Question about Radio Communications
How do I get my ''code'' for my Bluetooth-H710? (I changed phones)
I recently replaced my Blackberry and have a Motorola H710 bluetooth. I need the "code" in order to use with my new phone. How do I find the code? thanks!!
Code is 0000.... answer was posted on another site found at Google. Thanks!
Posted on Nov 20, 2008
Motorola h715 bluetooth pin number
Try '0000' (four zeros), which is the code chosen by the vast majority of bluetooth devices' manufactures.
I was able to find the user guide for the H710 headset, but unfortunately not for the H715. It's here, anyway. Hope you find it useful, somehow.
Cheers! Carlos
Apr 18, 2010 | Motorola Mobility H710 Bluetooth Headset
I'm trying to hook up a h710 to a blackberry curve
The default numeric passkey for the H710, is 0000.
I just paired my H710 with a brand new BB Tour, with no problems.
Sep 02, 2009 | Motorola Mobility H710 Bluetooth Headset
How can I listen to music from my LG ENV 3 Using the Motorola H71
Your blue tooth does not have that capability .I check myself google motorola h710 bluetooth
Aug 26, 2009 | Motorola Mobility H710 Bluetooth Headset
How do I add a 2nd phone to motorola bluetooth headset h710?
after you connect one phone. go into phone settings and turn off bluetooth. go to second phone open bluetooth options. not put your h710 into pairing mode. once paired, go back to original phone, turn bluetooth setting back on, and both devices are now paired.
Jul 03, 2009 | Motorola Mobility H710 Bluetooth Headset
Pairing H710 bluetooth to my Blackberry 8120
it is universal procedure to pair up all devices like this
first if ur hedset is switched on switch it OFF by long pressing the main button in the centre it will blink blue light twice or thrice and will switch OFF after that u can touch any button it will not respond with blinking lights
Now press again that centre main button long press for like 10 sec until that blue light comes on and become STABLE when it is stable it means it is ready to pair up with any bluetooth phone now go to ur phone switch the bluetooth ON and select search u will find ur headset with its model like H710 just select and when asked for pairing code enter 0000 Zero four times or try 8888 if it doesnt work , now u will see that ur headset light will start blinking and u will see a headset sign on the screen of ur mobile phone it means now it is paired up
now u can try to talk thru headset make a test call any number for voulume control there are two buttons on headset on upper sie with arrows u can select them to increase headset sound
pls rate me well for help ! Fixya rating is encouraging !
Apr 20, 2009 | Motorola Mobility H710 Bluetooth Headset
I hear the person clearly, they cannot hear me.
I recently had this same problem with my Motorola H710 Bluetooth & my Samsung SGH-A737. I could hear the people on my Bluetooth, and they couldn't hear me. It wasn't muted. I tried turning both the phone & the bluetooth off, then back on, first one, then the other, then vice versa; nothing worked.
Finally I deleted the H710 from my phone & reinstalled it. This fixed the problem.
To do this, navigate your phone's menu looking for the Bluetooth/Connections portion (every phone is different); select the bluetooth, then delete it from your phone.
To reinstall it, turn the bluetooth off. Then go back to your phone's menu and look for the equivalent of "Search For New Devices"; then, turn on the bluetooth. When your phone finds it, select it. The phone will ask you to input the pin. If it's the Motorola H710, the default pin should be four zeroes: "0000". I have heard this is the same for other Motorola's as well, but I can't say for sure. If you have another brand of bluetooth, either get out the manual and/or box (which should have the pin in it somewhere), or else get online and Google the model number and the word "pin"; you'll probably find it.
After I reinstalled it, it worked like a charm.
Apr 11, 2009 | Motorola Mobility H710 Bluetooth Headset
Pairing my motorola H710 to my Blackberry Storm phone
try and remove the current bluetooth device. Close the headset. Go to thephone and choose discover, or search. Open the headset and press and hold the big button. It should then turn purple and should be recognized.
Also make sure the battery on theheadset is charged before doing this.
The passkey will be 0000, four zeros.
Dec 30, 2008 | Motorola Mobility H710 Bluetooth Headset
Pairing my motorola h710 to my 8830 Blackberry
Depending on the phone... try and remove the current bluetooth device. Close the headset. Go to the phone and choose discover, or search. Open the headset and press and hold the big button. It should then turn purple and should be recognized. After this, it will ask for a passcode.
Dec 23, 2008 | Motorola Mobility H710 Bluetooth Headset
I loss my instructions for my Motorola H710 Bluetooth head set. I need to pair it with my black berry curve can someone help me accomplish this?
Hey notgni35,
Here is a link to the Motorola support site with step by step instruction on how to pair your Blackberry curve to your Bluetooth headset.
If you run into problems or need additional help simply replay again.
Thank you for using Fixya,
ERIC the PHONE GUY
sponsored by Cell Phone Technicians
Dec 15, 2008 | Motorola Mobility Blnc Bluetooth Car Kit...
Radio Communications Logo
80 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
