Can not get all my cable stations - Televison & Video
    Scholar:
  • 146 Answers
I will asume that you are not getting above channel 13. In that case you need to go into your menu of the tv and find the auto program area to program in your cable channels. You will also need to put the tv in cable mode as well. It will be in that same section of the tv.
Posted on Nov 19, 2008
I have a HP Z6100, and I got many times error 86:01 possible paperjam, after changing encoder strip and encoder sensor, carriage PCB. I still have 86:01 error, after Scan Axis in maintenance mode, the...
Observe when 86:10 error appearing? after intializing the carriage or immediately after powering on?
# If immediately error appearing do the below discussed activity
# after intializing if error appearing check trailing cable,service station wipers & cappings,cutter position, cutter movement & lubrication on rail.
Detatch power cable & data cable,remove right door, pull out carriage assembly from service station area (if its locked by service station manually unlock it). Remove cable connections, screws & take out service station from the printer.Place the service station out side(ensure that cables has to fix properly) connect the cables,switch on the machine, check for the error..
if error is not appearing: check the service station, found any damage replace it or shoot the problem.fix it back..
*even error is appearing: Remove carriage belt from the pully..check carriage movement, if found any hardness/obstruction? shoot the problem.
Finaly: check trailing cable( while carraige movement some tracks may lose their continuty)
Power supply.. ( check voltages)
Need your feedback for further help.. vinay229229@yahoo.co.in
Apr 11, 2012 | HP Designjet Z6100ps InkJet Printer
Need to get other stations on my philips magnavox can get standard ones but have cable and need to program in other stations need to know how, other tv in house have many stations and I just put this tv in...
Get into the menu and find the type of signal you want...cable or over the air. Set for cable and hit auto program! Be sure have a connection to the RF connector.
Dec 05, 2009 | Philips Magnavox 27MS343S 27" TV
The ethernet cable port on my docking station is broken.
It is hardly possible that anyone will even try to repair it. And believe it or not, it is cheaper to buy a new one then to repair the old one
Nov 17, 2009 | HP (EQ773AA ) Docking Station for nc2400...
710c cable will not fit in new docking station
Need to buy a new USB to Parallel converter kit (is just a cable and a cd with the installation drivers) cost around $20
Jul 27, 2009 | HP DeskJet 710c InkJet Printer
How to get from standard TV to Cable TV?
Should use remote to bring up the menu. Go to channel search and it will ask you if for ant or cable. This is where you will select for antenna or cable.
Feb 15, 2009 | Televison & Video
Not receiving my local cable stations
You need to make sure the TV is set for "cable" tuning and not "standard" or "air." (If you are getting only local off-air channels and no cable stations at all, be sure you have a good cable and connection to the set. Normally, even if the TV is set for "air" you will get the low-number cable channels 2-13.) This is usually a selection through the TV's set-up menu. With a universal remote, it may be difficult or even impossible to get to all the menu entries. Most replacement remotes don't support all the original remote functions. Try with yours and good luck. Once you get the TV set to the proper tuning, you should have all your cable channels.
Jan 03, 2009 | Durabrand BH1304D 13" TV
Cable needed to connect SNY DCR-SR40 Hndycm N DCRA-C162 Handycam Station to computer
There are 2 cables,
  1. A-V Connecting Cable P/N 1-831-553-11
  2. USB Cable P/N 1-829-579-41
attached with Handycam Station DCRA-C162. Hope this info is helpful to you.
Aug 12, 2008 | Sony Handycam DCR-SR40 Camcorder
Sony LCD Digital Color TV Model KDL26M300
If you only have basic cable with no cable box this may be normal. You may need to upgrade your service or get a cable box.
Dec 18, 2007 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
Television will not air all cable stations
If when you turn it on it starts to run through the stations let it go and finish.
Nov 18, 2007 | Sylvania 6719DF 19" TV/VCR/DVD
Televison & Video Logo
52 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
