2003 Chevrolet Malibu Logo
Anonymous Posted on May 05, 2012
Chevy Malibu 2003 cranks but won't start! I know
  • 1 more comment
  • Anonymous May 07, 2012
    I replaced the knock sensor, crank sensor, fuel filter, pressure regulator.. Clean the idle air control valve aswell nd nothing! The first symptoms that I saw was the rpm gauge immediately went to zero.. Nd stayed while I was accelerating, it's been there ever since. The car turns on every second time I turn the key over but once the engine is warm, it only cranks until engine is cooler then turns on. I know it's electronic but can't find what it is.. The engine sounds like it's in need of a lil more gas..
  • louie de la garza
    louie de la garza Aug 26, 2012
    sounds like you have low fuel presure defective fuel pump
  • desertracer May 20, 2014
    Have the IGN module in the distributer checked. Orillys has a machine that will check it you must remove it and take it to them..
Kevin Getz
Level 3:
Genius:
  • Master 1,032 Answers
  • Posted on May 05, 2012
Kevin Getz
Master
Level 3:
Genius:
Answers
1032
Questions
Helped
324696
Points
3063
You might have a defective fuel tank pressure sensor!
  • Anonymous May 08, 2012
Anonymous
Level 1:
New Friend:
  • Contributor 3 Answers
  • Posted on Aug 12, 2012
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
3857
Points
I sed a rubber hammer taped the fuel tank,then ,when i turned on the ignition the fuel pump hummed .vehicle started but would not stay running..after several attempts the fuel pup stoped humming .im replacing the fuel pump.
5 Related Answers
MacGyver911
Jerry Mace
  • 42 Answers
  • Posted on Mar 19, 2009
SOURCE: 2003 Malibu won't start
If the theft light is not on, then it's not related to the security lock-out. This is classic fuel pump failure. If you don't hear the 2 second hum of the fuel pump when you turn the key, it has failed. If you hear it and you still have NO gas to the engine, it could be debris in the strainer or a severely clogged filter.
Anonymous
  • Posted on Aug 19, 2008
SOURCE: how to bypass passlock on 1999 chevy malibu ?
Does the dash gauges and digital mileage and idiot lights work when you turn the key on?
Anonymous
  • 1201 Answers
  • Posted on Jan 27, 2009
SOURCE: 2003 chevy malibu that cranks but won't run
If you haven't done so already, have the cam and crank shaft position sensors checked, or replaced, You have replaced everything else.
Anonymous
  • 10 Answers
  • Posted on Feb 19, 2010
SOURCE: 1998 chevy c15 5.7 SFI SYSTEM
My truck did this after I replaced the fuel pump. Turned out to Fuel Pressure Regulator. It would crank and crank but never start. It's located underneath the black plastic manifold on the side of the injectors.
Anonymous
  • 8 Answers
  • Posted on Mar 16, 2010
SOURCE: 1999 chevy malibu, stalls, no restart after
I had the same problem-my check engine kept coming up with crank sensor(replaced several times- the car would run for 2 days then stall again)finally checked and replaced the wiring harness and the car ran great for awhile. Now I have a whole new problem(abs lights started coming on and the gauges all died while driving at which point the car just stopped and woulkd not restart)thinking alternator(the battery works great in another car)
2helpful
4answers
2009 chevy malibu won't crank.. Changed battery,
Did you ever figure out the problem Jason? I have the same exact deal going on with my 09 Malibu I can't figure out what the deal is?
1helpful
1997 chevy malibu wont start when hot
It sounds like a coil problem or its vapor locking when it quits again pour cold water on the fuel line and the fuel pump to cool both if your car starts you have found the problem if it won't start try replacing the coil
My 2003 chevy malibu cranks but wont start. battery is good and altenator is good
To clarify - - if the engine cranks the battery and starter are ok.
The alternator does not come into play until the engine is running.
If it cranks but won't start, you have to figure out if you are missing fuel to the injectors or spark to the plugs to proceed.
A mechanic would check that and if there are any trouble codes stored in the computer.
2helpful
Turns over but won't fire
If a starter is able to crank the engine but it won't start you usually have either an electrical or fuel problem. It's also remotely possibly that it's compression.If an engine has proper fuel, spark and compression, it will start when you crank it. So your challange is to find out which part isn't working right. Start with fuel. Spray a little starting fluid into the air intake while someone tries to start the engine. If it starts briefly when you're spraying starting fluid, you probably have a fuel delivery problem. That could be injectors, fuel pump, fuel filter, relay, fuse... who knows what until you check into it.If it doesn't start with starting fluid, check the spark. Pull a plug wire and attach it to a spare sparkplug and set the plug on a solid metal part of the engine. Have a helper crank the engine while you watch the plug. If you have a good spark, it might just be out of timing.In any case, you'll need to start isolating the problem. Find out which part isn't working then you'll know what to replace/repair.
'99 Malibu won't start.
sounds like a bad solenoid on the starter. replace the 1999 starter(Its old).
I have a 1998 chevy malibu that will not start. i replaced thr starter and key switch still it will not start. found some fuses blown replaced them still will not start. (the fuses was starter related)need...
There is a starter relay in the vehicle and it is normally located under teh hood, in the power distribution box which is usually drivers side. When you say it won't start, do you mean it will not crank or it will not start. If the motor is turning over but not firing the problem is not the starter and is most likely fuel related. If it is cranking and will not fire, do a compression check on the motor. If you have zero compression on one or more cylinders then the problem is most likely a broken timing chain or belt. If compression is good and it is cranking over then you need to check the connections to the Distributor and the Crank and Cam position sensors.
My 96 crown vic police interceptor, cranks won't start without spraying starter fluid.. the car won't start without spraying starter fluid into air intake hose to carb...
starting fluid is a thing of the past. dont use it. this car doesnt have a carb, its a throttle body/ electronic fuel injection system. you most likely have a fuel pump or fuel pressure regulator issue. test the fuel pressure, should be anywheres from 35-50 psi
2answers
Replaced fuel pump but it won't start it will crank but it won't start
when you have your hood up in the air can you hear the starter trying to make a clicking sound or no sound at all with the starter ? Starters also go bad too and some times it is intermitten some times as well. You can use a multimeter if you know how to use one that you can use one to test the starter red hot plug from the battery to it.
2answers
My son has an 98 Chevy Malibu, it wasn't starting so he took it to a Checkers and they put it on their manual diagnostic machine and said he needed a battery. So he bought a battery and it still takes...
no the starter only cranks the motor if it is cranking the motor over its good . you might have bad gas with water in it , a clogged fuel filter , bad fuel pump , check if you have fuel pressure with a fuel pressure gauge , check if you have spark at the plugs then reply findings on this post hope this helps
Top Chevrolet Experts
ZJ Limited
ZJ Limited
john h
Thomas Perkins
Thomas Perkins
Are you a Chevrolet Expert? Answer questions, earn points and help others
