Question about Toshiba MD20H63 TV
My Toshiba television, MD20H63, will not turn on anymore.
I have a Toshiba television, model number MD20H63that on Monday just stopped turning on. When I press the power button,whether it is on the tv itself or on the remote, the power light willturn and it will make a noise but then after about 1 or 2 seconds itjust shuts off. I tried removing the cable cord and then putting it back and that did not help. I also moved the plug that the tv was originally plugged into and that also did not work.
  • Anonymous Mar 15, 2009
    I have this exact same problem, precisely as described, also with the Toshiba model MD20H63. Once in a while if I hit enough buttons and hold them down I can get a glimpse of a station for a split second before the entire TV shuts itself off. More often, all that happens when I turn the set on is that the power light illuminates for a second or two but nothing comes up on the screen; then the TV turns off. The TV is only a little over a year old and has gotten relatively minimal use - on average, 3-6 hours a week.
andyroid85
  • 7 Answers
SOURCE: Toshiba 32A32 won't turn on
just fixed one with that problem it was the vertical output ic Q301
that was shorted. try wicking it out. it is a LA7833S.
Postings say to be sure to use the Toshiba part
Posted on Aug 28, 2008
snakehead
  • 1074 Answers
SOURCE: TV does not turn on; red light blinking.
your problem is a more technical problem you will need a tech to look at your set if you are not a tech you wont be able to do it your self. contact a tech to repair your set the problem is in the power supply or related circuit.good luck.
Posted on May 02, 2007
MrScary66613
  • 1990 Answers
SOURCE: remote control not working
Welcome to Fixya! This sounds like the Recieving Mechanist inside the TV is Faulty and needs to be replaced by a Service Center.
Posted on Jan 02, 2009
pgh_pa_guy
  • 2992 Answers
SOURCE: Our daughter gave us a Toshiba TV and remote. We
If the remote is the original Toshiba remote, it obviously should work the TV. Have you checked to make sure it has good batteries? Also, if old batteries leaked in it at any time there may be corrosion on the battery contacts keeping it from working. Make sure the metal contacts look shiny, not crusty and corroded.
If the remote still doesn't work there are two possibilities. One is that the remote is just bad. You can get a universal remote, set it for Toshiba and try it. It will at least control power, channel and volume functions. If the universal remote doesn't work, the remote sensor in the TV would be the probable cause. Like any other part, they can sometimes fail.
Posted on Apr 11, 2009
rulds2008
  • 3866 Answers
SOURCE: the tv suddenly shuts off
flyback on the verge of giveing out on you.. needs a new flyback..
Posted on Apr 22, 2009
What is the dish network code for second TV TOSHIBA MODEL NO.MD20H63
If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the relative post easily.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
May 03, 2015 | Toshiba Televison & Video
Which streaming device and antenna should I buy after I dump cable?
That depends on where you are, what you want to receive.
Nov 18, 2014 | Toshiba MD20H63 TV
Toshiba 50HP66--can't change channels anymore
Have you tried to unplug set for a while and turn back on?
If that does not help contact Toshiba to see if common problem on this model and if any possible software upgrade is available for this problem.
If still no luck someone will have to examine it and decide which board is causing this and replace it.
Mar 22, 2012 | Toshiba 50HP66 50 in. Plasma Television
Toshiba model 34hfx84 turns on for a couple of seconds then turns off then red power light blinks and does not not stop blinking
Your television probably has problem on power supply.. some television sets has its own Power on Delay (P.O.D.) on power supply circuits., thus to protect your equipment for severe damage.. please contact a certified technician to repair your unit.. hope this help
Sep 16, 2011 | Toshiba 34HFX84 34" TV
Hi, our toshiba rear projection tv will turn on but no picture. whats the problem? thanks
MODEL NUMBER 56H80 TOSHIBA PROJECTOIN TV,PICTURE IS NOT COMING AT ALL
WHATS THE PROBLEM
Feb 04, 2011 | Toshiba 57H81 57" Rear Projection...
My toshiba 36in crt tv's demo mode keeps turning it self on
Since I do not have your tv model number so can't be specific, check Demo mode option in Menu and turn it off. Some tvs have selection like Store/ Display and Home mode, store or display mode is demo mode so set tv on home mode to turn off demo mode.
Let me know model number of your tv if you have additional question.
Thanks.
Jul 22, 2010 | Toshiba Televison & Video
TV turns it self off, after a few seconds of being on.
This television has had a problem with component failure. It turns on and then when it turn off it is going into protection mode to prevent further damage. The circuits in the television will go into this mode when they sense unusual voltage or current levels in the circuits. This television need to be tested for faulty component operation. The Customer support telephone number for Toshiba is 1-800-631-3811. Call them and give them the model number of your television and ask them where the nearest authorized service center is and for a telephone number. Give them a call and ask them how much they charge to estimate repairs for your model television. They should be able to help you. Then you can evaluate whether not it is worth repairing or replacing. I hope this information helps you with your problem.
Jun 09, 2009 | Emerson EWC19T3 19 in. TV/VCR/DVD Combo
I have a sony tv and it will not turn on anymore. The red light flashes 9 times and stops and then repeats. This tv is only 3 years old. Please help.
I will need the model number for your sony to diagnose the blink code as different models have different codes. Please respond to this same post when replying.
Jul 31, 2008 | Televison & Video
Toshiba MD20H63 TV Logo
85 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
