Question about Freezers
Ice/frost build up inside the freezer
Find frost build in my fridge/freezer and the temperature rise slightly.Please advise what causes this.Many thanks
  • 2 more comments
  • harishsudra Nov 20, 2008
    Thanks for the info.The model of fridge/freezer is Bosch KGU 3201GB.
    Thanks for that but any chance of parts number and where to look for it in the fridge.Info on service manual or circuit diagram would be great help.
  • alikapaka Dec 13, 2008
    My Maytag side by side also has ice build up inside the freezer also condensation on the outside on super humid days (I live in Hawaii) can I replace the parts myself or do I need a professional?
  • Anonymous Mar 31, 2009
    i have a side by side and the heaters tube went out how bad of a fix is this
  • 370 Answers
You have a defrost problem. The coils freeze up behind the freezer wall and the air does not flow properly. Replace the heater, defrost timer, and thermostat. get me the model number and i will give you the part numbers so you can order the parts.
Posted on Nov 19, 2008
  • Justin Duby
    Justin Duby Nov 20, 2008
    This is caused by either the defrost timer, Heater, Or thermostat failing. The factory says to replace all three at once. This way you will a new defrost circuit and then you will be good to go. I cant give you a reason as to why it happened. There are many reasons why it does happen.
  • Justin Duby
    Go to sears.com and click on the parts icon. Put in your model number and you will be able to pull up diagrams of the unit. You can find the part numbers and where they are located in one shot. You can also order the parts directly from sears also.
Where is the evaporator fan motor? My Freezer and fridge would quit cooling/freezing. I took the back panel off in the freezer a week ago and the evaporator coils were completely frozen over with ice. I...
I do not believe the problem is the fan. sounds like the frig. is low on Freon this is what will cause the ice build up. you need to find the leak, you can do this by spraying soapy water on coil tubes & watch for bubbles. repair leak & recharge.
May 25, 2015 | Samsung RS261MDBP Side by Side...
Is my defrost timer broken or my thermostat? The freezer was holding -30 temp but now is at +30.
Is the compressor running? If not - the timer could be stuck in defrost mode. If it is ruinning, then the freezer coil should be cold. If it is choked with frost & ice - then the defrost heater isn't getting powered (bad timer or defrost terminator - or is getting powered but has burned out.
You should allow the ice and frost to melt completely before turning back on again. Typically ice and frost don't build up so bad in a few days time to cause the temperature rise you're describing If getting cold - the compressor and refrigerant is likely OK, if not the defrost circuit is suspect. If compressor running but not getting cold - a refrigerant leak / charge level may be causing the problem.
May 18, 2015 | Arctic Air 22 cu. ft. Commercial Freezer...
Our Frigidaire frost frost free upright freezer from day one has frost build up on the food inside the packages. The frost is not a problem in the freezer itself, but on the food. Freezer burn occur
Hi Dale Dibb, thank you for your inquiry!
I understand that the food inside of your Frigidaire freezer is getting frost on the inside of the packages. I would recommend turning the temperature up inside of your freezer. Additionally moisture inside of the package would cause frost to develop on the inside of the food packages.
Please assure that all possible moisture has been removed out of the food packages prior to placing the items inside of the freezer. If there is anything else that I can help you with, please feel free to reconnect! -Matt
Sep 30, 2014 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Beko CDA543 F freezer always on?
noise sound like compressor mount are loose or rubber garment fell off that stops vibration or pump is bad internally call warranty get replaced if not a mounting problem of compressor
Mar 02, 2017 | Freezers
Hi i have a E5221 rt d fisher and paykel fridge freezer, freezer at top, the freezer always gets a build up of ice that collects on the slats and has a slightly swollen back wall witch seems to have ice...
try to clean the drain of your unit maybe it is clog up declog it to avoid drip. u said that ther is a build up of ice this means auto defrost not activate try to chek the defrost heater or defrost timer if have the unit this. or try to allign the door gasket possible theres a gap entry of outside air cause of build up of ice. bec it is came from moisture of air out side or avoid to much door opening.goodluck.
Feb 27, 2011 | Fisher Freezers
Major Appliance
It sounds like the thermostat is not sensing when the fridge/freezer reaches it's set temperature.This will result in the compressor running non-stop and this causes ice build-up inside the fridge.See on what number (0-7) the thermostat is set on.If it is set on 7,turn it down to 3 and see if it makes a difference.If there is no difference it means that the thermostat is not sensing & switching the compressor off.You will then have to replace the thermostat.
Regards
Andre Nagel
Mar 15, 2010 | Freezers
Frost buildup around the inside top of the door of an upright Frigidaire Commerical Frostfree Freezer Mod# FFU20IC8Cw2
This happens when your thermistor gets frozen along with the coils or there is a clogging of the freezer drain which causes Ice to build up and spread to the system. Another issue is that your thermistor may be faulty, telling the system inaccurate temperature. Incorrect freon pressure can also be a cause. I would advise first to have the ice melted by letting the unit stay unplugged and have it cleaned while at it.
Aug 11, 2009 | Frigidaire Freezers
My Bosch frostfree fridge freezer keeps icing up!
My Bosch Frost Free Fridge Freezer did the same thing - Ice forming in the bottom of the freezer area after a few days.
It was caused by a blocked drain pipe - When the freezer does the de-frosting cycle, the melted ice drips into a tray and tehn runs into a dish on top of teh compressor, through a pipe.
If this pipe gets blocked, the de frosted ice overflows from the tray and overflows into the bottom of the freezer and then re-freezes !
To fix, pull the freezer away form the wall, locate the pipe that runs to the dish on top of the compressor and blow through it - This should clear it. Alternatively, from inside the freezer compartment, pull off the cover at the back, but the clips holding it on will probably break off, as mine did ! You can sort of push the cover back on and re-fit the food draws.
Feb 23, 2009 | Freezers
Ice build-up
Defected DEFROST HEATER can cause frost build up on the panel at the back of the freezer,and freezer stop cooling and ice frozen on unit so air could not flow to refrigerator side.Water will coming out caused of unbalanced freezing,and causing the flooding of water in the floor. You must change this defroster heater assembly so it will works normal again..
Hope this may help;
Regards,
VOTIT
Sep 22, 2008 | Frigidaire 20 cu. ft. / 566 liter Upright...
Freezers Logo
1,069 people viewed this question
Top Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
AJMAL KHAN
Are you a Freezer Expert? Answer questions, earn points and help others
