Error code 010-348
Hi go to system settings and then go to NVM location then type 744-003 and then change the value in the lower field to 0.
Jun 26, 2008 | Xerox DocuColor 3535 Copier
178 people viewed this question
jasbo
jasbo
