Question about VisionTek Computers & Internet
ATI Radeon X1550 256 PCI is not recognizable
When I install the plug and play recognizes the cars as a PCI bridge. If i restart the system (Dell Optiplex G260/xp) the D diagnostics light on back turns orange and system will not boot
  • 849 Answers
May be card problem, replace it.
Posted on Nov 20, 2008
My wifi will not use my wifi router after upgrading ubuntu to ver 11.10 it worked before and i can use different wifi routers lspci 00:00.0 Host bridge: ATI Technologies Inc RS690 Host Bridge 00:01.0 PCI...
first make sure your wireless adapter is not disabled you can check it by running rfkill list in terminal if it is type sudo rfkill unblock wifi [second you can try activating and deactivating by typing sudo ifdown wlan0 and sudo ifup wlan0 me personly have kept to 10.10 the 11.04 seem to have a few glitches you can also check for additional drivers
Nov 27, 2011 | Canonical Ltd. Ubuntu
Hello, have Vista Home Basic. I just installed a Sapphire Radeon 7000 - Graphics Adapter - Radeon 7000 - PCI - 64 MB Problem: When I plug the monitor into the Radeon 7000, I get a black screen. If I...
Does the box say it is supported? These new 64-bit systems are still just getting going.
I tried xp64 but switched back because most of my hardware would not work.
Did it ever work? again alot of stuff is done with the 64 bit opsys.
Go into the bios, and make the new board the primary display.
In my experience, ATI needs to be primary. Just switch to PCI Primary.
If you haven't done this yet, you probably need to uninstall the software, too.
so it can setup correctly.
please rate this answer
Aug 10, 2011 | ATI RADEON 7000 PCI Graphic Card
Dell dimension 5100
If you are having problems with your video card
the drivers might not be installed correctly you might have to uninstall the graphics card restart your computer then reinstall the graphics card and its drivers
If your computer came with a motherboard disc the drivers could be on it
Click start control panel administrive tools computer management device manager scroll to display adapters + to expand you might see a yellow question mark ? or exclamation mark ! or a red x right click select reinstall drivers or
you might need to download one
http://download.cnet.com/video-ati-ati-radeon/3000-2108_4-175861.html
This package supports the following driver models:
  • 128MB ATI RADEON X600 SE
  • 128MB ATI RADEON X600 SE Secondary
  • 256MB ATI RADEON X600
  • 256MB ATI RADEON X600 Secondary
  • RADEON X300 SE 128MB HyperMemory
  • RADEON X300 SE 128MB HyperMemory Secondary
  • RADEON X300 Series
  • RADEON X300 Series Secondary
  • RADEON X600 256MB HyperMemory
  • RADEON X600 256MB HyperMemory Secondary
  • 128MB ATI Radeon X1300
  • 128MB ATI Radeon X1300 Secondary
  • 256MB ATI Radeon X1300PRO
  • 256MB ATI Radeon X1300PRO Secondary
  • ATI Radeon Xpress 1100
  • ATI PCI Express (3GIO) Filter Driver
Hope this helps you
Aug 07, 2011 | Dell ATI RADEON X300 SE, (128 MB) PCI...
Suitable agp for playing gta 4
The AGP slot on this system is 4X
The two cards that were tested on this from Dell are
ATI 64MB Radeon VE 7500 ATI 32MB Radeon
The maximum card you can connect to the system any PCI video card not more than 128 MB. As the motherboard and the power supply would not support it
Thanks
Proton
May 25, 2010 | Dell OptiPlex GX260 PC Desktop
I can't get my board to recognize my ATI Radeon x300 se in the pcie pnp will not even recognize it.
You must enter the bios menu and set the video controller to boot to the PCIe first. Save and exit the bios. The proper orders when installing a PCI-E card is as follows; before you install you’re new video card onto the motherboard. Install the graphics cards software. Than shut down the system. Install the video card. Boot system and enter the bios menu. Go to and open Advance.
Open North Bridge Configuration
See page 4-23 in manual.
Internal Graphics Adapter should be set to [PEG/PCI]
Internal Graphics Mode Select should be set to [Disabled]
PEG Port Control set to [Auto]
Save you're changes and exit the bios. You should be able to boot to you're PCI-E graphics card now.
Cheers'
Mike
Feb 05, 2010 | ASUS P5E-VM HDMI Motherboard
Hi I have an ATI Radeon HD 3650 x16 PCI-I installed in my desktop. It doesn't seem to recognize that I have two monitors plugged in. How do I do this? Thank you in advance
Go into Control Panel and choose the Display option in XP or Personalization option in Vista. Find Display settings.
Then check the Extend the desktop onto this monitor box to activate the 2nd monitor.
Oct 11, 2009 | ATI RADEON HD 3650, PCI Express Video Card
Will intel D101GGC support ATI Radeon 8500?
yes, before you buy video card
verify first the interface slot available on *********** board (AGP,PCI or PCI Express)
then select the video card with the same interface in *********** board
verify the video cards driver if compatible to your operating system
before installing the video card update your BIOS to latest version
Mar 20, 2009 | ATI RADEON 8500 Graphic Card
Upgrading Graphics accelerator
Not every computer is the same, but many times you can disable your integrated graphics by going into the BIOS setup and disabling the onboard graphics. This is not necessary, even if you plan to upgrade.
http://support.dell.com/support/edocs/systems/opgx110/ens/ug/specs.htm#expansion_bus
when i read the system specs it says it only has PCI expansion slots. I regret to inform you your computer is very limited in its ability to expand, basically you will not be able to upgrade to render graphics for more 3d applications especially newer games. you need at least one AGP port or PCI Express. However if you absolutely want the best available for PCI you can purchase a RADEON 9000 PCI edition. It can handle most older 3d games or apps and it will work on your computer. All you have to do is plug it in to any PCI slot and install the software that come with the device, and voila.
http://www.amazon.com/ATI-Radeon-9000-64MB-Video/dp/B001339YIC
For newer 3d apps and games you will have to purchase a new system.
Dec 30, 2008 | Dell OptiPlex GX110 PC Desktop
How to enable Crossfire with my two ati radeon x1650 graphic card
You need two pci-e slots. Put the cards in the slots. The cards connect with a crossfire bridge. Then just plug your monitor in and your ready to go. Make sure that you have the software installed and that your chipset supports crossfire. For more info click here.
Nov 17, 2008 | ATI RADEON X1650 Pro, (512 MB) PCI...
Computers & Internet Logo
163 people viewed this question
Top VisionTek Computers & Internet Experts
rafnix
rafnix
Computer Links
J John
Are you a VisionTek Computer and Internet Expert? Answer questions, earn points and help others
