Question about HP Officejet 5610 All-In-One InkJet Printer
Re: Setup Is it possible to get a manual to setup the volume on this equipment? everytime a fax is coming the noise is really loud. How can we lower it? I appreciate your help. thanks a lot.
  • lgonzalez610 Nov 19, 2008
    thanks a lot. I finally lowered the ring.
    Have a good one,
    absolutelly! I did it and thanks again for your good and quick response!
    havea good one,
  • 32 Answers
Here are the setup and user guides from HP. The info your looking for will be in here;
http://h10025.www1.hp.com/ewfrf/wc/manualCategory?lc=en&dlc=en&cc=us&lang=en&product=441125&
Posted on Nov 19, 2008
  • longinos guereca
    longinos guereca Nov 19, 2008
    Glad to hear to hear the problem is solved. How'bout you trow me a bone and select the 4 blue diamonds that indicate this issue was solved. Trying to make my way up to Master. Thank's.
Loud fax noises
Just press the Home button > Setup > Fax Setup > Dialing and Sending > adjust the volume.
Oct 25, 2012 | Lexmark OfficeEdge Pro4000 Inkjet...
When an incoming fax is arriving our fax at work is beeping very loudly, how do you turn it off.
Hello, it may be possible the the fax is in diagnostic mode or the ringer volume is turned up. 1) go to the administration tab on the control panel 2) go down to the initial setup 3) go to fax setup menu 4) go to fax receive settings 5) Check the ringer volume should be set to low (default) or to off for no sound. In the troubleshooting menu - set the fax speker mode to NORMAL (default). I hope this will assist with your problem.
Jan 13, 2011 | HP® LaserJet M5035 MFP Laser...
How do i turn up volume on hp officejet all in one
Adjust the volume
The HP All-in-One provides three levels for adjusting the Ring and Beep Volume and
the Phone Line Monitor Volume.
The ring volume is the volume of the phone rings. The beep volume is the level of
button press and error beeps. The default Ring and Beep Volume setting is Soft.
The Phone Line Monitor Volume is the volume of dial tones and fax tones. The
default Phone Line Monitor Volume is Medium.
To adjust the Ring and Beep Volume from the control panel
1. Press Setup.
2. Press 4, and then press 4 again. This selects Basic Fax Setup and then selects Ring and Beep Volume.
3. Press to select one of the options: Soft, Loud, or Off.
4. Press OK.
To adjust the Phone Line Monitor Volume from the control panel
1. Press Setup.
2. Press 4, and then press 5. This selects Basic Fax Setup and then selects Phone Line Monitor Volume.
3. Press to select one of the options: Medium, High, or Low.
4. Press OK.
Trust this is helpful. Please vote. :)
Dec 14, 2010 | HP Officejet 4355 All-In-One InkJet...
Hp8500 premier comes with wrong language on lsd
To fix this issue you can review your manual page 117 for the hp 8500. If you do not have the manual for your HP 8500 you can view it via the link below to assist you.
http://h10032.www1.hp.com/ctg/Manual/c01643304.pdf or
Under: Device control panel
• Language and country/region: Press Setup, and then open the Preferences menu. If you do not see your country/region, press 99, and then find your country/region in the list.
• Device control-panel volume: Press Setup, and then open the Preferences menu.
• Fax sound volume: Press Setup, and then select Fax Sound Volume.
• Automatic report printing: Press Setup, and then open the Advance Fax Setup menu.
• Set the dial type: Press Setup, and then open the Basic Fax Setup menu.
• Set up redial options: Press Setup, and then open the Advance Fax Setup menu.
• Set the date and time: Press Setup, press Tools, and then press Date and Time.
I hope this helps.
Oct 25, 2010 | Computers & Internet
A am not getting any sound when faxing or when faxes are coming through and my volume is on loud why is that.. I disconnected plugged it back in changed some settings and i still get nothing
Your HP all-in-one provides three levels for adjusting the ring and speaker volume. The ring volume is the volume of the phone rings. The speaker volume is the level of everything else, such as the dial tones, fax tones, and button press beeps. The default setting is Soft.
1 Press Setup.
2 Press 4, and then press 8.
This displays the Basic Fax Setup menu and then selects Ring and Beep Volume.
3 Press to select one of the options: Soft, Loud, or Off.
Note If you select Off, you will not hear a dial tone, fax tones, or incoming ring
tones.
4 Press OK.
Sep 15, 2010 | HP OfficeJet 7310 All-In-One InkJet...
How do I shut off the ringer on HP Photosmart Premier C309
Press the Setup button, go to Basic Fax Setup, scroll down to Fax Sound Volume, select Soft, Loud or Off. On ours, "Soft" is way too loud.
Dec 01, 2009 | HP Photosmart Premium C309A All-In-One...
Make the ringer louder I cant hear the phone ringing
Hello. From the User Guide:
1. Press Setup.
3. Press > to select one of the options: Soft, Loud, or Off.
4. Press OK.
1. Press Setup.
3. Press > to select one of the options: Medium, High, or Low.
4. Press OK.
For your reference, here is a link to the user guide:
http://h10032.www1.hp.com/ctg/Manual/c00644922.pdf
Thanks for using Fixya.
Sep 29, 2009 | HP Officejet 4355 All-In-One InkJet...
Hp j3680 fax/printer is loud
Press on Setup--> then scroll down and select Basic Fax Setup--> then scroll down and select Ring and Beep Volume and reduce it.
Apr 08, 2009 | HP J3680 Officejet All In One Printer
Ringer Volume
A little further clarification for all of those who had troubles finding it in the fantastic menu system on the 7210.
  1. Start by pressing the main setup button.
  2. Scroll to the Basic Fax Setup, and select it.
  3. Scroll to the Ring and Beep volume, and select it.
  4. Choose an option: Loud, Soft, Off.
Feb 17, 2009 | HP Officejet 7210 All-In-One InkJet...
L170 Canon Fax Sound and volume control issues
Sunds as though you have the handset that came with the machine attached to it and the handset ring volume is still on. To turn that off there are 2 black inset switches on the handset itself turn those down or off.
Apr 09, 2008 | Canon FAXPHONE L170 Plain Paper Laser
HP Officejet 5610 All-In-One InkJet Printer Logo
37 people viewed this question
Ben Johnson
