Question about Amana ABB1927DE Bottom Freezer Refrigerator
The fridge compartment doesnt keep food cool mine does the same thing - it is intermitten; I cleaned the coils first, but noticed the freezer is OK. When I started to take apart the covers inside it started working & worked for a month. Now it's happening again...I banged on the plastic covers and it worked for awhile but cut out.
  • gaanderson2 Nov 20, 2008
    I manually defrosted last night & now it is cool, but I suspect it will happen again. I know how to ck. the heater and T-stat which I'm assuming is behind the cover plate. Amana ARB2257CC is on the sales rcpt. (6/10/03) Can anyone tell me if the timer is manual or electronic? Where is it located? Do they glue a schematic to the back of the unit?
    Thanks for any addl. help.
    Thank you very much - for some reason could find it myself. I can figure things out but when I open it up this weekend I will feel a lot more confidence now. (Especially w/a cooler full of frozen food!)
    Thanks again & God bless you guys.
  • 4,806 Answers
Here is the sevice manual:
http://www.servicematters.com/maytag_library/docs/16025629.pdf
hope this helps
regards
Posted on Nov 20, 2008
  • Amana Master
  • 19,396 Answers
Check that the defrost system and the fan at the back is working, if it is not the defrost system, then it is probably the thermistor.
Posted on Nov 19, 2008
  • Ginko
    Ginko Nov 20, 2008
    If you solved the problem by defrosting, then it is was the condenser under stress because of an inefficient defrosting.
    Observe the fridge behaviour for a while and see how it goes.
    Here you get all diagrams for your fridge.
    The defrost timer is electronic, here is the part: PS649809
    Genius:
  • 1,550 Answers
The fresh food section gets cold air as from the fan motor blowing the cold air from the freezer side to the fresh food side. This is done through vents & air ducts. If the freezer side has an ice build-up, this will prevent the fan motor from working correctly. This is usually caused by a failure of the defrost assembly or fan motor. I would recommend removing all the food from the entire refrigerator/freezer & turning the unit off for 24 hours.
Hotpoint Future fridge freezer - freezer working well but top of the back of the fridge has a large build up of ice ??? And doesn't appear to be keeping the food cold enough
here are lots of things that can cause cooling problems. One of the most common causes of poor cooling in a frost free refrigerator is a defrost system failure. In such a case one or the other compartment may appear to be keeping proper temperature but that too may change in a short period of time. The fridge compartment's temperature rise is usually (but not always) the first to be noticed. Frost" and "Ice"
There is a difference between "frost" (a white, snow-like substance) and "ice" (usually clear and solid). When referring to what is seen during an inspection, please keep this distinction in mind as the possible causes for each are often very different. The Defrost System
Inspecting the (usually rear) wall of the freezer compartment for a frost build up is necessary. (In the case of many GE top freezer models, check the freezer's bottom panel.) If there is a frost coating on it, it is often a sign of excessive frosting beneath it. Sometimes however the evaporator cover panel will actually need to be removed (see the illustration below) before an excessive frost build will visible.
The refrigeration system's evaporator (cooling) coil is usually in the freezer compartment. This evaporator will periodically frost over and have to be defrosted by means of a heating system. When the defrost heating system fails, the frost can accumulate to such a degree that airflow throughout the appliance is hampered. There may be just enough air circulation to cool the freezer section but that will eventually stop too.
Sep 28, 2016 | Hotpoint Refrigerators
Rge 400 fridge freezer purchased 2011
try moving the temp prob down on coils inside or let hang if same unplug thermistor in back let run overnite if ok replace thermistor
Jun 16, 2014 | Dometic Refrigerators
Why is my fridge warm
There is a fan and a damper the blows cold air from freezer to refrigerator compartment. Damper is stuck closed or fan is not working is a good starting point.
May 07, 2017 | Whirlpool Refrigerators
Rm4400 freezer working fridge not
move temp sensor that's mounted in coils down or let hang if same replace sensor
Jan 19, 2014 | Dometic Refrigerators
This unit is used in a garage as a 2nd unit. It
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Dec 26, 2010 | Whirlpool 25.2 cu. ft. Side-by-Side...
