Question about HP Office Equipment & Supplies
My fax machine 'prints' out a blank page when I receive a fax. No hint of any ink, yet when I test my ink cartridge it tests as full.
    Genius:
  • 2,120 Answers
The ink may be dried out inside the cartridge. Try cleaning the brass parts of the cartridge with SOAPY WATER or replace the cartdridge.
Posted on Nov 20, 2008
Can send faxes but cannot receive or copy pages come out blank but ink cartridge is saying full
the cartridge is coagulated and it cannot print. , so better remove it an dip it mild hot water for few minutes and replace it after wiping it would work properly . it worked for me.
May 08, 2011 | Samsung SF360 Plain Paper Inkjet Fax
My hpf44880 printer prints out blank sheets of paper what do I need to do to get it to print with ink on the paper?
please follow these steps:
1.please print a test page from printer(hold down power and cancel(red X)buttons for 3 seconds together and release both of them..it will print a test page
2.if it is blank :please take out the cartridges.
clean the metallic contacts with lint free cloth
clean the ink cartridge slots with a cutip
disconnect usb cable
unplug the power cable from the back keeping cartridges out
hold down power key for 30 seconds
reconnect power cable
reinstall the cartridges
3.print a test page again from printer if printer is quiet
4.if the test page is still blank..u need another set of cartridges
5.if test page isn't blank and u print blank pages from computer,do the following:
6.if printer s/w is already installed..please go to devices and printers(printers and faxes in win xp)
7.please click on add a printer
8.select driver manufacturer as HP,and driver as deskjet 990c(this is the generic driver for all HP printers)
9.follow the onscreen instructions,and finish installation
10.try printing with this driver
Jan 24, 2011 | HP F4480 All-In-One Printer
Printer has full ink cartrage. When I print something the printer runs and works but the page come out blank
if you have a printer fax machine the problem might simply be inserting the paper in the correct slot. Unfortunately, the directions for some printer are really lacking .... i would try putting the paper in what might seem to be the fax slot. Another possibility is that the ink cartridges are not opened... the silver foil need to be removed before loading... Some printer have a print test button that sets up the printer to work properly I would try that as well. Hope this is helpful
Jul 12, 2010 | Office Equipment & Supplies
No blank ink being printed or received by fax.
the m/c needs the 5 tank for faxes!Is it a canon cart?The head might be blocked!Go to your printer properties and under maintanace do a deep clean!!Good luck!!
Mar 31, 2010 | Canon PIXMA MP830 All-In-One InkJet...
Hp 1040 ran out of paper/after restocking now prints blank pages
Even though the toner was shown at 1/2, I had the fax machine operator install a new cartridge. Problem solved!
Aug 24, 2009 | HP Office Equipment & Supplies
Fax will not print test page comes out blank
Try another cartrige or clean the contact points of your print head.
Jul 29, 2009 | Samsung SF-350 Plain Paper Inkjet Fax
HP 640 Fax series not printing
If it is a color printer, try printing just grayscale or black& white.  It is is already set to print just b/w, try printing in color.  Basically you may be out of ink.  Run the printer utility to clean the heads and see if anything changes.  A new set of cartridges should fix the problem, I believe.
Hope this helps...
~enov8
Feb 16, 2009 | HP 640 Inkjet Fax Machine
Printing Blank Pages
Try checking the ink cartridges and make sure they have ink in them or it will keep printing blank pages. Then try printing a test page by going to control panel, clicking on printers and faxes and right clicking on your printer and going to properties. Then go all the way down to the bottom of the page and click print test page. It will clean the printer cartridges and align them to print correctly. It should work after that.
Nov 08, 2008 | Lexmark X4270 All-In-One InkJet Printer
Cant receive faxes
First make sure your line cable is plugged into the correct place. Most Brother machines have a plug for Line and a plug for Extension (EXT), make sure it's plugged into "Line".
Go into the menu on your Brother machine and select Fax, then Setup Receive and then select Easy Receive. This will usually solve most recieve problems.
Brother machines come with s default of 4 rings before they will answer, make sure none of your other devices (such as an answering machine) are set to a lower number of rings or the fax machine will never grab the line.
If you have distinctive ring, make sure you have it set up in the machine. There is a section in the owners manual for setting up discinctive ring.
If the machine grabs the line and goes through the motions but nothing comes out on the page (no black print) then make sure you are using a Brother ink cartridge (not refilled or generic) and print out the test page using the "ink" button. Allow the machine to clean a few times and see if the test page prints out correctly. If you are using refills or a generic black, you might have premanently damaged the print head. In this case take it to a service centre to have the head tested.
Sep 10, 2008 | Brother IntelliFAX 4100 Laser Fax
Machine does not print
check ink cartridge head is it dry ? put on a peice of tissue does it stain it? if no then head is dried out. replace.
clean contacts w/alcohol
run print test a few times.
Jun 25, 2008 | HP 1040 Plain Paper Inkjet Fax
117 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
