Question about Dryers
I have a Whirlpool Dyer, model #LHE5800WD
A Few months ago, the dryer would no longer turn off automatically, but it would still heat. So I have just tolerated the problem.
Now the dryer will no longer heat. How do I repair this problem?
  • Anonymous Apr 20, 2009
    i have a whirlpool dyer that will run but will not heat at any temp setting
  • 370 Answers
You have a bad timer. when you replace the timer it will start heating again. Get me the model # and i can get the part number and price.
Posted on Nov 19, 2008
Electric dyer no heat
Online appliance parts sites have been helpful to me. They may help you diagnose the problem and recommend a repair part. It's their business.
Apr 01, 2015 | Whirlpool Dryers
No heat for whirlppol steam dryer
check the heater element, it may need replacement
Dec 22, 2013 | Dryers
Heating problem
There is a thermal cutoff built into the dryer to protect from fires due to overheating. This could be activating after the dryer starts running for a while. Is it possible that the exhaust duct is clogged up with lint? Check the airflow at the dryer vent.
Dec 17, 2013 | GE DCVH515GF Gas Dryer
I have a whirlpool lgr5634a gas dryer, it heats up but does not seem to heat as high as it should.
possible of lint build up in the discharge vent vaccum/clean out first. next ensure the filter trap is clean and the below area is in the discharge area is cleaned out. also the sensor on the inside of the drum could be coated with sooftner causing the sensor that automaticly tells the dryer when top stop/ amount of heat to produce could be coated use isopropel alchol to clean and check after 10 minutes if the dyer is functioning properly at this time.
Mar 05, 2011 | Whirlpool LGR5634L Gas Dryer
Whirlpool dyer is running however no longer heating
The first thing i would cheak is to see if you have 110volts on each side and 220 acrosson plug recepticle if you do not have a voltage meter try the breaker.It will be a double 30 try and snap it on and off 2 times and see if the heat comes on.If not you may want to cheak the safty thermostat located under the back panel.It will be the top thermostat on the heater housing.Bypass by joining the wires together and tape so no short happens.Turn on dryer still no heat i would say you need new element.Would say timer but very very rare timer is problem.
Jan 29, 2011 | Whirlpool Dryers
Whirlpool dryer WED5530SQ0, heats but does not run
So,. basically your drum doesnt turn. SO your getting heat still even though the drum isnt turning. Is this right? Sounds strange??? Do you hear any humming noise when you push the start button? I need to know a little more about the problem because im kinda confused as how you decribed the problem. Iv never seen a dryer heat but the drum not spinning. especially your model dryer. Its electric heat right? because if the drum doesnt spin, maybe your motor is bad. and if your motor is bad, then your heating element wont heat up because the centrifical switch in the motor is not switching to complete the circuit to the heating element. So this is why im confused when you said" Dryer heats when knob turned but when "push button" pressed, drum doesnt run." Because your belt wraps around the motor pully and the motor is what makes the drum turn. Like i said, i never seen this model dryer heat with out the motor operating. So if you can give me some more info, ill do my best to help you out....Thanks!!!!
Jul 30, 2009 | Whirlpool WED5500S Electric Dryer
Whirlpool model number LGV7646ANO gas dyer will not heat up
Can you hear a click like always? If not then it has to be either the fuse, ignitor,or sensor. If you hear it clicking then the operator coils are dead. HERE is a link that shows pictures of these parts and locations.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jan 19, 2009 | Whirlpool GGQ8831L Gas Dryer
LGR4634EQ1-DYER WILL NOT HEAT UP
Go to: RepairClinic.com
There you can troubleshoot
your appliance.
You'll need make & model #.
Nov 15, 2008 | Whirlpool LGR3624JQ Gas Dryer
Whirlpool Electric Dyer Problem
most of the time the dryer vent hose,wall vent and dryer vent hole must be clear to allow the dryer to vent,also you can pull dryer hot put you hand on the dryer vent hole turn on and see if it is venting this will let you know if the blower wheel is turning, let me know what you find-mike
Sep 25, 2008 | Whirlpool Dryers
Dryer runs but not heating
Check the vent it may be clog with lint, make sure the vent that is going to the dyer and outside the house is clear.
May 10, 2008 | Dryers
Dryers Logo
89 people viewed this question
Top Dryers Experts
Marvin
Marvin
