Question about Compaq Presario 700 470024-192 Notebook
Laptop battery problem
Laptop dc power on , and battery no power on. whats any setup in changing? what problem? please diagram slution to me.
  • faisalj Dec 12, 2008
    i bought a new hp compaq 6270 before a week and suddenly its battery is not getting charged when i plug in the power cable in to it
    Genius:
  • 1,124 Answers
I think that your battery is bad or you have a board connection issue.
This could be helping you also (related issues):
1.- Computer AC / DC cable is bad not allowing the computer battery to charge
Verify that the AC and or DC cable is not bad by testing the computer only with the power plug connected and the battery out of the laptop.
2.- Battery is bad
It is possible that if the power plug is good that the computer battery is bad. Leave the computer connected to the power with the battery connected in the computer for at least one hour; if the battery does not charge, consider having the battery and/or the laptop serviced or repaired.
If the computer and/or battery is not in warranty consider just replacing the battery as it is very likely that it is just a bad battery.
3.- Battery charger board is bad
If the battery has been replaced or an alternate battery from an alternate identical laptop does not work in the computer, it is likely that the power or charger board within the laptop is bad. It is recommended that the laptop be serviced or repaired.
Posted on Nov 19, 2008
The power cord is a weak spot on these computers. Borrow one from a friend with the same computer and see if it works.
If it does replace yours with a new one.
Posted on May 29, 2009
Battery not charging, need to find extra voltage load?
Hi gelly, unless the battery you have purchased just happens to be faulty (can you test with another) then i would suggest that the mainboard is faulty (charging circuit is not working as it should) and unless you are good with a diagram & soldering iron i would recommend taking to a good local tech. Hope this helps.
Feb 07, 2014 | ASUS 1025C-BBK301 Eee PC Netbook Computer...
Wiring diagram battery pack aspire 5580
Are you asking for the wiring diagram inside the main Battery?
If so, due to very possible injury, or death to you, there will be No solution.
Now, if you are talking about what is the polarity for the plug of the AC adapter, (Charger), that plugs into the DC Power Jack on the laptop, (DC _IN), then I'm on board.
The Center Hole in the plug end is the Positive ( + ) connection.
This is where the Positive (Red) probe lead of the multimeter goes.
The cylindrical outside metal shell is the Negative connection.
The Negative (Black) probe lead of the multimeter touches here.
Voltage is 19 Volts DC.
Wiring diagram for the inside of the AC adapter itself?
No gottom.
Regards,
joecoolvette
Oct 22, 2012 | Acer Aspire 5580 Notebook
Samsung n145 will not power up
Related to a Samsung Np-n145 Notebook PC:
Plug the laptop into power for 24 hours. See if the Battery charges up.
Next test, or have tested, the AC adapter (Charger) See if it is putting out 19 Volts -> DC.
Know someone with a multimeter? I can guide you in testing.
AC adapter is good? Things go downhill rapidly here.
The next problem could be a DC Power Jack.
The DC Power jack is the jack on the laptop, that you plug the AC adapter into,
1) The DC Power jack may be broken
2) The solder joints holding it to the motherboard may be cracked. Poor connection to motherboard.
The DC Power jack can be replaced, or it's solder joints re-soldered.
DC Power jack proves to be okay?
Power MOSFET's have gone bad. The next link, is an article that deals with bad Power MOSFET's in an HP laptop. Used for an example,
http://mayohardware.blogspot.com/2010/04/important-parts-on-dv6000-and-dv9000.html
Let's hope it's a bad AC adapter
Regards,
joecoolvette
Jul 18, 2012 | Samsung Notebook Np-n145 10.1" Laptop...
Mother board power slution
Change power supply to get rid off from problem
May 12, 2012 | Compaq Presario CQ61 Series Laptop Charger...
I need hp pavilion dv7 1240us motherboard power problem solution..i have allready check dc jack,battery,power cord..and i soldring dc jack,battery jack..please some body help me... plz give me this...
I am not exactly sure what is the problem. Are you certain it is a power problem with the mother board? It could also be damaged or non functional.
Here's a troubleshooting guide from HP that might help you.
and the product's manual:
May 22, 2011 | HP Pavilion dv7-1240us Notebook
Dc jack of labtop getting vey hot
A common weak spot on most laptops is the DC power jack. If someone trips on the wire while you have the power adaptor plugged into your laptop, chances are that the power jack will get damaged.
On most laptops the DC power jack is soldered directly to the motherboard and there are only three or four small pins holding it in place. Unfortunately that makes the power jack quite weak. Any sideways pulling of the DC power cord while attached to the laptop will usually dislodge at least one of these pins, breaking the solder around it. Modern laptops use quite a lot of power, from about 70W to 120W or even more. The bad electrical connection from the dislodged pin will cause sparks and heating that will eventually burn a hole through the motherboard and can even be a fire hazard.
The usual signs of that are:
  • The battery is not charging properly or stays at half charge despite that you have been using the power adaptor.
  • The screen flickers (the brightness is changing) while the power cord is plugged in. This is caused by the laptop switching between DC power (screen is brighter) and battery power (screen is dimmer).
  • The DC plug gets hot after a few minutes of use and may even smell of burning.
  • There are "scratching" sounds coming from the DC jack.
You need to take the unit apart and check/resolder the DC jack on the system board.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
Feb 15, 2011 | Computers & Internet
My batteri is not charging at all, i can only use my laptop with direct power connection. Pls give me s slution.
the conector AC into the LAP TOP probabily is broke, check this shake the cable and check the battery icon , if not chane the batery
Aug 05, 2010 | Gateway LT2021u Netbook
Repair Diagram DC Power Jack replacement Sony FE770G
Hi Chris,
I found this page that hopefully may haelp you.
It has pics, and how tos, etc.
http://repair4laptop.org/disassembly_sony.html
Hope this helps,
Karlos
Jul 04, 2009 | Sony VAIO VGN-NR385E Laptop
Will not boot up
I have seen a lot of Toshiba Laptops with bad "DC Connectors" on the motherboard. It sounds like you know what your doing so here a link on how to disassemble your laptop.http://www.irisvista.com/tech/laptops/ToshibaM2/tecra_M2_disassembly_1.htm
and here is another on how to repair the dc connector. http://www.laptoprepair101.com/laptop/2006/05/27/failed-laptop-power-jack-workaround/
May 27, 2009 | Toshiba Tecra M2-S530 Notebook
Dell Laptop Battery Charer
Or it could be a broken/damaged power pin that is causing the problem. Every time you tug or pull on the pin it causes damage...eventually it doesn't work at all. When you get it fixed you need to invest in a CRD (Cable Retention Device) like shown here. . .
Jan 25, 2008 | Dell Inspiron E1505 Notebook
Compaq Presario 700 470024-192 Notebook Logo
266 people viewed this question
Top Compaq Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
