Question about Philips 32PT6441/37 32" TV
Shut down when press
I have a 25" samsung TV CTX2516. When I press the volume up/down button on the TV/remote, it shut down within a second for a second and restart by itself. Any solution
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 108 Answers
1.Check whether your Remote buttons jammed else on the TV.
2.there might be some problem Remote ir receiver unit in your TV
3. Microprocessor/microcontroller unit on Remote signal receiver board
Posted on Dec 22, 2007
Sky remote volume code
  1. Switch on the TV set
  2. Press the TV button on the Sky Remote
  3. Hold down the Select and Red buttons for 2-3 seconds until the LED blinks twice
  4. Press the TV button on the Sky Remote again
  5. Enter the 4 digit code for your make of TV
  6. The LED should blink twice, if not recheck the 4 digit code used and go back to 1
  7. Press the standby button on the Sky Remote (The TV should go to standby)
  8. Press the Select button to store
Samsung Code 0060
Nov 28, 2011 | Televison & Video
Virgin remote control code for volume on my 50" samsung plasma tv
To set up the volume control on your Telewest remote control, to be able to change the TV volume, please follow the instructions below.
1. Using the table below find your make of TV and the code which matches it.
2. Press and hold down Volume + and mute on your remote control at the same time for at least three seconds, until the green light in the top right-hand corner of your remote control flashes twice.
3. Release the buttons and enter the first four digit code from the table below. (You must do this within ten seconds).
4. As you enter the first three digits the green light on your remote control will give a short blink.
5. As you enter the fourth digit, the green light will flash twice to confirm that the volume is set.
If setting the volume is not successful, please repeat the above steps with the second or third codes from the table below.
Samsung 0065, 0584, 0037
Nov 18, 2011 | Samsung 50 in. Plasma TV
HOW DO I RESET THE LAMP TIMER ON A SONY KDF55WF655
Procedure for resetting your lamp timer,
Use the Remote Commander to put the set into service mode to display the service menus.
1. TV must be in standby mode (Power off).
2. Press the following buttons on the Remote commander within a second of each other: DISPLAY ==> Channel 5 ==> Volume + ==> POWER. The first service menu (TV) displays.
To reset the Lamp Timer:
1. Press the JUMP button 3 times on the remote to get to the Panel OSD mode.
2. Next press the remote channel 2 button 9 times to get to the Lamp Timer mode.
3. Press the remote 3 button, mute, then enter to reset the timer to zero.
It will take 45-50 seconds for the timer to reset. After the timer is reset you can shut the TV off. The lamp timer will remain reset (no need to save).
Jun 30, 2011 | Sony Televison & Video
The volume will go to high by itself, and then decide to go all the way down, without touching the remote or the tv volume buttones.
The Samsung brand is the most universal remote compatible tv out there, sounds like either a neighbor or even someone in your own home has a Samsung product that will work on your plasma. for example if someone within range has a Samsung dvd or blue ray player the volume up and down button will work on the Samsung tv also.
May 30, 2011 | Samsung 50 in. Plasma TV
I have a Emerson LD190EM1 Tv DVD combo. It will not work with my Dish Network remote. What is the IR code?
I also have the same tv with no luck on my dish network with the codes. However, I just did an autoscan and found the code, but it doesn't tell you what code. I am sorry I cannot give you the code, since manually entering them did not work, but the auto scan did work!
To run auto scan follow these steps.... it took me about 5 minutes to find on my dish network remote.
1. Press and hold the tv mode button until all other mode lights flash.
2. Press the red power button (not the red tv power button, but the power button which normally shuts off your receiver only)
3. Press the up button (about every other second) When your remote finds the code, your tv will automatically shut off.... once it shuts off, DO NOT press the up button again.
4. While the tv is off, press the pound (#) button.
Your remote will be programmed to your tv. Turn on your tv with the small red power button with the tv wording and test other functions (volume, etc.)
