Question about Logitech X-230 Computer Speakers
No Problem, Just curious at how to open the sub box.
I just want to know how to open the sub woofer box so i cn see inside it at all the mumbo jumbo etc. I tried my self but it proved to be difficult as i dnt want to break it open. I tried the back input panel but the circuit board was either hooked on something or the wasnt enough slack in the wires inside. Can anyone help :)
    Genius:
  • 2,985 Answers
It is made so as no fumbling fingers can't get at it There are no user serviceable parts there in So leave it alone.
Posted on Jul 24, 2007
I opened mine, here's a description: http://users.tpg.com.au/malydog/fixits/logitechx230.htm
Posted on Aug 14, 2007
  • malydog Aug 14, 2007
    Sorry, I didn't read properly, you want to open subwoofer not speakers... I opened the subwoofer, it was easy. Just unscrew the screws off the panel and firmly but gently pull it out. It feels like it won't fit through the hole but it does.
Malfunctioning. wont print documents or pictures. Just some kind of jumbo mumbo. like; @PJL SET REPRINT=OFF, @PJL SET HOLD=OFF....etc.
That "mumbo-jumbo" is the printer code. It may well be that you either have the wrong driver installed for the printer and it is misinterpreting the code, or the driver may be corrupt and needs to be reloaded.
Nov 04, 2015 | Epson WorkForce Pro WF-4630 Wireless Color...
Tip
Box specs and airspace for 8 inch subwoofers
<span>Regardless of your wattage rating on your sub woofer, sub woofers</span> differ in only one way. You get an "Open Air" and a "Closed air" <span>Sub woofer</span>, That being said, you'll have to check on your magnet which one you have, to make the boxes for that particular sub woofer. If it is an "Open air" <span>Sub woofer</span>, you should see a hole with "wire mesh" or "metal grid" in the center, at the back of the magnet. If it is a "Closed air", the magnet will be solid with no hole whatsoever.<br /><br />If it is a "Open air" sub, your boxes should always be sealed with silicone sealant, and no ports are to be cut in your box.<br /><br />Regarding the "Closed air" <span>sub woofers</span>, you should have 2 ports cot in the corners of the boxes just below your sub on the face of the box, and the port sizes should be around 50mm in diameter. Get yourself some 50mm PVC drain piping to use as ports. Firstlycut yourself a 100mm piece and insert flush with the front of the box. Test your sound. then try a 150mm piecs and test again. You should start with a 100mm long piece in the one box and add 50mm increments to "tune" the port up to 250mm, depending on the frequency of bass you require. Carry on testing the sound on each increment until you find the sound you want, Then silicone the port to the box for permanent fixing.<br /><br />On a 15 inch <span>Sub woofer</span> ranging between 80Hz and 100Hz, the ample box size required should be a box of 9 inches high, x 9 inches wide, x 9 inches deep. Or 400mm high, x 400mm wide, x 400mm deep. <br />Enjoy! <br />
on May 29, 2011 | Car Audio & Video
Tip
Box specs and airpsace for 12 inch subwoofers
<span>Regardless of your wattage rating on your sub woofer, sub woofers</span> differ in only one way. You get an "Open Air" and a "Closed air" <span>Sub woofer</span>, That being said, you'll have to check on your magnet which one you have, to make the boxes for that particular sub woofer. If it is an "Open air" <span>Sub woofer</span>, you should see a hole with "wire mesh" or "metal grid" in the center, at the back of the magnet. If it is a "Closed air", the magnet will be solid with no hole whatsoever.<br /><br />If it is a "Open air" sub, your boxes should always be sealed with silicone sealant, and no ports are to be cut in your box.<br /><br />Regarding the "Closed air" <span>sub woofers</span>, you should have 2 ports cot in the corners of the boxes just below your sub on the face of the box, and the port sizes should be around 50mm in diameter. Get yourself some 50mm PVC drain piping to use as ports. Firstlycut yourself a 100mm piece and insert flush with the front of the box. Test your sound. then try a 150mm piecs and test again. You should start with a 100mm long piece in the one box and add 50mm increments to "tune" the port up to 250mm, depending on the frequency of bass you require. Carry on testing the sound on each increment until you find the sound you want, Then silicone the port to the box for permanent fixing.<br /><br />On a 15 inch <span>Sub woofer</span> ranging between 80Hz and 100Hz, the ample box size required should be around 27 liters, meaning that you will end up with a box of 13 inches high, x 13 inches wide, x 13 inches deep. Or 400mm high, x 400mm wide, x 400mm deep. <br />Enjoy! <br />
Legacy 1000w 2 channel amp worked awesmoe then just stopped working after a few songs. Didn't turn up too loud. Didn't have the settings too high. still getting power (amp light on, led lights...
Open your speaker box up most likely the jumper from the inside of the box to the subwoofer itsself is broken free, Usally when they have lights around the sub woofers there seperate leads, bet 10-1 you have loose wires inside the speaker box
Mar 25, 2013 | Legacy Audio ICON LA2770BK 1000W 2-Channel...
Tip
Box size and airspace for 10 inch subwoofers
<span>Regardless of your wattage rating on your sub woofer, sub woofers</span> differ in only one way. You get an "Open Air" and a "Closed air" <span>Sub woofer</span>, That being said, you'll have to check on your magnet which one you have, to make the boxes for that particular sub woofer. If it is an "Open air" <span>Sub woofer</span>, you should see a hole with "wire mesh" or "metal grid" in the center, at the back of the magnet. If it is a "Closed air", the magnet will be solid with no hole whatsoever.<br /><br />If it is a "Open air" sub, your boxes should always be sealed with silicone sealant, and no ports are to be cut in your box.<br /><br />Regarding the "Closed air" <span>sub woofers</span>, you should have 2 ports cot in the corners of the boxes just below your sub on the face of the box, and the port sizes should be around 50mm in diameter. Get yourself some 50mm PVC drain piping to use as ports. Firstlycut yourself a 100mm piece and insert flush with the front of the box. Test your sound. then try a 150mm piecs and test again. You should start with a 100mm long piece in the one box and add 50mm increments to "tune" the port up to 250mm, depending on the frequency of bass you require. Carry on testing the sound on each increment until you find the sound you want, Then silicone the port to the box for permanent fixing.<br /><br />On a 10 inch <span>Sub woofer</span> ranging between 80Hz and 100Hz, the ample box size required should be around 26 liters, meaning that you will end up with a box of 11 inches high, x 11 inches wide, x 11 inches deep. <br />Enjoy! <br />
JVC Sub-Woofer
Well, sort of. It's part of a typical JVC shelf system. The gray and blue are for the left woofer and the red and black are for the right woofer. It's basically just two small "woofers" in a box. So unless you have a small amplifier that has 2 subwoofer outputs with a built in crossover, they are essentially useless.
Aug 04, 2008 | Audio Players & Recorders
Logitech X-230 Computer Speakers Logo
1,938 people viewed this question
Top Logitech Audio Players & Recorders Experts
Paul
Marvin
Marvin
Are you a Logitech Audio Player and Recorder Expert? Answer questions, earn points and help others
