Question about Delphi MyFi SA10113 XM Radio Receiver with Home and Car Kit
My XM Delph MyFi won't "record"
I had recorded several XM programs and played them back. Today I tried to record something and it wouldn't work. When I checked to see if the memory was FULL it said "nothing in memory". What Happened? Is this a defect, or do I need to send it in for repair?
I get the same problem once in a while. Try removing the back cover and hitting the reset button via a paper clip--then try accessing the stored content. The MyFi should "release" the stored content.
Posted on Feb 21, 2007
My smilebox slide show won't record.
My creations preview great but when I press the save to DVD nothing happens, I am not saying is a smilebox problem, but It used to work just fine. I am just wanting to know what to do because I just wasted 40 bucks if I cannot burn it
Jun 21, 2012 | smilebox.com
Want to copy songs in my mifi xm to computer how? only have the 3.5 plug on my mifi
This is of course against the rules of your XM user agreement, but if you wanted to 'test' this out, just run the 3.5mm plug from your earphone jack to your 3.5mm 'LINE' input on your computer. Load the free program called "Audacity" on your computer, hit 'record' and you can record and edit the song, saving as an MP3 or WAV file. Again, this is against the XM rules, so this is all just theoretical okay? You would then need a program like Nero to take the MP3 or WAV and record to a blank CD. Just a theory though.
Aug 07, 2010 | Delphi MyFi SA10113 XM Radio Receiver with...
My Myfi will turn off and on in the car. It is
Leave the battery out and see. Do you have the sleep timer set, or have it set for recordings? Try a complete reset and see if that clears things up (unless you have recorded content you don't want to lose).
Jan 23, 2010 | Delphi MyFi SA10113 XM Radio Receiver with...
My XM recording plays but doesn't have audio.
Recently I had the same problem - could see it was playing on the screen, but no sound in the headphones. Pulled battery and reinserted. That solved the problem, whatever it was.
Jan 08, 2009 | Delphi MyFi SA10113 XM Radio Receiver with...
Recording xm
Press "mode" button so that the reciever is receiving music from satellite signal on the station you want to record. Then press "2Go" button - screen will ask you to press again to confirm - press again, and it will record whatever was being received. It will record over what was already in 2Go. In menu, under "myXm" there are choices to clear the entire memory of recorded music.
Dec 31, 2008 | Delphi MyFi SA10113 XM Radio Receiver with...
Downloading instructions Delphi SKYFi3 unit
You can't download Xm programming, like you can from itunes, where you get a song in 3 or 4 seconds.
Do you mean record music? You must record realtime, either while listening or while the unit is idle in its cradle.
It's easy. while listening to the radio in the cradle (press mode repeatedly to get to Live XM mode), then press the center (play/pause) button.  the menu will pop-up, select Record.  It will give you the option for Song, Channel, and Session.  Just chose one of the first two and press the button.  You should see a microphone appear at the top of the screen.  It's recording.  Follow the same steps to stop the recording.  Setting up a recording session is self-explanatory once you get into that screen.
Oct 21, 2008 | Delphi SKYFi3 XM Radio Receiver
try doing away with the external fm transmitter and use the one thats built in to the delphi you just go into settings and set it to a station that has no channels and tune it in
Jun 13, 2008 | Delphi MyFi SA10113 XM Radio Receiver with...
MyFi loses proper index to recorded music
Sometimes this will fix itself if you take the battery out. Otherwise, the best way seems to be to empty the memory, and start all over, recording on a blank slate. These are really pretty awful machines, with endless problems.
The on/off switch on mine just broke, and I say "good riddance."
Feb 03, 2008 | Delphi MyFi SA10113 XM Radio Receiver with...
MyFi remote control has stopped working
ok take the battery out of the radio then put it back in and it should work mine did the same thing to me
Nov 24, 2007 | Delphi MyFi SA10113 XM Radio Receiver with...
Delphi MiFi
xm radio shuts down , then starts back up again with no intervention.
Oct 03, 2007 | Delphi MyFi SA10113 XM Radio Receiver with...
Delphi MyFi SA10113 XM Radio Receiver with Home and Car Kit Logo
173 people viewed this question
Top Delphi Audio Players & Recorders Experts
xxxxxx xxx
Marvin
Marvin
Colin Stickland
Colin Stickland
Are you a Delphi Audio Player and Recorder Expert? Answer questions, earn points and help others
