Question about Samsung HL-R5087W 50" HDTV-Ready Television
No External Audio sound
I attempted to connect a subwoofer to the external audio connection without an amplifier. I heard a loud pop and now I get no audio from the audio output jacks. Is there a fuse that could have blown? If so where is it?
You have to turn ON the Internal Mute for audio to be directed to the audio out jacks
Posted on Nov 20, 2008
Makes large thumping/chirping noise when turned on. Its not even connected to the receiver
Since you have said the speakers make this sound when "turned on", I'm going to assume there's some form of power amplifier attached (internal, external or otherwise). Based on the minimal information provided here, this simply sounds like the normal reaction of a speaker when the amplifier is turned on. In short, an audio speaker is a type of "transducer" and when power is applied (thru some form of amplifier), the cone reacts to the power surge and causes a thump, pop or other noise. Turn on your TV for example and you'll usually hear a small pop from the speakers...and a larger/more powerful amplifier is likely to make a louder noise. Without further information, in most cases this is quite normal.
Assuming there is an external power amplifier, my advice would be to turn the volume on the amp (regardless of whether there's a receiver connected) to 0 before turning the power on. If it still makes such a noise, it's possible the volume control of the amp may require cleaning.
Good Luck!
Apr 01, 2016 | Audio Players & Recorders
I want to connect external speakers to tv
If this unit has audio output jacks then these would be connected through an amplifier to provide your external speakers. Caution: Do not open the tv and connect additional speakers to installed speakers because you'll blow the small audio amp in the tv. I have seen this attempted many times
Dec 24, 2013 | Philips Magnavox 27MS343S 27" TV
Tv loses sound after around 45minutes of being swiched on
there may be problem in your amplifier or the mute signal or the input signal from processor or speakers, First you have to check the audio output from the processor by using another external amplifier... connect it to the correct audio out pin of processor( these are R,L audio written in pcb near the processor lead that carry) if there is sound moreover than 45 minute....... replace the external amplifier and connect it to its own amplifier.... disconnect the own cabin speakers and connect another sp. and check... if there is sound break after45 minute.... replace the amplifier ic(may beTDA7297) if there is still have the problem, check the amplifier circuite suitable for your ic and dissconnect the mute connection from processor and make a connection to the +ve or ground follows as the circuit(means give external mute signal to amplifier dont from processor)......
Nov 09, 2013 | Televison & Video
Crackling speaker as soon as i switch on my digital piano
It looks like the Korg c-15s has a internally mounted speaker and so I will assume that the speaker and amplifier are part of the piano base. It sounds like either the speaker is blown (crackling sounds heard as deformed voice coil scrapes the magnet structure) or the audio amplifier is distorting the audio.
Connect the piano's output to an external amplifier and speaker to properly identify problem.
Oct 17, 2012 | Korg Music
Good picture no sound
Hello
Check the speakers first. Get this set connected to an external audio amplifier device, such ans an amplifier or so, with its audio out connections at the back of the TV with audio in connections on the back of the amp, and listen whether you can see sound from the external amp. If you can hear sound from the external amp, and not with the internal speakers of your tv, either the speakers may have damaged or it audio output IC had got damaged. if so you have to replace the IC or should replace the audio card o your tV, if the IC is not available at local electronic spare part market.
If you can't hear any audio by external amp, as it has been connected as stated earlier, the mother board [main board] of your tv has the trouble. There is no repair to this digital board, and it should be replaced as card basis. OK.
Feb 08, 2012 | Vizio 42 in. LCD TV
No sound in my Toshiba laptop computer..but do get a loud noise when I turn up the volume...
Hello Sir, Hi, the loud noise means that the amplifier is working fine, the problem is the signal or the audio is missing. so check your cables (usually) or port connection (sometimes) and selector switch. update me of your progress.
Oct 17, 2010 | Emagic EMI 6|2m External Sound System
How to connect unpowered subwoofer to receiver with RCA sub out?
In order for this to work, you will need an external amplifier. Your receiver is set up to use a "powered" sub. With only speaker connections on the sub, it is a "passive" sub requiring a separate amp.
Dan
Dec 16, 2008 | Yamaha YST-MSW10 Computer Speakers
Subwoofer
check your earth cable. Connect your earth (black) cable elsewere.
Aug 05, 2008 | Jl Audio 250/1 Car Audio Amplifier
Problem no sound
If your KENWOOD unit is experiencing audio problems (NO Audio), but do have audio when TUNER is selected as the source, you may have problems with your installation.
NOTE: If using an external amplifier or the unit was installed using a separately purchased wiring harness for your specific vehicle, please check the following
If Using an External Amplifier
The P.CONT or REMOTE terminal on the external amplifier requires a “turn on” signal from the stereo. This terminal should be connected to the BLUE/WHITE P.CONT wire on the Kenwood harness and not the solid BLUE ANT.CONT wire.
If Using a Vehicle Specific Harness
The vehicle has a factory installed amplifier and requires a “turn on” signal from the stereo. Make sure that the BLUE/WHITE P.CONT wire is connected to the vehicle specific harness and NOT the sold BLUE ANT.CONT wire.
The solid BLUE ANT. CONT wire is used to trigger a power antenna ONLY when the tuner is selected as the source. Using this wire to “turn on” an external amplifier or factory installed amplifier will only allow it to work when TUNER is selected. Please refer to your instruction manual for proper installation. If you are not completely comfortable with installing the unit yourself, we recommend that you seek assistance from a professional installer.
Apr 10, 2008 | Kenwood KDC-MP438U Car CD/ MP3 Player
Open Questions:
Samsung HL-R5087W 50" HDTV-Ready Television Logo
119 people viewed this question
Henry  Thomas
Henry Thomas
