LF speaker in EVP X makes strange noise
D-644 LF speaker in my EVP X makes strange noise when volume is up
and music has full bass or drum peaks.
After opening the cabinet and disconnecting the speaker I saw that lower part of the cone is disconnected from metal base.
Any suggestions on how to fix it, glue it..????
thanks a lot
  • ashokanandpu Nov 21, 2008
    It is a Wharfedale EVP X-15 speaker, not a receiver, in question. And yes I still need a solution for this problem.
    Ashokanand
  • 624 Answers
SOURCE: Loud and strange noises
The built-in speaker amp or the volume switch may be going bad on you. A quick test is to disconnect the speaker set and replace it with a headphone or another working speaker set. If it behaves normally then the problem is in your original speakers, if not then you may have software driver issues or less likely an issue with the sound card. Let us know what you find out.
Posted on Jul 28, 2007
james klgr
  • 362 Answers
SOURCE: Sharp Aquos rattling bass
the sharp some models dont put a spacer between the speaker and the case causing the speaker to hit the case at med to high volume you can check this and make you a spacer out of washers on each screw that mounts the speakers between the case and peaker frame make sure that the washers or spacers you use dont contact the speaker core. and dont do anything that will void the warrenty if nothing else let the store fix it.
Posted on Dec 12, 2007
  • 1694 Answers
SOURCE: Denon AVR-1601 Receiver
Check capacitors in power supply......also check for over-heated
resistors..all 1 ohm.....replace if cooked...................T.
Posted on Jan 05, 2008
SOURCE: The bass speaker doesnt work
OK, Bose owners out there listen up and listen good. Here's the real scoop on 1.(getting access to the inside of most bose subwoofers, 2.( repairing said subwoofer.
Follow these steps in removing the cover of your subwoofer. Unscrew the two screws from the cover. (They are on the input/output side of the cover) Remove the two knobs (Bass and treble volume).
On the opposite side of the cover, (put those damn shoes back in the closet) there is a lockout tab that needs to be swung out, it moves 90 degrees in a counter-clockwise direction and is located under the center of the cover.
A small flat blade screwdriver works great for swinging this tab out and will be necessary for the next step (the screwdriver that is).
On the same side (opposite the input/output side) there are two small tabs near the edges of the cover, one on the right and it's counterpart on the left. If you look closely in the gap between the cover and the sub itself, you will see these 3/8" wide tabs near the edges and towards the top of the cover.
With the flat blade screwdriver, put the blade between the cover and on the tab and pull down. Then with your hand balled into a fist, gently hit that side of the cover towards the input/output side. the cover will move only slightly but the tab should remain depressed.
Do the same procedure on the opposite side of the cover and it will slide about a 1/2 to 3/4" towards the input/output side and can then be removed by pulling it straight up and off of the cabinet.
Yay! If you get this far without incident then you are ready to implement repairs. In the case of the AM15's, normally what happens is a resistor will open up and prevent the triac (turn-on device) from firing.
The fuse is on the underside of the PC board and this above mentioned resistor is a 100 ohm, surface mount "chip" resistor on the top side of the PC board. It will not appear to be bad but trust me, if the fuse is good and the sub will not turn on... replace it!
You don't have to use a chip resistor since as a consumer you may have a rough time finding one but a 1/8 watt or 1/4 watt resistor you can find at any Radio Shack will work just dandy in this application.
Cut the leads short and solder the two cut leads to the pads on the circuit board where the chip resistor is currently sitting. The chip resistor will be black, about 1/4" long, 1/8" wide and have "101" printed on it's surface. On some models they used two 200 ohm resistors in parallel but the result is the same. One 1/4w axial lead resistor will do just fine. Plug it up and give it a try. (Before you replace the cover).
Secondly, if the fuse is blown on a "Lifestyle" Bose subwoofer, contrary to popular belief, it blew for a reason. The speaker outputs and the subwoofer output devices are TDA7294 IC's with TIP142 and TIP147 Motorola transistors used as current supplements to these said output devices. If the fuse is blown and replacing it only results in another blown fuse then chances are good that one or more of these are blown. In some cases it's very easy to tell, the front of these IC's will be blown off and/or you will see burn marks on the board where they are mounted. These devices are located inside the amp portion of the subwoofer. (The black metal heatsink underneath the input/preamp PCB. As a consumer, if the fuse is blown, unless you are familiar with soldering techniques and troubleshooting electronics, leave this to the pro's. It isn't as easy as you might think and you can destroy the PCB in your attempts to repair it.