I tried this last night, waiting about 3 seconds in betwwen with no luck after 30 minutes, just a tired finger from constantly pressing the up button. But tonight I tried it on my LD190EM1 and paused for a second inbetween pressing up and almost fainted when the tv actually shut off within 5 minutes of starting! Best of Luck!!!
May 19, 2011 | Televison & Video
How do I program the oversized brookstone tv remote control to my new Samsung television?
Step 1: Turn on the device you wish to program (TV, VCR, DVD) manually
Step 2: Press and hold the button for the device you wish to program for more than 3 seconds, the red LED will illuminate indicating that the remote is ready to accept a three digit code.
Step 3: Enter the first three digit code listed below within 30 seconds, the red LED will shut off indicating that the remote is programmed.
Step 4: Press the ON/OFF button to verify correct code entry. If the device shuts off then no further programming is required.
Step 6: If the device does not respond, repeat steps 2-5 using a different three digit code.
Samsung - 043, 048, 054, 057, 062, 073, 074, 075, 078, 080, 089, 092, 097, 104, 112, 117, 118, 125, 131, 139.
Jan 13, 2011 | Brookstone 538744 Remote Control
I need to re tune my samsung tv but have no remote any ideas?
you can always use the button on your Tv itself.
ie menu = Menu
Channel up/down = take you up and down
volume = goes left and right.
follow these steps
Menu,
channel down button to CHANNEL
press the volume button along
channel down button to AUTO STORE
press the volume button to Start the scan.
right now you have your telly tuned in. What you could do it get an old sky remote off a friend/ neighbour. or buy from argos etc ( a lot cheaper then getting a replacement samsung one)
press the following buttons on the sky remote to program it to work with your samsung tv.
TV,
RED + SELECT
TV.
0060
try the volume if this works press SELECT to save this code if it doesnt press Tv then try the volume again. repeat this step until the volume works your telly. once it doest dont forget to press the SELECT button to save.
Now you will be able to change your volume use the number keys. if you also press the HELP button on the sky remote this will also change your AV / SOURCE I hope this post helps you out. When it does please leave a thumbs up for me Please
Cheers Little Dish Fitter
Sep 21, 2009 | Samsung LN-S3251D 32 in. LCD HDTV
How can I turn off the fpa lock without the remote?
Hi
Usually this is the issue with RCA TVs (or any other TVs) not Air Conditioner which I think you wrongly chose. To resolve the issue press and hold the channel up button on the TV and press the volume up button at the same time. If this does not work repeat this but pressing the volume down button. With the original remote you would Press VOL- on the TV's front panel and then CLEAR on the remote for approximately 5 seconds. Depending on the model, one of the methods should unlock the V-chip. Try each method until you find one that works:
  1. Hold down MENU on the remote and VOLUME DOWN on the TV it's self at the same time for at least 4 seconds. The set won't say so, but the lock will be unlocked
  2. Hold down the 0 on the remote and the VOLUME DOWN buttons on the TV its self at the same time for at least 4 seconds. The set won't say so, but the lock will be unlocked
  3. Hold down the MENU button on the front of the TV and the TV button on the remote at the same time for at least 4 seconds.
  4. Hold down GO BACK on the remote and MENU on the front of the TV at the same time for at least 4 seconds.
  5. Hold down EJECT on the front of the TV and the MENU button on the remote at the same time for at least 4 seconds.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Sep 17, 2009 | Heating & Cooling
Samsung LCD picture adjustment... Store Demo...WTF...?
Push the volume button on the television set (not the remote) up once.
Then press the menu button (TV, not remote) for about 12 seconds.
It should flash once and go to dynamic mode (center, bottom of the screen), which will indicate that it is now in the "non-store-demo" mode, allowing you to save your picture settings, and access the menus.
Sep 24, 2008 | Televison & Video
Philips 32PT6441/37 32" TV Logo
80 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
