Cars & Trucks Logo
Posted on Nov 19, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
High beams wont turn on.
Low beams work fine go to turn on high beams i have no headlights at all. when i have fog lamps and low beam on and hit high beams fog light go out. please any help would be appreciated. thank u.
  • 6 more comments
  • Anonymous Mar 12, 2014
    low beams work but high beams wont work
  • Anonymous Mar 13, 2014
    Front headlights come on but the high beams
  • Anonymous Mar 15, 2014
    low beam lights work, high beam lights wont turn on
    while changing a headlight bulb I lost my low beam and driving lights but the high beams still work. whats wrong.
  • Anonymous Mar 18, 2014
    My company bought a new 13 F550 and at 3,000 miles the high beams only came on if you held the multifunction switch, then when the high beams did come on they wouldn't go back to low beams, until like a half hour later after hitting a lot of bumps.
  • Anonymous Mar 24, 2014
    pump works fine in low but this happens in high
  • Anonymous Mar 27, 2014
    Low beams working but the high beams aren't working. The lights turn off when the knob is on the high beam position.
  • Anonymous Mar 30, 2014
    drivers side low beam went out the other day. replaced both headlight bulbs (as recommended) and the one still does not work. high beams work on both. fog lamps work for both.
Anonymous
Level 2:
Novelist:
  • Expert 193 Answers
  • Posted on Nov 19, 2008
Anonymous
Expert
Level 2:
Novelist:
Answers
193
Questions
0
Helped
100381
Points
490
First place to start is with headlight switch. I did have a case many years ago when both high beams were blown out at once, but this is rare. When you have the headlight switch out, jump power from te low beams to the high beam contacts. If high beams come on, replace switch.
Bill
Paul Thoegersen
Level 2:
  • Expert 95 Answers
Paul Thoegersen
Expert
Level 2:
Answers
95
Questions
0
Helped
65088
Points
282
Park up to a wall with the lights on and move the dimmer switch slowly on and off up and down and see if you get a flicker of lights...probably a bad switch
2answers
No headlights or fog lights
I suspect it is the headlight switch
4helpful
2answers
2005 Ford Focus ZX3 SES, the blue high beam indicator in the dash comes on with low beams, and goes off with high beams. The indicator is on at the wrong time! I have tried the following: The turn signal...
It sounds like you are confused about how your headlamp system is supposed to work. The DRL does not run on the High beam circuit, it runs on the low beam circuit. The fog lamps are supposed operate with the park lamps and also with the low beams, not the high beams. From your description, I would say that your system is operating as designed and you are having trouble telling High from Low. (Don't feel bad, that is why high beam indicators were invented in the first place.)
My 2000 Blazer low beam headlights won't come on .High beams, fog,running, turn signals all work fine.
Try changing the headlights....some headlight high beams will work even when the low beams dont
Passenger headlights only do not operate.
check the bulbs first and also the fuses theres a fuse for each side and for low and high beams, start there, good luck.
Low beam headlight are not working. high beams and fogs lamps work fine. is there a fuse for a controller?both low beams stopped working at the same time so i don't think it the fuse for the headlamps.
The problem could be the headlamp switch.
You are right about the fuses.There is one for the LH high/low and one for the RH high/low.
Have you tried turning on the lamps manually with the switch?
Headlight trouble on sunfire 2003 with 2.2ecotech
sounds like either a wiring loom is shorting across somewhere ??where ----best of british to finding it
Low beam headlights not working on 2004 Pontiac Montana extended
You headlight lamp have a diffuser mechanism which allows it to flip between the hight beam and low beam feature of the bulb. In fact, you high beam will function even if the low beam is not working.
I would recommend the purchase of the new headlight lamp. It would cost you you any where from $15.00 per unit to get a replacement lamp
Top Ford Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
Thomas Perkins
Thomas Perkins
Are you a Ford Expert? Answer questions, earn points and help others
