Question about Generic Memory (SY-ATA-6410-2L) (SY-ATA-6410-2L) IDE Controller
Finding a driver for SY ATA 6410 2L IDE Controller card
I can't seem to find a driver for my IDE card. I installed one on my intel DG451D mama & it locked up the system.
Thanx for your help,
Mark
Acer Extensa5620z originally had Vista, I wiped the hard drive and installed W7. Its not as simple as I thought. Now I need to update drivers and Acer.com doesn't have anything listed. In the det
Windows 7 should automatically install device drivers for the Audio, Video and Network, If you are unable to find/download a device driver that works on your computer and your computer is connected to the Internet then - 1. Remove the driver that isn't working if it was installed.
2. Set Win-7 "Windows Device Installation" to 'AUTO'
3. Windows will automatically search the internet for the driver.
4. Reboot your computer.
Mar 19, 2013 | AU Optronics Acer Extensa 5620-4801...
Silicon Image Ultra-133 Medley ATA (Maxtor Ultra ATA/133 PCI Card
No I do not think there is unfortunaely. Contact Maxtor and ask if they are going to support it under Windows 7?
Jan 21, 2010 | Maxtor Ultra ATA/133 PCI Adapter Card...
I cannot find a driver anywhere for my belkin f5u098 ide raid controller.
The drivers for this ATA Controller Card are resident in Windows, just like the Motherboard's onboard ATA/IDE Controller. If they don't autodetect and load make sure you are running at least Service Pack 2 for Windows XP and SP4 for Win 2000. Vista and later will have resident drivers.
Sep 23, 2009 | Belkin Ultra ATA/133 PCI (f5u098) ATA...
Vista drivers needed for Ultra ATA/133 IDE RIAD controller card
You can plug it in and see if Vista can use any of its drivers for it. In many cases it has drivers for the chipset on the card which will work perfectly well with the device.
Apr 09, 2009 | Maxtor Ultra ATA/133 PCI Adapter Card...
Who is the mother board manufature for sy -p41 845pe? what type of cpu does sy -p41 845pe suport and speed range? the type of module, max support capacity and speed ranges? the type of chipsets? the type...
Processors
  • Supports all Socket 478 CPUs (400FSB & 533FSB)
Chipset
  • North bridge: Intel I845PE MCH
  • South bridge: Intel ICH4
System Memory
  • 3 x 184-pin DDR SDRAM
  • DDR200 / DDR266 / DDR333 support @ 2.5v
  • 3GB maximum system RAM
Slots
  • AGP slot, 4x AGP compliant (1.5v support only)
  • 6 x 32-bit PCI 33MHz slots
On-board peripherals - I/O
  • 1 floppy port supports 2 FDD
  • 3 Audio Jacks for the CMI9738 sound chipset
  • CMI9738 6-channel sound
  • Davicom 10/100 LAN (10/100 Mbit/s)
  • 2 USB2.0 ports and a further 4 available via headers
  • PS/2 ports
On-board IDE
  • An IDE controller on the ICH4 chipset provides IDE HDD/CD-ROM with PIO, Bus Master and Ultra DMA/100/66/ operation modes
  • Highpoint HPT371 RAID single-channel ATA133 RAID controller
  • Ultra DMA/ATA133, 100, 66, 33 operation modes
  • Supports up to 2 hard drives
  • Serial ATA support via the Marvell 88I8030 single-ATA bridge
  • Supports 1 S-ATA drive
BIOS & Voltages
  • FSB speeds of 100Mhz - 255Mhz (quad-pumped)
  • 1.1 - 1.85v Vcore adjustable in 0.025v increments
  • 2.5v - 2.8v Vmem adjustable in 0.1v increments
  • 1.5v - 1.8v VAGP adjustment
  • Fix AGP/PCI speeds and variable settings
Jan 22, 2009 | Soyo SY-P4I 845PE Motherboard
Hello, I have a PCI Ultra Ata/133 Dual IDE card. I have two Ide devices hooked to it. Everytime I hook it up in the system My regular Motherboard IDE says can't be read, reboot. I am trying to get not Raid...
Sounds like the system is trying to boot from the drives attached to the controller. Go into your setup and make sure the system is set to boot from the proper drive.
Jan 12, 2009 | Maxtor Ultra ATA/133 PCI Adapter Card...
Controller Driver Issue on Armada M700
I am running a Armada M700 with a Hitachi HTS541060G9AT00 60GB Hard Drive - Ultra ATA-100, 5400 RPM, 8MB. The driver that is loaded in mine is on both primary and secondary is atapi.sys. This driver is also installed on the Intel 82371AB/EB PCI Bus Master IDE Controller, along with intelide.sys. The main difference is I am running Window XP Pro SP2. But I believe that they should use the same driver.
Hope this helps.
dferguson64
Sep 09, 2008 | Compaq Armada M700 Notebook
Driver for rtl 8139D
maybe you got the wrong version of your driver, realtek got an A&B device driver..
Feb 15, 2008 | Computers & Internet
Installing a 2 port ATA-133 IDE adapter card to a desktop w/a hard drive & DVD
I don't think you can boot off of the ATA-133 so you will have to boot off of the IDE on the mobo and have the DVD drive jumpered cable select on the 2nd IDE. Boot that way to make sure the system boots. Shut down. Then instll the ATA-133 adapter with NO DRIVES on it and boot. The system should ask you for drivers for the new hardware. Intall the drivers. Shut down. Attach the new drives to the ATA-133. Reboot. You still might have to go into admin in windows and assign drive letters to the new drives. Anyway, if you are trying to boot off of a drive on the ATA-133 adapter, I don't think you can do it. I have mostly used Asus boards with Award Bios and there was no way to point the boot process to an add-on ATA Controller.
Jan 12, 2008 | Promise Ultra133 TX2 ATA Controller
Generic Memory (SY-ATA-6410-2L) (SY-ATA-6410-2L) IDE Controller Logo
213 people viewed this question
Top Generic Memory Computers & Internet Experts
David Payne
David Payne
Are you a Generic Memory Computer and Internet Expert? Answer questions, earn points and help others
