Question about Dishwashers
Kenmore elite dishwasher codes
I have a Kenmore Elite dishwasher, model # 665.13762K601. I'm getting tired of resetting the blinking clean light. Does anybody know the list of codes for this machine, so I don't have to call Sears.
  • bradley6 Mar 19, 2009
    Same problem .. blinking clean
5 Suggested Answers
  • 213 Answers
SOURCE: kenmore elite dishwasher
press back and forth between hi-tempwash and sani rinse several times to get all lights to come on if not then press sani rinse and heated dry back and forth several times. one of though combos will start the test mode. the test mode will stop the light from blinking and you can use the dishwasher again
Posted on Nov 28, 2007
aborcass
  • 2651 Answers
SOURCE: My kenmore elite ultrawash dishwasher,
youll need to enter a diagnistic mode, press in this order, hi-temp(sani-rinse)----heated dry--hitemp---heated dry... all lights should light, close door and let cycle for about a min, htne press the cancelbutton, you should be good to go, the buttons on your model may read slighty different names, if this "toggle of buttons" does not work, you can remove thelower access panel and htere willl be a tech sheet/trouble shoooter behind the panel, in there it will explain how to enter diag/test mode
Posted on Dec 24, 2008
  • 172 Answers
SOURCE: KENMORE ELITE DISHWASHER - MULTI-LIGHTS FLASHING
Look at your manual, usually available on net for reading or downloading. Blink lights are often used to code out a problem with various combinations and repetition rates to indicate trouble code number for look-up in manual.
Posted on Feb 22, 2009
ginko
  • 19396 Answers
SOURCE: Kenmore Elite 137889, grinding noise
If the noise is like a shaking of rattling , like coins being shaked , then it is an object trapped inside the tub.
If instead the noise is a loud grinding , that may get louder on high speed, then it is usually a bad drum bearing.
The drum bearing is replaced by accessing the bottom side of the washer, and is a not a simple repair.
Posted on May 05, 2009
SOURCE: How do I go about Replacing the Heating Element on
I am waiting on a heating element. Once installed, we hope the problem is resolved.
Thank you.
Posted on Jun 04, 2009
The pots and pans light and normal light is blinking
Kenmore Elite Dishwasher blinking light Control Board FIX ...
? 1:37
www.youtube.com/watch?v=flzhfmIIYpM
Apr 14, 2011 - Uploaded by MegaHowtoMan Kenmore Elite Dishwasher blinking light Control Board FIX ....year old washer, did a google search for the problem, and your video came up.
Sep 01, 2015 | Dishwashers
Blinking clean light, not completing cycles
some of the dishwasher have a device in them that you have to remove the container and clean it. mine is up side down cup that unscrews.
go to www.wikipedia.org
kenmore elite blink clean light
or go on to www.sears.com/service
talk to someone or look on line at
www.youtube.com/kenmore_elite_blinking_clean_light
see if anyone else had this issue
Mar 25, 2015 | Kenmore 24 in. Elite Built-In Dishwasher...
Our Kenmore Elite Dishwasher has a blinking green light next to the clean cycle. It won't reset. We changed the motor and this has been going on ever since. Do you know what we need to do to fix it....
Hello
Blinking green light can be reset by following two buttons in sequence: press HIGH TEMP WASH-HEATED DRY buttons in sequence around 3-4 times so that the control reset itself. Please get back to me if you have any other questions.
Kevin
Nov 11, 2010 | Kenmore Elite 45986 Front Load Washer
Feb 22, 2009 | Kenmore Dishwashers
I had the same problem when I bought it and it just happened again; the problem is solved by ressting the control panel: Hi Temp ---> Heated Dry two or three times. It kind of goes into a testing cycle and the clean blinking light goes off.
Dec 08, 2007 | Kenmore 24 in. 16032 Built-in Dishwasher
Nov 27, 2007 | Kenmore 24 in. 17482 / 17484 / 17489...
Green clean light keeps blinking
HI, Same thing happened to me today and Sears more than willing to charge me 200.00 for a 1 year service agreement. I found the answer on askmehelpdesk.com and the answer is: To reset a Kenmore Ultra Wash elite series dishwasher (stuck on clean) simply push heated/dry then normal wash and do the same thing again. Panel will reset itself and it hopefully will run normally again. Mine did and I am rejoicing! Julie
Aug 24, 2007 | Kenmore 24 in. 16302 Built-in Dishwasher
Dishwashers Logo
311 people viewed this question
Top Dishwashers Experts
Mike Cairns
Mike Cairns
