Question about Compaq Presario 700 470024-192 Notebook
Disc drive problem
When we insert a cd/dvd in to the system, the sytem does not show anything about cd or dvd. some noises is coming from the disc drive.
    Genius:
  • 1,124 Answers
I have G900 i want to transfer me pic from phone to comuter but once i plugged comupter is not showing anything .i wait long but nothing happen .please help .
You G900 comes with a software CD, DVD or a mini disc. Insert it in the computer CD/DVD drive and install the software. If you cannot find the disc in the packing then you must download this software from the sony erricson website.
http://www.sonyericsson.com
Jul 30, 2011 | Computers & Internet
My computer will turn but it only shows a blank screen with a flashing dash in the top left hand corner. Can you help?
Insert your system recovery disc to repair your startup.
1. Change your Bios to boot from disc:
When your computer powers on, hit F2 (on some computers, F8 on others). Use your arrow keys and move to the right to your BOOT option. Hit the down arrow until you select your CD/DVD drive. Look at the bottom of your screen, and it should say to change the option hit F7 or F8. Use the specified keys, and move your CD/DVD drive above your hard-drive. Save your settings.
2. Boot from your disc. Insert your system recovery disc and restart your computer. Let the recovery disc load. If the option comes up to hit any button to boot from CD/DVD, then hit any button. Once it loads, it should come to a spot where it wants your language, then select the option "Startup Repair". Click on it, and let it repair the startup. Restart your computer, and hopefully it will boot from your hard-drive correctly.
Hope this works.
Chadlnrd
P.S. If it continues to boot from your recovery disc, then using the same method in step 1, go to your bios, and move your CD/DVD drive below your hard-drive.
Feb 28, 2011 | Computers & Internet
I put in a cd and it now wont recognize the drive at all. i can't get the disc out, no idea how to fix it
Hi Laurenleighd
Have a look at your CD/DVD drive and you will see a small pin hole that about the size of a needle. You can take a straightened paperclip and push it in there to open the CD dirve manualy. After you've removed it, try another CD that you know is working and see if you have the same problem. If this CD also get stuck in there then we know the CD/DVD ROM may be faulty.
Is this a Dell Laptop or Desktop?
Can you open and close the Drive with or without anything inside it?
Can you hear any noise coming from CD/DVD ROM when you insert a CD?
What Happens when you insert any other CDs or DVDs that you know is working fine?
When you open your MY Computer/Computer in the Start Menu, Can you see the drive there, or is it not showing the CD dirve there at all?
If the you are 100% sure this is not a power issue, then it might be the CD/DVD driver that needs to be re-installed.
Hope this helps
"Even your Computer needs a rest"
www.thecomputerspa.co.nz
Hope this helps
Jan 31, 2011 | Dell Computers & Internet
I put in a blank cd and I cannot burn it because in my computer it shows that there is no cd inserted
Here you go...I hope this works for you....
CD/DVD Is Not Recognized
spacer.gif spacer.gif spacer.gif spacer.gif Many times, after inserting a disc into the CD or DVD drive, the disc is not recognized by that drive. CD-read and DVD-read issues can be caused by many sources. Perform the procedures presented in this General Computer Advice article when troubleshooting CD-read and DVD-read issues.
Begin with the first procedure and continue through the list. Try using the CD or DVD after each procedure is completed. For any procedure that requires changing current system settings, record the original settings before completing the procedure.
  1. Verify that the correct disc (CD/DVD) is used when prompted to insert the disc.
  2. For programs on DVD, verify that the drive containing the DVD is a DVD drive and not a CD-ROM drive. Most DVD drives will haveDVD printed on the front of the drive. For programs on DVD, consider the following:
  • DVD drives can read both DVD's and CD's.
  • CD-ROM drives can read only CD's.
  1. If multiple disc drives (e.g., CD-ROM and CD-RW, or DVD and DVD-RW, or CD-ROM and DVD-RW, etc.) exist on the computer that can read the disc (refer to the items under Step 2), insert the CD or DVD into the other drive and try the program again.
  2. If you are attempting to install a program and the installation does not begin after inserting the CD/DVD into the proper drive, refer to the program's instructions for the installation procedure.
  3. Clean the CD/DVD in the following manner:
  1. Place a small amount of nonabrasive liquid soap on the shiny side of the CD/DVD.
  2. Using your fingertips and warm water, gently rub the soap on the CD/DVD in a circular motion.
  3. Rinse the CD/DVD thoroughly and dry it using a clean, soft T-shirt or lint-free towel. (Do not use paper towels or tissue paper.)
  1. Try to use a different CD or DVD in the drive to see if that disc can be read.
  2. If possible, insert the problem CD or DVD into the DVD or CD drive of another computer to see if the issue persists.
Apr 01, 2010 | LG GSA-H55N DVD-RAM Burner
DVD Writer not recognizing DVD
the drive is not recognizing any dvd. this happens when you insert dvd into cd drive. if this happens with dvd drive its factory malfunction probably so if you can-replace it
Oct 02, 2009 | LG GSA-H55N DVD-RAM Burner
Wont boot
go to BIOS and enable the secondary drive auto detect.
if you manaully set the drive to primary, secondar. the system should be able to detect it as you have set it. if you select cable select or auto. the sytem will put the drive connected to the end of the IDE cable as primary.
Apr 02, 2009 | Intel Motherboard
NEC ND-6650A
well, sounds like common error promblem have you tried looking and seeing if mite have bought the wrong kind of dvd's I have done this before i bought dvd's instead of Cdrw's discs.? or try dowloading www.slysoft.com thier cd player plays and reads and rewrites almost anything .. lala linda
Jun 03, 2008 | NEC ND-6650A DVD RW Dual Layer Burner
Pioneer DVR-112D disc recognition
what i would do is install one drive as the master on ide 2, and the other as the slave on ide 1 and what OS are you using?
Sep 13, 2007 | Pioneer DVR-112D DVD RW Dual Layer Burner
Compaq Presario 700 470024-192 Notebook Logo
29 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
