Question about RCA D61W20 61" Rear Projection Television
Tv makes high pitch noise
My tv is around two years old. A few months ago it started making a high pitch noise. Sometimes you can turn the tv off and back on and the noise will stop but not always. A repair shop said it was most likey the flyback, and it might be repairable without replacing it, their labor rate was to much (200-300 hundred) plus with the amount of time we would spend without our tv, we would like to try to repair it our selves. How do you repair a noisey flyback? Is there any way to get a diagram? My husband thinks he could repair it if he had instructions.
Seems like your television is doing the same thing as mine. I dont have a resolution but this may help from it clonking out completly. Leave it alone for now. My television started doing this months ago and I rarely even used it for the first two years due to deployment. One day it startd the high pitch, and i ignored it because i rarely turned it on besides when company came. About a month later it completly clunked out. Now i only get the green power light. NO pic, No volume or anything. Just that loud screech. Eventually it will go out, causing more problems. Usually you can go to a repair shop, get the piece name from them and then order and fix it yourself. The shop is going to do the same thing as you will, except charge you more for having ordereing it when you can do so yourself. Shops here charge about $60 bucks to let you know what it is... Shouldnt be a big change where you are.
Posted on Apr 24, 2007
When turned on the screen is blank and makes a high pitch buzz
Samsung LCD TV with no video and high pitched sound - Digital TV ...
www.tomsguide.com/forum/54120-4-samsung-video-high-pitched-sound
Nov 8, 2015 - 25 posts - ‎12 authors
Our is the same model and has started making a very high pitched ... to acutally turn on and then when it does, the screen is still black and we ...
Is your LCD making a buzzing or high pitch noise ...
https://www.devside.net/blog/lcd-making-a-buzzing-noise
Dec 30, 2008 - In my case, the monitor was fine for the first two months. But then started making a buzzing noise... 1) when on, 2) worse when .... my Samsung TV ismaking high pitched noises even if its turned off. I will NEVER EVER EVER ...
TV not turning on; making high-pitched sounds - Tom's ...
Dec 13, 2015 | Televison & Video
`How do I fix my LG tv? It's making a high pitched noise and there is a black screen, is it fixable?
Get it to a tv dealer but my guess is its died. It may not be economical to repair but you may be pleasantly surprised and its a small job. LG are usually pretty good so I'm surprised its gone at this age.
Mar 30, 2015 | LG Televison & Video
Making High Pitch Noise, Sounds Strained
the drive shaft bush is dry ( probably from dough getting up the shaft) have the unit serviced /repaired and properly lubricated using food grade lubricate
Mar 20, 2017 | Bosch Food Mixers
Toshiba HD ready TV ct 90158 makes high pitched sound
A high pitch sound can be a capacitor losing power it would sound a bit like a fire work. most have back up on the board but it put more pressure on them the more times you use the tv. would check them and replace. all of them can be 5 in a row in some models.
Oct 23, 2013 | Toshiba Televison & Video
I have Samsung DLP TV 50 inch HL-P5063W
First thing to look at is the color wheel this model uses--usually it will make a high pitched fan like sound but can make a grinding sound also.
If it slows down from the 12,000 or so RPM speed it will cause color issues.
HAVE GRINDING OR HIGH PITCHED SOUND?
Apr 02, 2012 | Samsung Televison & Video
Making Loud noises
Got the same problem with my second TX-S3082WH Slimfit...the first had the same problem...it was deemed unrepairable and I was advised to return it to Circuit City...now a year and five months later Samsung support has been less than helpful as I am 5 months out of warranty...don't know what I'm going to do...any advice would be appreciated
Dec 02, 2007 | Samsung TXR3079 TV
TV won't turn on, makes high-pitched clicking noise
Its a real good chance that the HOT (horizontal output tranistor) transistor is shorted if so the flyback trasformer may be bad also. the transformer will make a tick tick sound if it is trying to start.
Mar 30, 2007 | Philips Magnavox MT1905B 19" TV
Occasional 'whistling/whining' from back of TV
I wonder if there is enough air circulating around your equipment?? My DVD recorder makes a sound unless I open the doors on the cabinet that contains all of my equipment. The cable company says it is a fan to cool down the units.
Jan 30, 2007 | Bush WS6671 28" TV
High Pitch buzz noise when plugged in and it doesn't turn on
The tv has a shorted component and that is why is making the noise,call a qualified technician to find it and dont try to use it anymore.Is not a fuse.
Sep 12, 2006 | RCA F25649 25" TV
RCA D61W20 61" Rear Projection Television Logo
98 people viewed this question
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
