Question about Denon DVD-2910 DVD Player
Red goes out
My player loses red intermittently; displays only in blue and yellow.
    President:
  • 3,130 Answers
How is the player attached to the TV set. If its with a scart cable or the R,G,B plugs, there is a loose connection in the cable or plug itself, or the connection inside the TV set or on the printed circuit board inside the DVD player. You should be able to make the problem happen by moving around the cables. if it does not, them maybe the TV set has a loose connection on the CRT socket or the player has a fault in the color demodulator circuit.
Posted on Dec 27, 2006
Yellow, red, and blue wires. Where does each go? Kenwood KDC-322
yellow wire is memory wire goes to 12 v source that is always on red wire is the ingtion wire so when u turn on key its turns on that goes to a ingtion source the blue wire is ethier amp or ant wire
May 22, 2010 | Kenwood KDC-322 CD Player
Movie has no red color only green and yellow
Remove & re-seat the component video cables at both the TV and the DVD player.
If the problem continues, disconnect BOTH ends of the BLUE cable and the RED cable. Connect the BLUE cable to the RED jack at both the DVD and TV, and connect the RED cable to the BLUE jack ob both the TV and DVD. If the RED color comes back and the BLUE is missing, then replace the RED cable (the red cable is broken and will not pass the signal that it is connected to).
If all works, reconnect the colored cables to the corresponding colored jacks at both the TV and DVD player.
If the RED color still won't display, isolate the trouble to either the DVD player or TV by connecting the DVD to another TV w/ component jacks. If the RED is still missing, it is a problem inside the DVD player - if the RED displays, it is a problem with the TV.
Sep 30, 2009 | Sony DVP-NS501P Progressive-Scan DVD/CD...
Wii display black/ white only
I had this problem too. It was just because I had the wrong cord that goes from the Wii to the t.v. I had a green, blue, and red for the video. And a red and white for the audio, while my T.V. only took yellow for the video. I just went out and bought the right cord that instead of having green, blue, 2 reds, and a white, just had a yellow, red, and white.
Hope this helps.
Aug 23, 2009 | Nintendo Wii Console
Cda 7949 turns off/on by itself
Sounds like a lose wire in the harness either yellow, red or black. Pull radio and shake the wires around untill you find it or the face plate is lose.
Jun 04, 2009 | Alpine CDA-9856 CD Player
How to connect to TV
The Yellow/Red/White connectors are Composite+Audio
Yellow carries a composite signal and Red and White Carry left and right audio channels.
Red Green Blue Connectors are Component
Each coloured connector carries one 'component' of the picture
So yes, your extra set of red white yellow cables would be fine to use, just make sure you connect the same colors at each end red-red green-green blue-blue
However..... the red green blue only carry the video, you will still need to carry the Audio, this is usually done either by the red and white (L & R stereo) or your DVD may also have an optical or coaxial output to carry the sound. if there is no equivalent connector on the TV then you may be stuck swapping the red/white cables, usually though there would be 2 sets of red/white connectors one set to go with the yellow, one set to go with RGB.
Apr 22, 2009 | Televison & Video
Red wire missing
the power wire goes above a blue wire or next to (white/orange) and (green) in top row if there is a space there
yellow should be above black
(white/orange) should be above (blue/yellow) i think
than red over blue
hope this helps
Jan 11, 2009 | Pioneer AVH-P6400CD Car DVD Player
Unable to properly connect sony dvd to tv to play movie
DVD-3 RCA phono outputs(red & white=audio,yellow=video
I have a DVP-NS700,the same happens on mine.Turn it on,goes green to red(standby),then press eject,it will then power up properly.
Jan 03, 2009 | Sony DVP-NS300 DVD Player
RCA Pearl TH1100A backlight colors
Pp. 16-17 of your user's manual:
http://www.rcapearl.com/pdf/TH11xx_IB.pdf
Settings
Press forward to enter the Settings menu and then
press plus or minus or to highlight an item. Press play
repeatedly to change settings.
Backlight:
• to adjust the time before the display light
turns off (On/10s/20s/30s).
• to adjust the color of the display light
(Red/Blue/Green/Yellow/Cyan/Purple/White).
-Tha Mp3 Doctor
Dec 13, 2008 | RCA TH1101 MP3 Player
Don't keep memeory
follow this code:
Black-----------ground
Red------------12V Switched (ignition)
Yellow---------12V (constant)
Blue------------power antenna
Blue/white----Amp turn on
Orange--------dimmer
White----------Left front+
White/blk-----Left Front -
Gray-----------Right Front+
Gray/blk------Right front-
Green---------Left rear+
Green/blk----Left rear-
Purple---------Right rear+
Purple/blk----Right rear -
In a grand-am the radios yellow goes to the cars orange and the radios red goes to the cars yellow.
1998 Pontiac Grand Am Stereo Wiring Constant 12V+ Orange Switched 12V+ Yellow Ground Black Illumination Gray Dimmer Brown Antenna Trigger Pink Antenna Right Rear Front Speakers 4" x 6" Doors Left Front (+) Tan Left Front (-) Gray Right Front (+) Light Green Right Front (-) Dark Green Rear Speakers 6" x 9" Rear Deck Left Rear (+) Brown Left Rear (-) Yellow Right Rear (+) Dark Blue Right Rear (-) Light Blue
May 13, 2008 | Alpine CDE-9843 CD Player
Deh-1950
yellow 12v + constant blue power antenna red accessories
Dec 15, 2007 | Pioneer DEH-P430 CD Player
Denon DVD-2910 DVD Player Logo
85 people viewed this question
Top Denon Televison & Video Experts
 Grubhead
Grubhead
Are you a Denon Televison and Video Expert? Answer questions, earn points and help others
