Question about Canon Speedlite 220EX TTL Flash
When using with canon rebel 2000. The batteries get hot
Due to shortcircuit. the flash is not working.
Please guide us , which part of flash is defective,or Provide circuit diagram.
  • ninad0604 Dec 27, 2008
    can you please provide us internal circuit diagram of Speedlite 220EX TTL Flash ??we are experienced electronic techician.
  • 22 Answers
Not enough info-
Does the unit not flash? What type and size of batteries are in use? Are there ant odors, smoke or popping sounds coming from the unit? Are the batteries rechargeable and if so dies the charger or batteries heat up during the charging cycle. WARNING! dO NOT USE IT IN THE CAMERA- A SHORT CIRCUIT IN THE FLASH CAN DAMAGE THE CAMERA. uNLESS YOU ARE AN EXPERIENCED ELECTRONIC TECHNICIAN- DO BIT OPEN THE UNIT AND POKE AROUND IN IT- EVEN SMALL PORTABLE FLASHES MAY CONTAIN LETHAL VOLTAGES AND CAUSE INJURY OR DEATH.!
Come back with the information for more help. Ed
Posted on Nov 19, 2008
  • Ed Shapiro
    Ed Shapiro Dec 27, 2008
    I do njot have this digram in my files. Check with the manufacturer to see if the have one published for service shops.
Can I use Speedlight SB-50DX with Canon EOS Rebel Xti
It is not possible to use the Nikon SB-50DX directly on a Canon EOS Rebel camera. The Nikon flash gun hot shoe contacts do not match the Canon hot shoe contacts.
You can use the Nikon as a slave flash gun with a PC flash cord that matches the Nikon's flash contacts then connect the end of this flash cord to a flash trigger. The Canon's flash can then trigger the Nikon flash gun via the flash trigger.
Dec 27, 2011 | Nikon Speedlight SB-50DX TTL Flash
I just Bought a Canon Speedlite 540EZ it will not fire in the hot shoe of My Rebel XTI are they compatible
No. The rebel, or any digital canon camera requires the use of the EX or EX II series flashes.
Jan 19, 2010 | Canon Speedlite 540EZ TTL Flash
Canon Rebel XS says it's busy
I can help you fix the BUSY Error or Error 99 of your Canon EOS Rebel XS.
Installation of this Canon EOS Rebel XS firmware version 1.06 update will solve these problems:
  1. Some cameras may exhibit a phenomenon in which the LCD monitor does not display, the shutter does not release, and the BUSY indication remains lit in the viewfinder.
  2. The message, "Err 99 Shooting is not possible. Turn the power switch to<OFF> and <ON> again or re-install the battery", appears on the camera's LCD monitor, and after the above operation is carried out,the LCD monitor displays in a language that is different from the actual language setting.
See the firmware instructions and download the firmware upgrade by following these Fixya Tips :
  1. Follow this link to download a pdf version of the firmware installation instruction guide.
  2. Follow this link to download the Windows Version of the Canon EOS Rebel XS / Canon EOS 1000D firmware version 1.06 update.
  3. Follow this link to download the MAC version of the Canon EOS Rebel XS / Canon EOS 1000D firmware version 1.06 update.
  4. Follow this link to download the Canon EOS Rebel XS / Canon EOS 1000D Instruction Manual.
I hope that helps.
May 29, 2009 | Canon EOS Digital Rebel XS / 1000D IS...
Err 99 on canon rebel xt 350 d
The Err 99 problem occurs due to dirty contacts between the body and the lens. I recommend cleaning the contacts. You can then turn Off the camera and then remove and reinstall the batteries to reset the camera to get the problem fixed.
Jan 15, 2009 | Canon Rebel XT / EOS 350D Digital Camera
Switch from film to digital cameras.
I also own a Vivitar 285 that i used with my Canon F1 manual 35mm camera. Most older cameras before the advent of digital, had a hot shoe on top of the camera, or like in my case, the hot shoe went over the rewind knob. I also had to plug in a power cord from the 285 flash foot and the cameras PC connection in order for the flash to work on some other cameras. The Canon Rebel XTi has a TTL (through the lens) hot shoe usable with Canon's own EX flash units. You can buy a "hot shoe to PC connector" if the TTL camera hot shoe doesn't work, but be extremely careful, the only problem that exists with the older manual flash units was the trigger voltage is as high as 200+volts which would fry digital camera hot shoes. I tried my unit with a Wein flash trigger device on the PC cord of the flash and my Canon D60 with it's own flash. All shots were overexposed and washed out highlights.  Here's a copy of the hot-shoe review:h The EOS 400D's hot-shoe can be used with Canon and third party flashes (although sync only on most third party units). The hot-shoe is E-TTL II compatible. Compatible flashes include Speedlite 220EX, 380EX, 420EX, 430EX, 550EX, 580EX, Macro-Ring Lite, MR-14EX, Macro Twin Lite MT-24EX and Speedlite Transmitter ST-E2.  The Canon Rebel XTi doesn't have a PC socket to plug in a manual flash trigger cord which common sense tells me there is no provision to step up the voltage to trigger manual flashes - so my answer is this combination is not a good idea on a Canon Rebel XTi. Hope this helps.
Dec 12, 2008 | Vivitar 283 Flash
Flash on a canon rebel 2000 eso
Just push the flash back and it locks ,...... thats flash off
Oct 14, 2008 | Canon EOS Rebel 2000 with 28-80 lens 35mm...
EOS rebel flash is not popping up
Looking at camera from the front, the flash hinge is on the right hand side. Mine was corroded (due to sea spray). I removed the two arms which limit the travel of the flash, MAKE SURE YOU KNOW WHICH WAY UP THEY GO AND ON WHICH SIDE! remove the three very small screws which hold the cover on the flash and remove the cover. Now you can ease the bearing our and clean with Iso-propyl alcohol. Do not oil!. Reassemble and ensure it moves freely.
Mar 10, 2008 | Canon EOS Rebel 2000 with 28-80 lens 35mm...
Rebel 2000 went retarded
I got a Rebel 2000 off ebay, and it had the same problem. The Shutter wouldn't open, it showed dead batteries, and the mirror hung until I pressed the shutter button or changed modes.
After a good deal of surfing, I found that the most likely reason was a sticky/oily shutter
(http://photonotes.org/articles/oily-shutter/).
Since I didn't have much $$$ invested in the camera, I tried cleaning the shutter curtain with Qtips and alcohol. After a little cleaning, the shutter started to move. After a lot of cleaning, the shutter moves freely. I ran a roll of film through it, and it seems to be working just fine now.
Feb 27, 2008 | Canon EOS Rebel 2000 with 28-80 lens 35mm...
Camera wont shoot in automatic modes
Have you removed the batteries for a few hours (reset) ?
Have you turned the dial around several times (clean contacts)
The only other error is the flashing battery light, if it persistes, according to the manual. It's dead as repairs would be pretty expensive against a newer replacement.
Feb 12, 2018 | Canon EOS Rebel 2000 35mm SLR Camera
Canon Speedlite 220EX TTL Flash Logo
117 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
