Question about Brother HL-2070N Laser Printer
Brother hl-2070n; Paper jams half way through drum unit.
The paper feeds half way through the drum unit when it stops...is about 1/8 through fuser.
help?
  • b_schmidt_76 Nov 19, 2008
    Wow! that was fast. thanks! Yes the paper stops at exactly the same spot every time. Any link to an image of the sensor?
  • Anonymous Mar 24, 2014
    how do you replace the fuser unit in a brothers HL 5470DW
    Scholar:
  • 130 Answers
Usually there is a sensor right before the paper enters the fuser. If the paper sensor is bad the machine will stop feeding and output the error paper jam. This is probably the cuase if the paper stops in the same position all the time.
Posted on Nov 19, 2008
  • Alvin Barnabas
    Alvin Barnabas Nov 20, 2008
    I am a certified Brother technician and I worked for a dealer in the past. Service/Parts manuals are only distributed to authorized service centers. If you call 404-377-1848 and ask for Jim Regert, he might be willing to research the part and ship it to you, he runs an authorized Brother Service center in Decatur GA. Tell him a former technician from Buckhead Office Machines referred you. My initials are AB.
  • 57 Answers
Hi b_schmidt_76
this problem occures from the sensor found in the outgoing of the paper, check all sensors.
hope this helpful for you,
thanks
Hamedo
I have a HL-2070N printer and it would not print, the Paper light is red and blinking. Also, sometimes when it prints the pages get stuck half way out. Any solutions? Thank you.
Usually there is a sensor right before the paper enters the fuser. If the paper sensor is bad the machine will stop feeding and output the error paper jam. This is probably the cause if the paper stops in the same position all the time.
The error light is simply telling you that there is a paper jam. Open both the back panel (you should be seeing the orange roller clearly) and the front panel. Grab the handle and take out the toner and drum and check there are papers stucked. Chances are there will be.
Thank you for using Fixya!
Dec 04, 2010 | Brother Office Equipment & Supplies
My Brother HL 5250DN printer has started making a loud clicking sound when it tries to feed paper for printing. It then stops and the paper light starts flashing.
Clear the jammed paper as follows.
Observe Cautions signs in printer.
Always remove all paper from the paper tray and straighten the stack when you add new paper. This helps prevent multiple sheets of paper from feeding through the printer at one time and prevents paper jams.
1. Press the cover release button and then open the front cover.
2. Slowly take out the drum unit and toner cartridge assembly. The jammed paper will be pulled out with the drum unit and toner cartridge assembly.
3. Pull the paper tray completely out of the printer.
4. Close the front cover.
5. Pull the jammed paper up and out of the printer.
6. Open the front cover again.
7. Open the back cover.
8. Pull the tabs at the left and right hand sides toward you to open the fuser cover (1).
9. Using both hands, gently pull the jammed paper out of the fuser unit.
10. Close the back cover.
11. Pull the duplex tray completely out of the printer.
12. Pull the the jammed paper out of the printer or the duplex tray. Put the duplex tray back in the printer.
13. Push down the blue lock lever and take the toner cartridge out of the drum unit. Clear the jammed paper if there is any inside the drum unit.
14. Put the toner cartridge back into the drum unit until you hear it lock into place. If you put the cartridge in properly, the blue lock lever will lift automatically.
15. Put the drum unit and toner cartridge assembly back in the printer.
16. Put the paper tray firmly back in the printer.
17. Close the front cover.
18. Make sure that the Paper LED is now off and the printer is ready.
After clearing paper jam if noise persist printer may need a Repair Tech and parts replacement for broken or wore parts.
Dec 04, 2009 | Brother Office Equipment & Supplies
FUSER TROUBLE HL 2040
This is a paper jamb problem. There is a piece of torn paper stuck in the paper path that is stopping the printed page from exiting properly.
Sep 30, 2009 | Brother HL-2040 Laser Printer
Paper jammed in my 2070N printer & I don't know how to remove it
That machine doesn't have a release lever, you need to pull the paper out, as straight as possible trying not to tear it. There probably is a problem with your fuser, and it will need to be replaced. Even getting the paper out, it will probably jam again on the next print.
Jul 22, 2009 | Brother HL-2070N Printer
Paper jam
Please open the front cover and remove the drum to check the jam. If not in the drum, then check the back cover, open it to remove any jammed.
May 12, 2009 | Brother HL-2070N Printer
How do I remove paper from paper jam?
To remove paper pull the paper with both hands being careful not to tear the paper . If you're unable to pull it you may need to manually rotate the gears that feed the paper through the printer
Now reset the printer by pressing the power button in on state to turn it off and restart
again thats all just take care that you remove the tray carefully
Thanks and Regards
Paper is jammed half way out on HL 2070N model
open the rear access door and pull the paper backwards through it then firmly and smoothly pull the paper free ofrom the fuser. pull the paper straight. should be easy.
Apr 08, 2009 | Brother HL-2070N Laser Printer
HL-2070N paper LEd flashing
most likely a sensor is tripped, eiher it's stuck or there is something blocking it. the most likely place is in the fuser, back door where paper exits and geta hot. look closely you should see a black lever towards the middle of the fuser, it should be up
Oct 18, 2008 | Brother HL-2070N Laser Printer
Brother HL 2070N red paper light blinks but won't print.
Just fixed my printer issue, had the same problem, Would load 1 sheet, then jam, sometimes it won't pull the paper out of the tray, sometimes it would pull the paper to the toner area, but never into the toner, opening and slamming the paper tray while it attempted to load would usually work, but who wants to slam the tray 50 times? I was using Walgreens generic paper, 20lb, took some higher-quality 24lb HP paper and VOILA! It works every time! EVERYONE WHO IS HAVING THIS PROBLEM, CHECK THAT YOU ARE USING 24LB PAPER!!! Brother says 20-24 is acceptible, but sneaking one sheet of 20lb paper about 15 sheets down in a 20 sheet print job and it will stop at it every time, You can feel the difference, less like toilet paper and more like real paper.
24 LB PAPER! USE IT NOW AND THANK ME LATER!
Jun 27, 2008 | Brother HL-2070N Laser Printer
Non stop paper jams
I had this same problem. I finally noticied that the problem occurred consistently on the right side of the paper feed. I discovered that a little part along the right side of my drum unit (just inside the paper feed area) had disconnected and was loose inside the drum unit itself. Once this little part was placed back into it's rightful place, VOILA! Problem solved! Hope this helps!
Jan 22, 2008 | Brother HL 5140 Laser Printer
Brother HL-2070N Laser Printer Logo
1,139 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
