Question about Panasonic CT-36D31 36" TV
High pitch sound
When I turn on my Panasonic 42 in standard tv, I get no picture or sound just a high pitch sound. When I try to turn off the TV using the main power button it will not shut of the high pitch sound. I have to disconnect the plug from the wall outlet to make it stop. The only thing that I have done so far was blowing the dust out of the TV with canned compressed air.
Hi Buddah! heres the solution for the high pitch sound on to your Panasonic TV,,just check if there are some SHORTED RECTIFIER DIODE on the power supply section,
Posted on Oct 25, 2008
  • 70 Answers
You say the set still works, if that is the case then you have no shorts at all. most ikely you have coil in the horizontal stage vibrating producing the same noise as you describe. removing the coil and dipping it into some clear laquer usually solves this.
It is also possible that you have a couple of caps in the hot side of the power supply that are low capacitance making the coil run harder than what it should.
Posted on Jul 07, 2008
    Problem Solver:
  • 17 Answers
Yes, shorts cause this. I have a lightning damaged sample of this unit that presented with the same symptoms. The horizontal output transistor and the diode supplying it with B+ (D823) were shorted, as was sacrificial shunt zener D830 in another section of the supply. I don't know what voltage this part is, but is has to be <25 because this the rating of the capacitor connected to it. I know better than to just leave this part out and plug the thing in. Especially since, with the HO transistor out of the circuit, the B+ is over 240 volts, EXTREMELY high, so something else is probably wrong with the power supply. I am still waiting for service literature (back ordered for over a month). If anyone knows any more about this design, (like how it regulates and how to check this) please post the information. Thanks. I will probably replace the known bad parts and hope for the best, but hesitate because I don't want to damage more parts if I guess wrong on the zener voltage. (In this case, this is merely a part designed to short if voltage ever gets too high). There is a possibility that the high B+ is because the supply is running unloaded and cannot regulate. But since I haven't seen this unit before, I can't tell.
Posted on Oct 17, 2007
  • acemoab Oct 18, 2007
    Someone sent me the schematic for this set. The problem was NOT lightning damage after all, but C820 (10MF/63V) which is the filter for the regulator reference voltage, gone bad. This took out D825, D830, and Q551. D825 is a general purpose fast switching 3A (similar to Thomson 164589) diode. D830 is an MA4270MTA, but you can use a 27V 1/2W zener, since this part does not conduct except in an overvoltage fault condition, then it merely shorts, as I stated in the last post. Q551 is the Horizontal Output, 2SC5339LBMA1, but this is not too critical. The B+ is NOT isolated from the power line so you measure it from the HOT ground.
    President:
  • 3,130 Answers
That high pitched sound is the switch mode power supply yelling out to you, telling you there is a major short in the circuit somewhere. Most likly thre horizontal output transistor is shorted, and as the other tech said , maybe the flyback transformer is bad also. Bad capacitors in the main power supply can cause this sound once in a while. Good Luck Please do not forget to rate this thread.
Posted on Dec 15, 2006
  • 81 Answers
Flyback, could be bad solder but I lean more to the flyback
Funai tv. When plugged in, makes ear piercing high pitched buzz that goes away when unplugged. Will not respond to buttons. No picture or power. Already replaced power board. What now??
TV not turning on; making high-pitched sounds - Tom's ...
www.tomshardware.com > Forum > Graphics Cards
Tom's Hardware Guide
Nov 30, 2013 - 7 posts - ‎2 authors
Both of them are refusing to turn on, and make high-pitched sounds when plugged in and unplugged. More about : turning making high pitched ...Missing: ear ‎piercing
Top 136 Complaints and Reviews about Funai TV ' Page 2
www.consumeraffairs.com > Electronics > Televisions
Rating: 1.1 - ‎65 votes
We unplugged the unit and waited 15 - 20 seconds and plugged the unit back in, and it wouldn't ... He heard a loud high-pitched whining which led him to TV in my daughter's room. ... It only makes a humming sound now, no pictures at all.Missing: ear ‎piercing
HELP! what is that high pitched noise when tv is on? - TV - Audio ...
www.tomsguide.com/forum/60895-6-help-high-pitched-noise
Jan 25, 2013 - 3 posts - ‎2 authors
Hello, I hear this constant high pitched noise, almost like ringing, but even ... pitch
Jan 21, 2016 | Funai Televison & Video
My tv powers on displays the LG logo then makes a high pitched squeal sound from speakers and then flashes on screen (strobe light effect) does not display picture or sound.
