Question about Edirol UA-4FX External Sound System
Edirol UA-25 not working on Mac OS X
I have bought a new mac and plugged in my Edirol UA-25, to use with Garageband. It appears completely dead. USB is plugged in, midi keyboard plugged in all as before. I have plugged in a mic and I can see the signal ending up in Garageband, but there are no lights on the Edirol and the midi keyboard isn't picked up at all...please help! Thanks...
I had the same problem. When I installed the Edirol software it prompted to 'reboot' and when it restarted all the lights on the Edirol came on.
Why don't you try it like that.
Hook up the Edirol Install the software Reboot
Best of luck Victoria
Posted on Jan 01, 2009
SOURCE:
Steinberg CI1 USB doesn't light up when plugged in
I restart with the CI1 plugged in) but I can't 'get it' in Garageband. I've tried the Garageband preferences, and system Audio section, but there's no device to select there - only internal mic.
Be sure to get the latest update from Steinberg.net
And in Garageband you'll find your unit in preferences - input
Dec 16, 2013 | Cubase Steinberg CI-1 USB Studio Audio...
Do not get MIDI signal via EDIROL UA25
Midi is data only, there is no actual sound to the midi tracks themselves. They need to be assigned to either a software synth or an external synth to actually make the sounds you want to hear.
For instance if you load a demo of a midi sequance you will need to add a software synth such as the TTS-1 or Roland sound canvas which are general midi compatable and will play the instruments sounds assigned to the demo's midi channels. Use the Synth Rack feature in Sonar to open one of them. Then you will need to assign the output of each of the midi tracks to that particular synth and you will get sound. Make sure to assing the synth's audio track to you UA-25 as its audio output.
I would suggest reading in the manual and following the tutorials included in the manual to get yourself familier with how this is all done. spacer.gif
May 25, 2008 | Edirol UA-25 External Sound System
Have a casio px 320 and trying to use it in GarageBand on my Mac OS X. Connecting USB cable from USB output on Casio to USB input on Mac doesn't work. Any help?
use the audio output to send the keyboards internal patch sounds, or use a usb midi adapter to use the keyboard to trigger the garageband midi sounds, if the keyboard has a midi output, that is. the usb output requires software drivers to use, and IS NOT mac compatible. You may have to select a midi source in garage band preferences or settings if you are using midi.
Nov 14, 2010 | Casio Privia Keyboard Case
How to use a condenser mic on a mac/in garageband?
If you are sure that the microphone and the cable is OK, it could be that you're phantompower is to low.
Normally you need 48 Volt, you can check that with voltage meter between pin1-2 and 1-3 from the XLR.
regards,
Gerard
Jan 22, 2010 | Audio Players & Recorders
No sound being picked up by Edirol
I discoverd the the digital in button had been pressed in. This was the mic was not picking up any sound.
Jul 09, 2008 | Edirol UA-25 External Sound System
Edirol ua25 jack speaker output
Your are using powered speakers right? Or going into an amp and then the speakers, as the UA-25 does not have enough power to drive passive speakers.
Call Roland customer service and have them walk you through the device setup to make sure you've got everything right.
EB
Jun 06, 2008 | Edirol UA-25 External Sound System
Edirol ua-25 not detecting midi but audio works fine
**** THIS IS THE SOLUTION ****
On the back of the UA25 there's a switch called "Advance" - this needs to be set to ON for the device to work as a MIDI interface.
LC (UK).
Feb 27, 2008 | Edirol UA-25 External Sound System
UA101 and Blue Screen of Death
try this to make sure that the driver was installed correctly.:
Note: Do not use the “Add New Hardware” Wizard in the control panel. Follow the steps below to install your driver correctly.
1. Plug in the USB cable and power on the device – the New Hardware Wizard will start up (wait for it to start).
2. If Windows asks to connect to Windows Update, click on “No, not this time” and click on “Next.”
3. Select “Install from a list or specified location” and click “Next.”
4. Select “Include this location in the search” and Browse to the folder containing your driver (either on your CD or the folder you downloaded). Click “Next.”
5. Click “Continue Anyway” when the Windows Logo testing screen appears.
6. Click “Finish” when the Completing the Found New Hardware Wizard screen appears.
At this point, you may need to reboot your computer. After restarting, you should check to make sure the driver was successfully installed. Go to Control Panel / Sounds and Audio Devices and make sure your device is listed under “Sound Playback” and “Sound Recording” for audio devices and “”MIDI Music Playback” for MIDI devices. You should also check in the Device Manager to make sure your MIDI or Audio device is listed under “Sound, video and game controllers” with no problems (such as the yellow exclamation point).
If everything is successful to this point, Windows has installed the device correctly and is making it available to any software you need to run. If you can not see your device in your software, you should first try re-profiling the device (different software programs do this differently). If this does not work, you may need to uninstall and reinstall the software. If you still do not see your device, you may need to contact your software vendor for more help.
- Mac OS X -
1. Make sure the Roland/Edirol device and any non-essential USB devices are disconnected.
2. Run the *.pkg installer from the CD-ROM or downloaded driver and follow the onscreen installation instructions. When finished, reboot fully.
3. Plug in the Roland/Edirol device. Ports should now be available in software (you can verify driver availability in Applications > Utilities > Audio/MIDI Setup > MIDI Devices).
- Mac OS 9.X -
Users must first decide if they want to run OMS or FreeMIDI, which can be downloaded from the World Wide Web. OMS is recommended. See the OMS or FreeMIDI documentation for installation and activation details.
Double-click the Edirol installer and follow the onscreen installation instructions.
Note: If you continue to have problems, you may wish to consider upgrading to OS X, as its Core Audio and Core MIDI features make this operating system an excellent base for music applications.
ALSO:
Product: UA-25 UA-101 FA-66 FA-101 UA-4FX UA-1EX
Pop/click/dropout is often a buffer size problem. Be sure to check your Buffer Size setting. You'll find it in the Edirol Icon in System Preferences or in the Control Panel of a Windows machine. Increase your buffer size until the problem goes away.
There are also several settings you will want to make in order for audio applications on a Windows XP computer run optimally.
One of the more detailed websites to walk through these settings is MusicXP.net.
http://www.musicxp.net/tuning_tips.php
Dec 23, 2007 | Edirol HI-SPEED USB (USB 2.0) Audio...
Edirol UA-25
A computer has line out and that means sound out from the computer to your speakers. A line out can also be connected to a recording device or a pair of speakers with an amp built in. Line in on a computer can be used to record audio from other equipment such as a Dj on his decks to record his set. It can also record audio from mp3 players etc. Line in can be used for mic's and also you can use mic in as well. To record any audio onto your computer use line in. Line out can also used for headphones and the mic will plug into mic in so you can talk online.
Oct 27, 2006 | Edirol Roland UA-25 External Sound System
Edirol UA-4FX External Sound System Logo
1,229 people viewed this question
Top Edirol Computers & Internet Experts
Ben Armstrong
Steve Allison
Steve Allison
Are you an Edirol Computer and Internet Expert? Answer questions, earn points and help others