 This was from a Guru of Bose systems at ecoustics.com: Mark Burgess
Posted on May 11, 2008
tech48
  • 624 Answers
SOURCE: marantz sr 4200
This is an indication of some bad solder connections on one of the boards. It could be the power supply board, amp board, or the digital board. I would like to be more specific, but this is not a common problem with those symptoms. Bad solder connection are a common problem and can cause many different unusual symptoms. Unless you have excellent soldering skills, it would be best to let a service center repair this for you. This is a very good receiver and is well worth getting fixed. If you have excellent soldering skills and are willing to take a chance on fixing it yourself you could save yourself some money, but be aware that if you make even one mistake while soldering, you could easily cause much more damage than you started with. Some of the components that may need to be resoldered are surface mounted IC's that are very difficult to resolder and if you have never done this before it is not a good idea to start learning how to solder on such a nice receiver.
Let me know if you need any further help.
Dave
Posted on Oct 27, 2008
Can you please tell me the best amp that I can use to hook up a Roland SPD 30, I'm looking for one to get volume. ( loud ).
Hi, With my sound engineers hat on I would use a small PA. mixer, amp and speakers!!!!
For quality you need a full, flat frequency range system with good headroom.
I assume this is for your own listening, when using an acoustic kit?
There are one box solutions.
  1. Drum amps. Like a monitor wedge with an amp, Roland do a PM-10, Various other makes are available.
  2. General purpose powered wedge.
  3. Keyboard Amp, these are full range and available in various sizes.
  4. Bass amp with high frequency driver (tweeter), not the best but will have good bottom end.
  5. Powered or active speaker, much like a powered wedge, but a different shape, needs an input volume control.
All these systems need to have large bass units, 10 inch minimum, and will be in mono. Two will give you stereo,
How loud depends primarily on the sensitivity of the speaker. But manufactures insist on selling things by power. Worth looking this up.
At a couple of feet away, 20 watts should do it, with high sensitivity speakers, more likely you find most things as above start at about 70 Watts.
Good luck, I hope I have widened you choices a bit.
All the best, Chris the Fader.
Oct 03, 2014 | Roland Spd-30 Drum Pads
My 200hd head is not putting out the full 200 watts i have a behringer 8x10 cab and before this head used to power this cab fine now even with the volume cranked you cant even feel the bass i have...
I am not sure how you are measuring the power output to verify it is less than 200 watts. With a true RMS voltmeter you should see 28.28 volts RMS across a net speaker load of 4 ohms. If you use only one 8 ohm speaker, you will get 120 watts. If you are getting the 28 volts there is nothing wrong with the amp. You MAY have blown the speakers OR not generating much bass due to processing in an EQ. I assume you are using at least 15 inch speakers if you want to feel bass. Look up your speakers specs... you will need speakers capable of 32 Hz to feel much. With this amp your speakers should have aa total rating not less than 400 to 600 peak watts or around 300 watts RMS continuous power rating. Using a lot of high end EQ will keep the amp busy at the high end and reduce the power available at the bass end.
May 06, 2011 | Kustom Deep End 200HD 200 Watt Bass Amp...
I have just run a bass test and I am getting bad vibration noises from one of evp subs the sub works but seams to crash at certain frequancies
Over-driving or resonances can be unpleasant and intermittent. Decide which you have. Find some music that causes the symptom.
If you haved two identical subs the diagnosis should be easy enough. Swap them physically.
Lower the volume. Problem solved?
Move the sub around the room to see if it changes for the better or worse. Room boundaries and YOUR position relative to the speakers play a huge part in bass response.
Maybe the speaker cone is damaged or the voice coil is separating.
Mar 06, 2011 | Audio Players & Recorders
My sub make a strange noise. It doesen't work anymore.Tks.
Strange noises can come from your amplifier or the sub itself. The most likely cause of the strange noise is the speaker just before it dies! If you have been using the sub-woofer at high volume levels then you probably have damaged it. Try testing the sub-woofer using a multimeter(on ohms setting) it should give you a reading from 8 to 4 ohms. Sometimes they may give readings as low as 1 ohm. When testing the speaker/sub you should hear a soft scratchy, thumping or clicking sound. This indicates that the speaker may still be working. If you don't have a multimeter try a 1.5 volt battery (say a AA), DONT USE HIGHER VOLTAGE BATTERIES they may damage the speaker! You will hear a clicking, scratching etc sound from the speaker which may indicate that it is still OK. If the speaker seems OK the problem may be in the amplifier, which I suggest you bring to a professional repairer. When buying speakers and amplifiers make sure the power handling of the speaker is equal to or greater than the amplifier output power. This should stop speakers from getting damaged. Make sure the speaker and amplifier specifications are rated in the same manner ie RMS PMPO Peak. A 100 Watt PMPO speaker will not survive the output of a 100Watt RMS amplifier!