LCD TV Repair Tutorial - LCD TV Parts Overview, Common ...
? 11:05
https://www.youtube.com/watch?v=tS4sIpdajVw
Aug 23, 2013 - Uploaded by ShopJimmy.com
Repair review of common LCD TV Problems and Repair Solutions ... input the tv is set to it begins making a high pitched whiningsound. .... I have a LG 47LN5750 that powers on, flashes a good picture for about 1/2 second, then goes dark. ... hi my samsung tvis not turning on is black. and I just replace the ...
#Treat At Home high pitched whine from plasma tv Tinnitus ...
www.aspenridgerentals.com/tinnituscure/?...high%20pitched%20whine%...
LG 50PK540 plasma TV Repair power supply EAY60968801 Part 1-2 ... Sanyo DP42849 with high pitched squeal after replacing power supply. ... In my second daily fix video, I solve a mystery that was making me having to turn off my speakers before I went to be ... The flash is accompanied by an high pitched sound.
Dec 16, 2015 | LG 55LE5400 TV
I have a samsung neo 32 inch picture tube tv. When I turn it on there is no picture or sound, but there is a light high pitched noise.
That high pitched sound is likely the Horizontal Output section trying to work. It operates at 15,750 Hz or at the upper end of normal human ears.
It will sound like a high pitched whine.
This is a section or your television that you don't want to fool with unless you are quite familiar with servicing your set. There are very high voltages involved and only a qualified technician should tend to this defect. It maybe easy to fix or it may be quite involved. Get an estimate first then decide to go further or not. There is a potential fire hazard here so don't operate your set until this is resolved.
Zashiban
Jun 23, 2010 | Samsung DynaFlat TX-P2764 27" TV
My CT-32SL14 32" TV has a high pitched Random BEEEEEEEEPing sound
prob high volt transformer tech may be able to repair replace cost high. 200 orso
Dec 01, 2008 | Panasonic CT-32SL14 32" TV
High Pitch Noise on 42" PLasma Gateway TV
how old is your plasma TV? try check the switch / volume of the sound settings.. Sometimes, when you always increase the volume, it will tend to alter the limit of sound and causing the sound to provide sound undesiredness. I suggest to check it with a liscensed technician.
Feb 05, 2008 | Gateway PLSM42TV 42 in. HD-Ready Plasma...
No picture no sound only the power light turn on and off
Hmm, sounds like a fuse has blown, and this is a problem that I recommend only those comfortable around high voltages try to fix......
Dec 22, 2007 | RCA F36650 36" TV
RCA 36" TV - High Pitch Sound - No Picture or Sound
check for high voltage s3ection of your TV. A Flyback transformer is defective especially in the high voltage cale of your flyback....
Oct 19, 2007 | RCA 35V432T 35" TV
TV screen wont turn on but just a loud noise coming from the tv
I think maybe the G-board needs to be replaced. A TV shop will have to repair it. They normally start around $200.00
Jul 02, 2007 | Panasonic CT-32G23 32" TV
Televison
The high pitched sound is probably comming from the power supply, possibly due to its trying to drive voltage into a shorted component in the high voltage deflection circuits. You may be lookng at about a $250 repair. If it has been used a lot and its picture quality didn't knock your socks off, I would replace it with a HDTV set. A 37 inch LCD from Toshiba might be a good place to start and should do nicely for you.
Jan 24, 2007 | Panasonic CT-36D11 36" TV
No picture, just a high pitch sound
Sounds like the flyback and horz output is shorted.
Nov 30, 2006 | RCA F32672SB 32" TV
Panasonic CT-36D31 36" TV Logo
967 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
