Question about Sony KP61XBR200 TV
Sony KP61XBR200 - More info...
Additional information regarding the post by CoryK... The red convergence is not functioning, and no adjustment can be made via service mode. I replaced both convergence IC's (part number STK392-020), and still have the exact same issue. The E10R error code description is "sensor output level low", and indicates sensor number "0", which is the top center sensor. I've swapped the sensor out with another, and still get same error code, so I'm not sure how valid this error is. Looking for ideas. As CoryK mentioned, we are in the sticks, and a housecall from repair tech is last resort. Considering the wood in the cabinet to supplement home heating.
  • damisa Dec 06, 2007
    The red is out of focus. On the top left screen, the red curve curves down like a sinusoidal curve about 7 inches at its minimum point and is noticeable so I pressed Auto Focus button and I am getting a E10R on the screen.
  • anmivaca Feb 15, 2009
    I have a similar problem but with the GREEN color, after AUTO FOCUS runs, I get a E 14G code, and I have a sinusoisal form of the green color in the upper and lower part of the screen.
    What should I do ? What part should I buy ? and where ?
    Any help will be appreciated.
If a output IC is bad it will usually open a pico fuse. These IC's do fail a lot. These fuses are near the IC's.
Posted on Jul 04, 2007
Convergence adjusting
Using the original remote go into your convergence menu and try to adjust red and blue. if they will not adjust you will need to get a convergence repair kit from sites such as www.TvRepairKits.com to fix it. Note that some sony models will not have a convergence menu...if that is the case you need to go into service mode. You can get that info from the same site above - its on their tips page.
May 04, 2012 | Sony KP-46WT510 46" Rear Projection HDTV
I hav a RCA model D52W25 its 52" it has convergence problems dont know how to setup the color things can u help??
Click on the following link :
http://www.riddledtv.com/repair/RCA.html. Go to the following section
(2) (3) (4)
(5) Stretched Image at top and bottom edge very distorted. Reheat all the surface mount solder points on the Small Signal Board. Then realign the set including convergence menu. To enter service mode: power off the set for 10 sec, then hold down Vol- and Ch- buttons for 10 sec. See this link: Alignment Procedure (pdf)
Also download the Alignment procedure pdf file. Hope this will help you. Please let me know if the information was of any help to you or you need further assistance.
Thanks
Oct 08, 2008 | Televison & Video
Sony trinitron colors(red,green,blue)are offset by 1" so it looks like there's 3 pictures on the screen.
Without a specific model to work on, would you pls check if the Sony has got a tripler, something similar to the one shown below?
If yes, try adjusting the white plastic knob and see if you can merge the 3 colors. Pls mark the original position to be able to revert to it if no significant improvement/change.
If not, pls post back exact model and additional info such as was there something done to the unit like repairs of some sort or anything out of the ordinary that happened prior to the color separation.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Jul 04, 2008 | Televison & Video
Sony KDP-65WS550 65 in. Rear Projection HDTV One day turned on
This can be as simple as poor solder connections at the convergence ICs or defective ICs. If you can solder you can fiz this yourself. Let me know if you wish to attempt the repair and I'll suply additional details and instructions.
Dan
Mar 24, 2009 | Sony Grand WEGA KDP-65WS550 65" Rear...
Trinitron suddenly turned itself off.Now doesn't go on.
Hi again,
I was just checking similar problems and saw that you posted twice.
Pls see your other post here with my proposed solution.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information. Good luck and kind regards. Thank you for using FixYa.
Nov 15, 2008 | Sony KV-27V40 27" TV
Unsuccessful autofocus followed by E15R code--red curves out at corners
this is a problem of the crrt tube inside your tv..... there wil be major problem this tube,..... only because of this, the pictures r noyt clear....
http://www.devicemanuals.com/guide/Television/Sony/Sony-TV-Projection-KP61XBR200-User-Guide-TXpRNE9UZz.html
dwnld the user manual frm here and change the crt tube
Jun 07, 2008 | Sony KP61XBR200 TV
Red convergence out of alingment
If you cant adjust it with the convergence option on the menu you will need new ICs. They are inexpensive. I can post a link where you can get replacement ICs and free step by step instructions on how to do the repair yoursel. The Conversion ICs will have STK numbers such as STK392-110 or simallar There are two of them identical attached to a large heat sink.
Mar 30, 2008 | Sony Grand WEGA KF60XBR800 60" Rear...
Red Convergence on JVC AV- 65WP74
convergence amp ic bad
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Sony Convergence
http://www.techlore.com/blog/entry/19694/Sony-Convergence-Repair-My-Sony-TV-has-a-distorted-picture-/
http://www.techlore.com/article/19631/Sony-Convergence-Procedure/
Jan 28, 2008 | JVC AV-65WP74 Rear Projection Television
Convergance problem red, and green won't adjust
this is a common problem for all projection TVs the convergence ICs need to be replaced. Its an easy fix if you can solder. Let me know if you need further information or a link to where you can order replacements.
Nov 10, 2007 | Akai PT4298HD Rear Projection Television
57H81
yeah common problem with the convergence cir get a tech to fix your converg 2 ics will be replaced it is labor time consuming now dont try the auto focus or will be worse
Sep 04, 2007 | Sony KP61XBR200 TV
Sony KP61XBR200 TV Logo
191 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
