Question about Magnum S9 Base CB Radio
When I switch off ceiling fan outside motion sensor lights switch
Outside security lights are motion activated and switch on when I activate the home security system or switch of ceiling fans. I'm told this is caused by "back EMF" How do I fix it?
  • 55 Answers
I AM NOT SURE ABOUT THIS ONE.......
THIS IS A NEW ONE ON ME........
I WOULD THINK THAT THE LIGHTS ARE NOT GROUNDED CORRECTLY ..IF YOU HAD THE SYSTEM INSTALL (THE SECURITY LIGHTS,AND SECURITY) BY A COMPANY ..THIS IS THE THERE PROBLEM....
.....SOUND'S LIKE A GROUND TO ME THE MORE I THINK ABOUT IT GOOD LUCK
Posted on Feb 21, 2009
I have outdoor security lights that run on a timer. Are there some that use a motion detector?
Yes, in fact most people have motion-detector activated lighting so they can know if there is suspicious activity outside of their home. Many security companies also offer systems that allow you to operate the lighting at your home from a smartphone or personal computer, which can help save electricity when it comes to outdoor lighting.
May 09, 2013 | Home Security
Ds 924 motion detector
It may have been previously learned into a zone. Sometimes, the motion will trip and activate a signal that can be learned into another zone you are trying to program. exit programming, then "tamper" the cover for the circuit board, not the battery access, on the motion, check the "status" light to see if a zone is displaying "tamper". Also check battery orientation in back of motion. When battery is first installed correctly. The light should activate during the first minute.
Sep 15, 2017 | GE 60-511-01-95R - ITI Wireless DS 924...
Why does motion sensor not fully illuminate a fluorescent 4' light?
many motion sensor do not work with fluro tubes as stated on the fitting instructions as it has the same affect as you turning the switch on and and on to change from auto to manual operation
the problem comes from the ballast and the starter operation
Jul 04, 2017 | Heath Zenith Occupancy Motion Sensor Wall...
Light stays on all of the time will not turn off
Adjust the timer setting under the sensor it might be set to zero you shuld adnust to about 3 minutes or desidered time if set to minimum light will stay on if this does not help change unit its faulty
Sep 25, 2017 | Heath Zenith Secure Home Motion Activated...
I have two outside motion detector lights acting weard
I don't know what type of sensor you have , but most have a sensitivity and range adjustment on them, I would turn one or both down and see if that helps. Also make sure the sensors are not aimed at each other, the heat from the bulbs on the other fixture can cause the opposite fixture to trigger on & vise- versa. Good Luck
Jul 04, 2010 | Home
Motions don't stay active when doors and windows are on too.
The system is working as designed. If you arm both doors/windows and motions, but you DON'T exit the premises during the exit delay, the system will "downgrade" its arming to doors/windows only. The assumption is that you haven't actually left the premises and are at risk of creating fale alarms. This behavior can be disabled in System Configuration (though it may require the dealer access code to do it).
Try opening and closing a sensored external door (even if you don't go outside) during the delay after arming doors+motion and see if the motions don't stay active.
Jul 12, 2009 | GE Security Simon 3 Wireless Home Security...
GE Simon XT panel lights window, door and motion indicators
It sounds like the auto-stay arming function. Try arming it and opening and closing the door.
Feb 10, 2009 | GE Security Simon 3 Wireless Home Security...
Magnum S9 Base CB Radio Logo
146 people viewed this question
Top Magnum Radio Communications Experts
Jim Goldsmith
Jim Goldsmith
James Walker
James Walker
Are you a Magnum Radio Communication Expert? Answer questions, earn points and help others