I have an amana fridge model # arb190rcw.nothing remains frozen in the freezer.and i have noticed ice on the back wall of the freezer compartment
Your cooling coils have frosted so much that there is ice forming allover the cooling coils and preventing the actual cooling inthe fridge. First of all shut off the fridge for about 10 hours and wait for all the ice to defrost. Clean up your fridge well and then check inside of the freezer compartment for break in wiring, failure of the heater or the thermostat. Now put the fridge on and see if the cooling comes back.If the set works ok then dont worry till you experience the same fault coming back. In this case your auto defrost timer could be faulty as it is not doing the 8 hours cycle defrosting. Check this out test and replace . Get help if you are not familiar. good day
Jul 31, 2010 | Amana ARB190RCW Bottom Freezer...
I cleaned out my fridge completely today. Took all the shelves out, cleaned the interior, all the glass over a three hour period. The freezer is working just fine, the fresh food area is nice and dry but...
Manufacturers suggest that it takes approximately 24 hours for the temperature to stabilize in both your freezer and fresh food compartments after being turned off for an extended period of time. Adjust temperature settings to the "half-way" mark for both freezer and fresh food compartments. Allow a period overnight and recheck the temperatures. Also check the condenser coil (usually located underneath the appliance). If clogged with dirt/lint, it needs to be cleaned (carefully) with a condenser coil brush (can be purchased at Home Depot or Lowe's). Prior to cleaning condenser coil, turn off appliance (there is a condenser fan motor and blade operating while on). Be careful not to damage copper tubing (refrigerant in tubing)!
Feb 16, 2010 | Refrigerators
MY FREEZE DOES NOT FREEZ BUT IS COOLD DOES IT NEEDS GAS
When the compressor is running, two fans should be running. One inside the freezer compartment that moves air over the evaporator coils. The other is under/behind the fridge that cools the condenser coils.
If the fan on the condenser coil (the one under/behind the fridge) stops working, the system cannot dissipate the heat from those coils, and thus cannot sufficiently cool the inside of either the freezer nor fresh food compartment.
On mine, when the condenser fan failed, I noticed right away. The front face of the wall separating the compartments became very hot. Extremely hot.
Apparently the refrigeration system is designed so that waste heat keeps condensation from forming where the magnetic gaskets on the door need to seal. When the condenser fan failed, there was too much waste heat (because no heat was being dissipated from the condenser coils by the fan), thus making that gasket-sealing area very hot.
If it is your condenser coil fan, you can relieve the problem temporarily by removing the bottom back panel from the fridge and aiming a box fan (a regular room or window fan) at the condenser coils. This will circulate air over the coils, thus removing heat from the coils.
Jul 29, 2009 | GE GSH25JFR Side by Side Refrigerator
Freezer and Fridge temperature not very cold
I can find only one good reason why your refrigerator may not be cooling. There is a control board inside the fresh food compartment and no signs of a defrost timer. If there is someone that go through some test to eliminate other possible problems would be good. If the refrigerator is still running, unplug and open the freezer compartment. Remove the back panel so we can have a look at the evaporator coils. Clean or are they frozen with a large piece of ice? Let me know, Thanks Sea Breeze
Mar 23, 2009 | Maytag ZigZagW / B Side by Side...
LG GR727RB Top Freezer ok but bottom fridge is not cool
Hi softwaredude with an LG GR-727R refrig. The occasional build up of water on the bottom of the fresh foods sections tells me that the refrig is going through it's defrost cycle, but that the defrost drain is plugged. If you take the back off the refrig. you will see a plastic tube about 1/2 inch diameter with a few ribs on it going from the top of the compressor compartment to the bottom, which is a defrost water holding / evaporating pan. Look to see if that tube is plugged. If not, it is plugged further up, most likely where the defrost water drains off the evaporator (that the coils behind the freezer wall that do all the cooling). Take that back panel off and use a hair dryer to melt all the frost off. The frost is blocking air flow from the freezer section to the fresh foods section, thus poor or no cooling in the FF section. You should be able to spot where the defrost water is suppose to drain. If the water is not draining out, use a turkey baster with hot water to flush out the drain.
Dec 04, 2008 | LG LRBN20510WW Bottom Freezer Refrigerator
Amana ABB1927DE Bottom Freezer Refrigerator Logo
20 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
