Question about Onkyo TX-LR552 6.1 Channels Receiver
DVD/TV Problem with TX-LR552
A few nights ago I stuck a DVD in my Onkyo DV-CP702. My TX-LR552 was on the DVD setting. The dvd had no sound, no matter what I did. FM had sound on FM setting, TV had sound on TV setting, etc. When I turned the receiver to the TV setting my DVD had sound. If I fast forwarded the dvd, the receiver would automatically switch to the DVD setting, but again, there was no sound. Any ideas? Thanks, Norm
    Master:
  • 589 Answers
Did you change your TV input to DVD as well?
Posted on Jul 27, 2017
SOURCE: Onkyo receiver playing in mono only
sounds like a reception problem. Is there a visual meter for the reception? Check your antenna.
Posted on Feb 02, 2007
  • 14 Answers
SOURCE: Onkyo TX-SR705 Muting Problem
if what Dark_Orbit said does not work try doing a master reset by ressing and holding the dvr/vcr button and stand by button simultaneously. This would erase all your assignments so you would need to reassign all your sources hooked up to your onkyo.
Posted on Mar 05, 2009
MNfisherman
  • 11896 Answers
SOURCE: Onkyo TX-LR552 was working great until I hooked up
Could be a couple things.
1. The system has a safety feature that cuts out when to much voltage runs through input/outputs
2. The audio ouputs have fried and will need all new capacitors installed.
Posted on May 10, 2009
buffalonyman
  • 1865 Answers
SOURCE: Does The Onkyo TX-8210 take a slow blow or fast
slow blow (aka time delay) fuses are used in motor circuits. Electronic devices use normal or fast blow fuses
Posted on Oct 02, 2009
mlapres
  • 757 Answers
SOURCE: Onkyo TX-SR601 6.1 Channels...dialog norm -3 readout
Enter the menu for speaker levels, and increase the center channel.
Posted on Dec 07, 2009
Have lost the remote control to onkyo dv cp702. Would like to access the random option.
You can get a substitute remote (the original remote is no longer available) at
http://www.remotes.com/remotes/servlet/rs?a=gmi&uuid=13118717212490&smodel=DVCP702&brand_pn=ONKYO_DVCP702
Let me know if you have any other problems or questions.Please rate this solution. Thanks.
Jul 28, 2011 | Onkyo DV-CP702 DVD Player
Displaying an error message "mecha
http://www.fixya.com/support/t4093524-onkyo_dvd_changer_display_reads_mecha
http://www.fixya.com/support/t1119443-onkyo_dv0_cp702_error_mecha_err
These may help you.
May 07, 2011 | Onkyo DV-CP702 DVD Player
I hooked up our Onkyo TX-SR607 system a few weeks ago and have watched several movies, but now I cannot get the Hitahci PH35811 TV to sync up to get video. I get audio, but no picture when we try to watch...
Are you routing the video into your reciver from the dvd player? If so route the video directly into your tv. It won't fix the initial problem but you will get picture and sound to watch dvd movies.
Feb 13, 2010 | Onkyo TX-SR607 Receiver
Onkyo TX-LR552 was working great until I hooked up the tv to act as a set of speakers. It cut off and now won't cut back on. We've unplugged it for a day and still nothing....
May 10, 2009 | Onkyo TX-LR552 6.1 Channels Receiver
We cannot get a disc out of a DVD player Onkyo CP702?
What is the model number of your DVD player?
Nov 30, 2008 | Onkyo TX-SR605 Receiver
Shuts off after a loud sound
Hmmm...not sure but sounds like the vibration from the loud sound is causing the disk to jump. Not sure why that would power it off, but I think your thought to junk it sounds reasonable.
Dec 24, 2007 | Onkyo DV-CP704 DVD Player
No audio
Most of the time its the amps that are bad and need changing. This will be transistors on heatsink in the reciever. Part number should be on the amp.
Sep 19, 2007 | Onkyo TX-DS494 Receiver
DVDs presumed stuck and the player won't eject
Hi, If you feel comfortable opening the unit, then you may remove the top cover normally held by 2 - 4 screws. The tray should be visible and most units have a locking bar right at the center to hold the discs down. Removing this (2 screws normally, 1 at each end of the bar) would expose fully the tray with the 2 discs on top. Remove the discs and put the locking bar back with the screws. You can test the unit without the top cover. Please be reminded about safety precaution when working with active/live units and laser equipment. Power it up and check if the "mech err" still shows. If not you're set to cover it up, otherwise, your probably better off seeking the services of a qualified technician. This is a generic method which normally should apply to most CD/DVD units. Good luck and kind regards.
Aug 19, 2007 | Onkyo DV-CP702 DVD Player
Onkyo TX-LR552 6.1 Channels Receiver Logo
81 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