Feb 08, 2011 | Audio Players & Recorders
Im a candidate sound engineer, im strugling to set the bass drum from the mixer. how do i set it?
Bass drum by convention is ch1 on the board.
You need a good drum and a good mic
First set eq flat and pfl ch1, set gain control so drum just hits peak/or red when hit hard.
Send ch to drum group (1+2) on board, or route to master (L+R), depending on type board. Then listen to drum ONLY through the system, and adjust eq so it sounds good at low level then turn it up and keep it sounding good.
If it keeps peaking the ch then turn down gain.
There are toys (inserts) you can use noise gates and compressors if available,
Sound is objective and can not be learnt without doing it , good luck. remember good low level sound will always be better than really bad lound sound, start low make it good then make it loud.
Good drums do not need much eq. Get the drum right first.
Hope this helps
Thanks for using FixYa
Aug 06, 2010 | Samson SX1200 Amplifier
How can i get more power through 8 ohm speakers?
In addition to the impedance rating of a speaker, there is also a wattage rating. Ideally, power output of the amplifier should not exceed the power handling rating of the speakers. The input impedance of the speakers should match the amplifier output impedance for maximum power transfer (Rin = Rout where R is resistance in Ohms). Supplying more power or wattage to the speaker than it can handle will result in distortion, and if the output of the amp is high enough and present long enough, it will damage the voice coil of the speaker. Make sure that when comparing wattage ratings, you are comparing the same rating between amps & speakers. Watts can be expressed three different ways: "Peak", "Peak to Peak" and the industry standard "RMS". The relationship is such: an industry standard value of "70 Watts RMS" (70W RMS) equals "100 Watts Peak" (100W P) *and* also is the same as "200 Watts Peak to Peak" (200W P-P). Furthermore, there is no such thing as 200W "Music Power" (but is often expressed this way to inflate the RMS wattage rating (and usually is close to the P-P rating). A speaker is an electrical device, so most the things that happen to electrical devices when over powered can happen to speakers and amplifiers, too.
Increasing the signal source level (input signal to the amp via volume control) in an attempt to get more audio power to the speaker can overdrive the amplifier - resulting in "clipping". This is plainly heard as "muddied" sound. The otherwise loud, crisp, clean passages in music end up sounding garbled and unpleasant when an amplifier is over driven in this way. This can damage both the amp and the speaker.
Cheap amps with higher THD (total harmonic distortion) ratings sound worse than their counterparts with a lower THD rating - when all other variables are the same. You'll pay extra for lower THD values.
You might be able to make a speaker seem louder by positioning the speakers against a wall, on the floor, etc. Experiment; as it can make a significant difference in sound levels and low frequency bass sounds.
I hope this was helpful!
Jun 11, 2010 | Yamaha Emx62m Powered PA Mixer System
My speakers make almost no sound at max volume. However if you listen closely, the music still plays, its just not amplified. How can i check the amplifier?
if you are wanting bass adjust your amp settings to low pass. if you are wanting a lil bass- a lil treb- adjust your amp to full. and make sure your rca cables are hooked up in the proper spots.
Feb 08, 2010 | Car Audio & Video
Yamaha DTXtreme IIS Drum Moduel repair
Listen to the output with headphones to check for noise.
OFTEN the output of a drum machine is CORRUPTED by an inadequate sound system. The waveforms generated by a drum machine tax the sound systems. A bass drum output can drive the speaker cone such that it goes beyond the linear range that the speaker and amplifier can handle and this appears as "noise". The noise may sound like a buzz or totally break up.
Turn the volume down and see if EXACTLY the same noise appears at low levels. If not, then saturation of the amp and speaker is likely. Continued use while it is doing that will often destroy the speaker.
Nov 28, 2009 | Yamaha Music
I have a rumble 100 bass amp which used to work fine until now! I've had it about 2 months and have only played it about a dozen times. Today, while practicing with a new band, 90% of volume got lost. Now...
It unfortunately sounds like a blown speaker. Try getting at the speaker and gently moving the cone with your fingers. If you feel a rubbing sensation you will most likely have to consider a new speaker. Make sure you get one with the same impedance (ohms) and the same or better power handling.
Jul 07, 2009 | Nomad Factory Fender Rumble 100 Bass Combo...
Sub issues
Would suggest that the power amp in side the speakers havs failed. Try to plug the speakers into a ipod then you can prove if tis the speakers or the Pc.
Jul 25, 2007 | Philips MMS171 Computer Speakers
56 people viewed this question
 Grubhead
Grubhead
