Question about Mitsubishi VS-60609 60" Rear Projection Television
My Pioneer SD-P5071-K has a very faint picture
Hi and thanks in advance. My tv has a very faint picture. If I turn off all lights and position myself correctly, I can strain and see what's on. I notice the picture is either lightening up, slightly, as time goes on, or my eyes are adjusting. However, still very, very faint. I had a fellow come out and charge me $189 to "clean" the tv, well his remedy did not solve the tv's problem, he said he'd be right back, that was,....oh,.....about October, a month and a half ago. Guess he got sidetracked. Can a tech out there offer assistance?
THERE ARE 9 ADJUSTMENT POTS ON THE FRONT LEFT SIDE OF THE UNIT BEHIND THE SPEAKER COVER WHICH POPS OFF IF YOU GRAB THE OUTSIDE EDGES. ADJUST THEM THAT WILL FIX IT.
Posted on May 14, 2007
Pioneer 52" projection TV, SD-533HDS,
It is likely that the CRT's (picture tubes or bulbs) are weak. It is a major job to change and all three should be changed to make the picture like new. However, it is not costwise to repair this old of a TV even if you can get the tubes. I estimate the cost of each tube is at least $200 each. I would call Pioneer and give them your model number and see if they are available. Only a trained technician should change the tubes because it requires a lot of time and setting up of the tubes and other things.
Jun 04, 2011 | Pioneer SD-533HD5 53" Rear Projection HDTV
Temporary losing picture
CHCK THE OPTIONS MENU SEE IF IT HAS A COLOR CONVERSION OPTION ,,TRY THAT,,ALLIGN THE COLORS
May 14, 2009 | Pioneer SD-582HD5 58" Rear Projection...
Pioneer SD-532HD5 - Picture Bowed on sides only on 1080I
The problem you are describing is known as a pincushoin problem. I'm a bit surprized that you only see it on the 1080i signal though. I've inquired at my Pioneer contact about this and will update this soon.
Stay tuned...
Dan
Jan 07, 2009 | Pioneer SD-643HD5 64" Rear Projection...
Power Supply part problem with a SD-P5795W
I wouldn't trust anything this repairman said reason well for one thing how could he (or anyone) tell everything else is "in perfect condition" when he couldn't "see" anything to tell what it looked like. He might be right about the power supply being bad But it could also be the high voltage "power supply" could have a short and that would cause the symptions you describe
But if you want to try the power supply your self you can call Pioneer and give them the model number and they should be able to get the information you need.
tvkirk
Dec 24, 2008 | Pioneer SD-P5795W 57" Rear Projection...
55" PIONEER SD-P5795W REAR..
yeah, I have the same issue... The tv worked fine, and now it will not turn on... the light turns green, then turns off and goes red...
Aug 03, 2008 | Pioneer SD-P5795W 57" Rear Projection...
Picture/sound goes out after 10 minutes of TV use
Rear projection hdtv, most likely damaged tubes. Don't repair this by your self get a tv repair man to do it before you injure your self.
Jun 24, 2008 | Pioneer SD-582HD5 58" Rear Projection...
Pioneer sd-p5071-k intermintently turns off, when on its works beautifully
You may need the power supply board resoldered as I had the same problem. The guy listed below can do it for you as I shipped mine from Illinois to him in California... Piece of cake getting the board out of the back and it's not too fraigile... Just pack in bubble wrap and it will be fine. My TV is now working great.
BUT DON'T DELAY AS SOONER LATER TV WILL NOT RESTART..
http://www.avsforum.com/avs-vb/showthread.php?t=402397&pp=30&page=38
Good luck.
cell
Dec 01, 2007 | Pioneer SD-P50A5-K 50" Rear Projection...
Pioneer SD 5575 - Needs to wam up
best thing i can suggest is buying a can of freeze from radio shack and spraying each ic/transistor till the problem appears again.
Nov 11, 2007 | Pioneer SD-533HD5 53" Rear Projection HDTV
Pioneer SD P5071-K has a dark picture, though, a good one.
You didn't mention if this problem suddenly happened or has been getting dimmer over time. If it's the latter, it could be a heavy buildup of dust/soot/smoke (depending if there are smokers in the house or a wood stove, etc) or the picture tubes going bad. If the set is over 9 years old, I'd replace it with a HDTV set and not look back. If the problem occurred suddendly, then a resistor or some other component may have gone out and it again would not likely be a cheap or easy repair.
Dec 16, 2006 | Pioneer SD-P5795W 57" Rear Projection...
Mitsubishi VS-60609 60" Rear Projection Television Logo
70 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
