Question about Ricoh FAX2900L Plain Paper Laser
Hey Logjam Im having trouble with a fax, it is recieving, but not sending anything. Any Ideas?
Is the fax line an extension off a PBX? If it is, you need to insert a 9 in front of the number. If you have to dial a 9 from your phone to dial out, then your fax machine may also have to dial the 9.
Posted on Jun 10, 2009
With my epson 520 i can recieve faxes but i can't send them.. everytime i send one it says no answer but i verify that the fax line im sending it to does work.
Hey I had this issue as well with my FAX and I validated that my setting were good and I'd even hear the Fax line pick-up and get a "no Answer" error. I went into FAX settings and just turned something called TCM off and then it worked. Maybe it is for sending it to an older Fax machine, but I did get it to work!
Dec 05, 2010 | Epson Stylus Multifunction Printer/...
I havent used the fax machine in quite sometime<<< i must be doing something wrong... im able to receive faxs but cannot send them, im sure im prolly doing something wrong can u give...
Hey!!The best and fastest way is to put in your documents in the ADF(automatic Document Feeder)Put the machine on fax,Dail your fax number and press the BLACK start button.Good Luck!!
Nov 05, 2010 | Canon MX310 Office All-In-One Printer
Fax machine isn't able to recieve or send anything
Make sure there is a dial tone on the phone reciever. If there is not check the connections, the cord could be damaged or disconnected. If there is, check the Recieve mode.
If not call Brother support - its free
Mar 31, 2010 | Brother IntelliFAX 2800 Laser Fax
Can't send or recieve faxes
Having trouble receiving faxes?
http://www.brother-usa.com/FAQs/Solution.aspx?FAQID=200000018476&Sympt=I+am+having+problems+receiving+faxes.+What+can+I+do%3f&Model=1292&ProductGroup=5&Keyword=fax&ProductID=MFC7840W
Having trouble sending faxes?
http://www.brother-usa.com/FAQs/Solution.aspx?FAQID=200000018532&Sympt=I%27m+having+problems+sending+faxes.+What+can+I+do%3f&Model=1292&ProductGroup=5&Keyword=fax&ProductID=MFC7840W
I hope this helps!
Dec 11, 2009 | Brother MFC 7840W Printer
I cannot receive faxes
Fax has to be set to auto recieve.
Apr 07, 2009 | Brother Office Equipment & Supplies
Can't recieve or fax records
Check for bent contact pins that rest against the cartridge.
May 30, 2008 | Brother IntelliFAX 885MC Plain Paper...
Sending a fax
First make sure that the fax button has been pushed and is llit...
The 2820 should have a handset. In order to use manual transmission (when you get to hear all the beeps and whistles) you will need to load the document then pick up the handset. then dial the number, when you hear the recieving fax tone then hit the start button.
The 2820 should also have a hook hold button pressing this will allow you to hear the dial tone and the numbers you dial along with the receiving fax tone. If you dont hear anything when you press this button then you may want to use the volume buttons to increase the volume.
Also remember that if you have not picked up the handset or pressed he hook/hold button the unit will use automatic mode, which is to say that all you will do is load the document, dial the number, and then press the start button.
May 19, 2008 | Brother IntelliFax-2820 Laser Fax
How to fax
The online interactive e-STUDIO 282 manual can be found here
Jan 15, 2008 | Office Equipment & Supplies
Busy signal on sending and recieving
Did you plug a phone into the phone jack and see if there is a dial tone?
Thats the first place to start.
After that let me know, and I will give you more ideas.
Sounds like a phone line issue
Dec 12, 2007 | Brother IntelliFAX 4100 Laser Fax
Ricoh FAX2900L Plain Paper Laser Logo
103 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
OfficeServiceAjnc
OfficeServiceAjnc
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
