Question about Dryers
A Squeak I have aTCR2 Creda Condenser Dryer. It has started to squeak recently but its only with heavier loads i.e towels n bed linen etc. What could it be???
  • 3,463 Answers
Hi.
Could be dry drum bearing or jockey pulley dearing. take the rear cveroff the back of the dryer, and you will see the rear drumshaft and bearing.
Squirt some wd40 on the bearing, hopefully.this will cure the squeak.
Posted on Nov 21, 2008
SAMSUNG steam moisture sensor front load dryer has noises coming from it. Need help to pinpoint possible problems and how to fix.
You may have a roller out of alignment or off track with the drum now if you took the front panel off. Check to make sure the rollers are on track and the front slides may need t o be replaced if your dryer is a 2 roller model.
Feb 08, 2017 | Samsung Dryers
Where can I buy quality cotton towels and bed linen in Bangalore?
To purchase quality cotton towels in Bangalore I will recommend you Maspar. It is leading online shopping store for home furnishing products. Choose from a wide range of cotton towels here- http://www.maspar.com/bath-linen/towels.html
Feb 27, 2014 | Moen 24 In. Towel Bar...
Dryer about 5-6 years old and does about 5-6 loads per week. last 2 months, with medium to heavy loads, has developed a loud squeak that coincides with drum rotation. light loads cause a lesser squeak, and...
drum rollers/glides, may be that the motor needs to be oiled, in which case you will need to unplug dryer and drill a hole in the casing not to deep just to where it goes through the casing, then moisten the cotton fabric. Hope this helps Tim:
http://www.partselect.com/dryer+dryer-tears-clothes+repair.htm
Feb 26, 2011 | GE Profile DPSR475GW Dryer
The dryer squeaks - noise is coming from left hand front of dryer. I've take the cover off, there is a plastic piece that if I press toward the front of the dryer stops the squeak. The heavier the...
The squeak is actually the rear bearing WE3X75.
98fbf6b.jpegOddly enough although this might be your part you should use your model number to order the part. Different production runs I guess. Theis dude mounts in the rear
66ec823.jpgright in the center of the heater. This bearing gets real thin and when almost gone starts the squeal. You must remove the drum to get to the backside and replace that dude. I have a pictorial and more HERE.
Oct 12, 2010 | GE DBXR463GB Gas Dryer
We've got a Maytag MDE6000AYQ dryer that we love. It started squeaking two loads ago. It would squeak off and on during the cycle. This next load seemed to squeak worse, so I'm worried to use it any...
The squeak is most likely from the drum support rollers or the drum bearing. If it's the rollers, they're fairly easy to replace and often a drop of lubricant will solve the problem. This is just one supplier of such parts:
http://www.apwapplianceparts.com/Laundry+Appliance+Parts/Dryer+Appliance+Parts+/Dryer+Drum+Bearings+and+Felt+Drum+Seals/default.aspx
Jun 21, 2010 | Maytag Atlantis MDE6400AY Electric Dryer
Smell
I think that you probably want to replace that gasket/book. with the front loaders, its almost best to leave the door cracked if you replace it. MCM electronics has the parts. their number is 800.824.9491. they ship UPS so its a little more expensive but if the part is in stock, you get it pretty quickly
Apr 15, 2010 | LG WM2487HWMA Front Load Stacked Washer /...
Dryer is squeaky. The heavier the load the louder the squeak
Might be a worn plastic bearing on the ceter hub. I have repair pictures HERE
Feb 16, 2010 | Dryers
The dryer squeaks loudly
The dryer has been over loaded too often. Try to determine if squeak is from the front or back. The felt pad dirty. If it is from the bottom, then the tension roller is binding and needs lubrication.
Nov 20, 2009 | Frigidaire FEX831CS Top Load Stacked...
Ge gas dryer that sweaks as drum rotates. the heavier the load the louder the noise
the drum sits on a couple of roller bearings. thats where the squeak is coming from. its a couple of hour job to change them. as far as dryer repairs go this is big job. I recommend finding a new machine although it will still work for quite a while.
Aug 23, 2009 | Dryers
Condenser dryer
doubt if squeak is related to not drying. if you are getting heat (you say heating element is ok) take out condensor and hose it down till thoroughly free of lint. check appliance has adequate ventilation as well
Apr 09, 2007 | Zanussi TC180W Electric Portable Dryer
Dryers Logo
123 people viewed this question
Top Dryers Experts
