Question about Epson Stylus C84 InkJet Printer
Power on problem
When printer is powered on, the print head bangs on each side. Does anyone out there know how to time an Epson Stylus C84????
  • Epson Master
  • 705 Answers
There is an encoded registration strip just behind the print head near the drive belt. This needs to be clean and obviously attached. If the strip is too dirty or not present the head does not know where it is and crashes into the ends of the rail. If the strip is clean and located correctly but the head is still crashing around, then the optical sensor on the rear of the head may be faulty. This is usually uneconomical to repair. Get a service manual from http://www.TheserviceManualShop.com as it shows where the encoder is located and how it is threaded through the head etc
Posted on Sep 28, 2007
SOURCE:
Epson Stylus C84 Fuzzy printing every five rows of
Try re-aligning the heads using the alignment software function
Jan 01, 2011 | Epson Stylus C84 InkJet Printer
Epson Stylus C84 prints every other line.. Cleaned print heads and ran nozzle check...still same problem.
Your printer head may be booked. Follow the instruction given bellow:
1. Open printer cover and put off cartige from cartige chamber.
2. Take a plastic seringe with full of ink and fit it on head's stick. Then push ink carefully.
use this procedure one after another . I thing you may relive from your problem. thank you.
Aug 17, 2010 | Epson Stylus C84 InkJet Printer
My epson stylus c84 printer does not print
Hi
Thanks for using FixYa. The printer won't operate properly if it's tilted. Place it on a stable and flat surface. Please do not leave your printer turned on when not in use to avoid print heads being clogged. In the instant case the ink cartridges can also leak into the printer. If the print heads are clogged then run the head cleaning and alignment utility. The print head nozzles may also need cleaning.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Aug 24, 2009 | Epson Stylus C84 InkJet Printer
Printer keeps printing lines across the page of 1
Width of head sprayer (head output) of black is about 1". Check nozzle. It might be some point of head spayer distort. See check nozzle ouput. There are tranversal and vertical lines that represent same point of head sprayer. Is the output perfectly straight and no clog at all? Do head cleaning procedure.
Aug 21, 2009 | Epson Stylus C84 InkJet Printer
Epson c84 printer not printing after installing new ink cartidges
Hi, Linda
You may buy cartriges of different producers.
Depending on producer on them can be or be not special yellow detachable labels.
These are an yellow labels must be removed from them. Then put cartridges back. And try to clean head 4-5 times. And check nozzle test.
Good luck.
Mar 06, 2009 | Epson Stylus C84 InkJet Printer
Epson stylus c84 inkjet printer
I don't know if this will help but your problem sounds like one I had with a C82 model. On the right side of the printer below where the print head rests is a small plastic suction tube. This tube can become disconnected and will prevent the printer from printing. Check to see if this is your problem. In the picture the red circle shows where the tube connects and the yellow shows the tube.
Jul 13, 2008 | Epson Stylus C84 InkJet Printer
Ink printing problem
Did you remove the plastic from the bottom ofthe cartridge, if not do so and changing from vista to xp would change that probelm.
Jamiell
May 13, 2008 | Epson Stylus C84 InkJet Printer
Printer does not print
An ink supplier advised turning off the printer for 15 minutes, turn it on and try again. That worked once. Next time he suggested turning off printer, removing all cartridges, waiting 15 minutes, replacing cartridges. I couldn't do this without turning the printer back on and going through the replace cartridges routine. Now the nozzle check routine printed magenta and yellow only. I've run the head cleaner a number of times with no success.  Hope one of these suggestions works for you.
Jan 06, 2008 | Epson Stylus C84 InkJet Printer
BIG PROBLEM
If any of the ink cartridges are needing to be replaced, the Epson C84 will not print, you will have to change the cartridge, if you lift up the printer lid the carrier will stop at the empty ink colour.
Nov 14, 2006 | Epson Stylus C84 InkJet Printer
Epson Stylus C84 InkJet Printer Logo
153 people viewed this question
Top Epson Office Equipment & Supplies Experts
Inky Fingers
Inky Fingers
Clive
Clive
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
