Question about HP PSC 1315 All-In-One InkJet Printer
HP 56 and 57 print cartridge
How to eliminate the memory built inside the HP print cartridge so that it will operate properly after DIY refilling those cartridges?
  • cat777n Nov 21, 2008
    it will reset the ink after refill can some one help
  • cat777n May 11, 2010
    it will not reset after ink refill how can you on the hp1315xi
Here's a link to a process I've used for many years now;
http://www.alotofthings.com/supportforrefillers/resettingthehpid565758.html
Just follow the steps and that's the end of your memory problem.
Posted on Dec 10, 2008
The problem cannot be solved even after downloading the HP cartridge compatibility software. The only solution is to buy a new HP cartridge to replace the old one which is still printing pretty good after refilling several times in a year. Perhaps it's the business tactics of the HP company which purposely setting some memory chips inside the all-in-one printer which can record the number of uses of any installed cartridges so in times it will reject that overdue cartridge and fail to respond properly. So the only way we consumers can do is to accept and pay if we want to use the product or curse them or just throw the printer away!!!!!
Posted on Nov 21, 2008
Had refill at Costco for hp 4620 printer 564 cartridge and now printer will not print in color. What do I do to make it print?u
That's means you didn't refill the colour ink properly.
Try this method, use the injection to draw any of the colour of about 2mm of the refill you bought, inject it into one of the tiny holes of the cartridge and draw a little back so as to remove the dirt in the foam inside the cartridge.. That's all
Aug 09, 2014 | HP Office Equipment & Supplies
I filled my hp 61 cartridges myself.I am having problems getting the ink to flow right,with the black cartridge
When filling cartridges yourself (i.e. DIY kits) you need to ensure that a proper vacuum prime occurs...often this is tricky if the internal foam is not properly 'wetted'. I suggest you take your HP61 ink cartridges to either Costco (most locations) or any Fry's Electronic Stores for ink refilling (typically ~40-70% cost savings vs. new cartridge cost)...the refill operators use a commercial grade ink refilling machine that preps, evacuates, cleans and then fills the cartridge automatically....followed by an electrical nozzle/jetting test. Anything goes wrong (at home) and you'll likely get a refund.
To find the nearest refill Costco store location and/or Costco pricing information, you can find this information at http://www.costcoinkjetrefill.com
For additional ink refill support information or advanced HP printer diagnosis/testing procedures for your printer model, please visit Inkjet411:
http://www.inkjet411.com
Aug 14, 2013 | HP DeskJet 1055 All-in-One Printer
WHEN PRINTING HP LaserJet P3005n Printer A MESSAGE TONNER REFILS, BUT TONNER FULL
Toner cartridge memory counts how many print outs passing through it, once memory sensed yield count crossed, printer will say that "low toner" , after couple of prints it will says to "replace the cartridge". If you refilled this cartridge with out replacing the memory printer will treats its old cartridge only.. Replacing the memory will solves your problem.
Ideal memory chip...
Sep 05, 2012 | HP LaserJet P3005n Printer
Printe shows out of memory HP LASER JET P1005
If its refilled cartridge, replace with new one & check, even its showing same error check cartridge memory contact unit located under the cartridge bank...Most of the cases we observed memory reader unit breakages happening. while inserting the cartridge it has to move to contact memory.. if its not moving properly results no contact between memory and memory reader.
Jul 20, 2012 | HP LASERJET P1005 Printer
I had my cartriges refilled and now its not printing correctly. actually printing in all yellow. I've tried cleaning the heads and turning off printer to rest. I've tried to align and clean printer heads....
Unfortunately in my opinion your cartridge has been compromised. Hopefully you did not pay for this service. You should replace that cartridge immediately. When it comes to cartridge "refilling" if you are not going to "do it yourself" don't even let someone else do the deed even for "FREE"
Nov 05, 2009 | HP OfficeJet 7310 All-In-One InkJet...
. HP 6210 all in one Kept printing till unplug
HP will tell you to never refill cartridges because they will not guarantee your printer will print properly with those refilled cartridges. If those refilled cartridges leak and cause damage to your printer HP will also not cover any repairs to the printer regardless of what sort of warranty coverage you have with them. Warranties only cover HP failures, not ones caused by using third-party or refilled ink cartridges. So, no it is not worth having the cartridges refilled - buy new HP-branded ones only.
Jul 25, 2009 | HP Office Equipment & Supplies
I have refilled my black ink catridge in HP PSC 1410 . now my printer does not print any pages . i have cleaned my printer catridges, still it's not printing any pages . plz tell me the detailed steps to...
Sounds like the printer thinks the cartridge is empty. Old PSC units had a 3 cartridge memory - you kept 3 cartridges and cycled them to trick the printer into thinking it had just received a brand new cartridge, rather than a refilled one.
Jun 16, 2009 | HP PSC 1410 All-In-One InkJet Printer
Replace electronic circuit.
How to eliminate the built-in memory in the HP 56 & 57 print cartridges so that the all-in-one will function again after DIY refilling the cartridges with ink?
Nov 06, 2008 | HP PSC 1315 All-In-One InkJet Printer
Ink replaced, but sows nothing
A yellow exclamation mark in any application means the attatched item to it is usually in error state, but you say the printer works fine. Most people would tell you to not touch what is working!!! But leaving anything showing error risks further confusion and problems. I think that you problem is probably very simple. Do you know hao to reset your ink levels. Read your manual that came with disk or go to the onscreen help. You may find this will remove the issue. If it does not, then you may have a corrupted driver etc, and may need to uninstall the printer, and reinstall it again. Good luck.
Aug 30, 2007 | HP Photosmart C3180 All-In-One InkJet...
HP PSC 1315 All-In-One InkJet Printer Logo
225 people viewed this question
Ben Johnson
