Question about Dell Dimension 2400 PC Desktop
PC boot up problem
When my other PC tries to boot up, it has has a difficult time and I wind up hitting some key until it finally gets to the desktop. After that, when I go to open an application, it tries to open multiple windows - usually between 80 to a 100. After I fight with closing each window getting and error each time, the PC runs fine. Needless to say, I haven't rebooted in quite some time.
  • nathangurley
    nathangurley Apr 25, 2009
    Eagle338 (Sai) is very helpful and knowledgeable.
  • 4,889 Answers
I believe this is some kind of registry goof up or a malare infection.
Click here to run an online scan with PC-Cilin(free) and see if catches anything. Then download and install an anti-spyware. My suggestion is Spybot destroy coz its cool and my personal choice. Its also free.
http://www.spybot.com/en/mirrors/index.html
If nothing works then post back and we will try and go for a much more complicated registry fix.
Also you did not rate my Live Session with you. If you found it useful please do rate it.
http://www.fixya.com/support/c31033-lg_42_in_goes_off_every_15_20_minutes
Regards,
Sai.
Posted on Nov 20, 2008
Power comes on no video, monitor works
Try hitting the F8 key or what ever is the key for safe mode, or try F11 for boot menu, if boot menu shows boot to hard drive.
If these don't work, unplug the PC, then hold the power button until the lights flash or hit again and make sure lights don't flash on.
remove the side cover, touch metal, then remove the little round battery for 5mins, replace, plug in, hit power, not hit the delete key and try to boot into the BIOS, you will need to set the date and time. then move to exit and save changes and exit.
Mar 14, 2013 | Dell OptiPlex GX620 PC Desktop
On booting it shows Intel AMT Error - Aborting, after a while it then shows 2207 AMT connection failure after which it finally boots to windows. its a hp compaq desktop dc 7700p mini tower convertible bios...
When you boot your computer, you need to hit the key to get you into the bios setup. F10, F2 or Del keys are the usual ones.
Once into the bios, change the boot order to make the CD drive first, and then you will boot right to the CD.
Note, you will also have to hit a key when it starts to boot, it will say, hit a key to boot from CD.
If you miss the key to get into the bios, you have to start over again. Sometimes you have to hit the enter bios key over and over to get in there.
Source : AMT Error
Aug 13, 2012 | HP dc Computers & Internet
My partner got a laptop emachines m250 and her son pressed system restore by accident now we cant get past the password to get onto desktop
It sounds like you might be trying to boot into a domain or lan. Turn the computer off and turn it back on and watch the screen for which key it says to press to Change the Boot Order or Boot Sequence. Hit that key when you see the message otherwise you will have to restart and try again. Select the Hard Drive as your boot option and let it boot up. If you are successful this is a temporary change and will have to be done each time you boot the computer. See below on how to make it permanent.
If you are successful then you want to turn the system off again and reboot looking at the screen for which key it says to hit to get into the Bios or System Setup. Hit that key when you see the message or you'll have to try again. When the Bios is open tab over to the Boot Sequence or Boot Order and set the dvd/cd as 1st and the Hard Drive as 2nd. This is the normal boot sequence and when you boot just make sure you don't have a music cd or movie video in the dvd/cd drive or you might get an error message if it tries to boot from it. The cd/dvd is first just in case the hard drive fails then you can use a cd to try and make repairs.
May 24, 2012 | E-Machines eMachines Desktop PC
Cant get back to desktop
Pretty vague help request "can't get back to desktop". Is the computer booting? Is it that your desktop is blank after it boots with no icons being shown on the desktop? Viruses can hide the desktop and other things on the computer. Maybe your boot process has the problem when it tried to display the desktop. Try hitting the CTRL+ALT+DEL keys. Hold down each key as you hit them and don't take your finger off the keys until after you have pressed the DEL (Delete) Key. This will bring up your Task Manager. In the task manager window click the Processes tab and look for explorer.exe. If you see it click explorer.exe to highlight it then click End Process. After you end the process click FILE at the top left corner of the Task Manager Window and click the option New Task (run). When the Create New Task window opens type: explorer.exe and press OK. This will cause your desktop to reappear with icons if windows had a problem displaying it on the boot process.
Mar 17, 2012 | Computers & Internet
Clean old files out of a computer
go to "my computer" and click on the drive (usually "C") and click on explore. the drive storage files will open so that you can choose which ones you want to delete. You can delete one file at a time or hold down the CNTRL Key and keep selecting files but don't try to do too many at once, maybe 10 or 15 at a time, just hit the delete key and they will be gone, realize that once they are gone they are actually in the recycle bin and can be recovered. You will not get your space back until you actually go into the recycle bin and delete the files that are there but once you do this,its final and your files are gone forever (well not exactly, but it would be difficult to get them back).
if you have a drive besides the "C" drive that you want to deltet files on, you can go to the drive and choose "select all files" and then hit the delete key, these will go to into the recycle bin as well and you'll have to detlet them there too to actually recover all your space. Be advised that some files are so large that when you hit the delete key the file won't go to the recycle bin but a diaglog box will open asking you if you want to delete the file.
Mar 18, 2011 | Dell Dimension 2350 PC Desktop
My msi wind wont start!!! i was trying to reinstall my windows using the recovery disk, so restarted my wind but mistakenly pressed f12 instead of f11 to run the boot set-up, but my screen froze (totally...
I'd like to help you, but it is very difficult to diagnose based on your description. We will need to gather more info as we try a few things.
1. Why are you reinstalling? 2. How old is the system? 3. Try the following & let me know the result: turn system back on. When the normal LED indicators are on, press & hold down the power button for 4+ seconds until everything goes off. 4. If step 3 worked, then turn power on & hit bios setup key (f2?). 5. See if HDD is detected.
Jun 07, 2010 | MSI Wind U100-030US Laptop
When i turn the pc on it seems like it is over running or winding out
The winding noise can be caused due to three components on the computer. The power supply fan, the Processor fan or the harddrive.
You run the built in diganostics to isolate if the fans are making the noise.
1. Restart your computer
2. Tap on the F12 key a couple of times when you see the Dell logo screen
3. High light boot to utlity partision using your down arrow key
4. Hit enter and select diagnostics
5. In the diagnostics menu select customer test and run the test on the fan.
If the test pass you need physically check , opening the chassis and which fan is making the noise and replace the same.
Thanks for using Fixya
Proton
Apr 18, 2010 | Dell OptiPlex GX520n PC Desktop
MY EMACHINE DESKTOP RECOVERY CD DOENT WORK
Hello
When booting up pc have you held the delete key or f2 key down to bring up the boot menu?Should be a option of cd dvd or hdd to boot first.
You want the cd dvd boot option on top or first.tThen reboot pc.
When asked hit any key to boot from cd, hit a key.Should start install.
If youve done this, clean the dvd or cd install disc with some windex and a paper towell,try again.
You can also do a system restore from control panel recovery option.
Jan 23, 2010 | E-Machines eMachines Desktop PC
Gateway splash screen thats all I get
Try hitting the delete key over and over at boot up. If you can get to BIOS, you can disable the splash screen, and also make sure that the boot order is correct. Try to put your hard drive as first boot priority. Also, remove any CD's in the drives.
Good Luck.
www.cobaltflorida.com
Jan 20, 2010 | Gateway GT5242E PC Desktop
Need to know hot to start emachine el 1200 in safe mode
depends on your operating system and bios i think.
you cant do it any harm...honest...just press f6 or f8 i think as it boots and a screen will show up asking what you want to do next?....read the screen and follow the intructions as there can be a few choices to go for.if you dont get the screen just SOFT restart untill you find the f-key that brings up the boot menu by pressing together CTR,ALT & DELETE at the same time to re-boot and then hold down another choice of f-key untill you hit the boot menu...hope this helps :)
Oct 07, 2009 | E-Machines eMachines T3830 PC Desktop
Dell Dimension 2400 PC Desktop Logo
Alun Cox
