Question about Honeywell HE220A1019 Whole House Humidifier Humidifier
Water leak The humdifier leaks water out the base of the unit. The drain line is clear and water is going through it. The water appears to be coming from the right side of the filter holder. If I remove the cover on the humidifer the leak stops.
Sounds like the air flow is too great and it is blowing the water in the bottom of the tray around before it gets a chance to drain. Try placing your summer, winter damper at half closed to slow the airflow down a little.
Posted on Nov 26, 2008
Water leaking / running from top of humidifier
humidifiers have a drain and if there is water going in it will be coming out the drain. check drain to see if it is clear, check hoses going into top of humidifier for cracks, check filter in humidifier.
Feb 05, 2014 | AutoFlo 250 Humidifier
Water drains into air return & onto floor
Hello, usually this is a sign of a drain problem or the water is entering the humidifier too fast. If the water is not draining at the end of the drain line something is preventing the water from flowing. I would also make sure that there is no heavy mineral buildup on the water panel pad this can cause water to leak out of the humidifier. Lastly check to make sure there is a orifice inside the supply water tubing leaving the solenoid, if not this causes the water to enter the humidifier too fast.
Jan 07, 2012 | Aprilaire 550 Humidifier
The water from my bionaire humidifier keeps leaking well not leaking pouring out of the humidifier base. I checked and no there is no cracks on the water tank and it does not leak from the tank itself. But...
try to check the insulation of your drain pan because of your water came from your unit is cold that create moist on the tank when hit by hot air from sorrounding air apply insulation on the tank.
Mar 27, 2011 | Bionaire Humidifiers
Have aprilaire #760 ,changed water panel, and turned furnace on and water started pouring out of the bottom of furnce? lots of water---
Typically, we find that the most common reason that you start to see leaking from the humidifier is that the water panel is not changed frequently enough. We do recommend that the water panel be changed once every humidifying season. We find a majority of our customers do this maintenance typically at the start of the humidifying season.
Here are the things to check when troubleshooting a power humidifier, which is leaking:
1.Position Of Unit On Plenum
Is the unit level (let to right)?
Is it plumb (front to back)?
2.Feed Tube
Is the Feed Tube tightened or is there a crack in the tube?
3.Position Of Scale control insert-
Is the base of the scale control insert sitting firmly in the drain spud at the base of the housing?
Does the bottom of the scale control insert have a taper to it to direct water to the drain spud?
Is the Scale control insert positioned correctly? The scale control insert has a front and a back. The back of the water distribution tray has an indentation in it to allow for clearance of the nozzle, which is attached to the top of the base. If reversed, and forced into place, the water distribution tray will break off the nozzle attached to the water feed tube and potentially the housing, causing water to leak
4.Water Panel Assembly-
Are there aluminum strands hanging out of the scale control insert?
Is there a gap between the top of the water panel and the water distribution tray for air to go through?
Is the colored dot on the water panel, up?
Is there a consistent coating on the Water panel, or are there shinny spots or clumps of coating?
5.Water Entrainment (Water Blowing out of the Humidifier)-
Are there signs of entrainment? Mineral build-up on fan blade, shroud, inside of cover?
Is the static pressure in the plenum over .4w.c.? If so, entrainment and leaking could occur.
6.Missing Orifice
If there is no orifice in the unit, the water entering the system could flood the panel. To check
for proper water flow, a quart jar should fill at the drain line in about 2 ½ minutes for a red or blue orifice, 5 minutes for a white or yellow orifice.
7.Drain line-
Is the drain line plugged?
Does it have a good downward slope?
Is it teed with any other drain lines?
If the above items do not resolve the existing leaking we would recommend contacting the customer service line at 800-334-6011 for further technical support.
Regards,
Tracey Hadju
Customer Service Specialist
Research Products Corporation
www.aprilaire.com
Oct 25, 2010 | Aprilaire 700 Humidifier
My 1042 Power Humidifier has water under the PVC pipe leading from the unit into the drain. Does that mean the unit itself is leaking water?
Hi, if the unit is leaking and it looks as though it is coming from the PVC pipe, more then likely its leaking at the unit its self where the pipe connects. Water will run down the pipe and drip down line. Dry it off and put your hand around where the PVC pipe screws into unit. Unless the pipe is cracked, this is where the leak is. If the fitting is a male or female threaded PVC fitting and a piece of PVC pipe that goes to the drain, you can repair this very easy. Just cut the pipe near the fitting with a hacksaw. Unscrew the fitting that goes to unit. Go to a hardware store like Home Depot, take the old fitting with you and buy a replacement. Buy a coupling, a small can of clear PVC glue and a small can or tube of pipe dope to put on the fitting threads. Screw the fitting in first and make sure it has pipe dope on it, get it tight with pliers. Take the pipe and coupling and glue it on the pipe. Put glue on the other end and slide it in the fitting that was where it was leaking before. Hold it in place for a few seconds. Once you put the glue on, be ready to put it together as it drys super fast and you cant take it apart once it sets. Very easy to repair and the parts cost pennys. Keep me posted. You can do this and will learn about plumbing! Good Luck.
Shastalaker7
Jan 24, 2010 | General Filters 1042-LH Humidifier
Honeywell HE260 leaks somewhere
Neither, even if the solenoid or humidistat stick, it should always drain properly. Is the unit mounted on the cold air return duct or the supply plenum? If it's mounted on the supply plenum, the water panel might be getting blown forward and spilling the water. High efficient furnaces also can leak water on the floor if its drain is restricted. If hum. is mounted on return duct make sure drain is clear by blowing through it. On Honeywell hum's I've seen the rubber hose from the solenoid valve to the distributor tray leak too, check the rubber 1/4" hose.
Dec 28, 2009 | Honeywell HE260A1010 Whole House...
Leaking out of the bottom of the unit on to the
Check the drain to make sure its clear and that the tray is properly aligned with the drain of the housing. Also check how much water is being fed to the unit sometimes you have too much and it is blown off the pad. Just a personal opinion I have never installed a humidifier on the front of a furnace for this reason. I hope this helps
Tinner
Sunsetmech
Dec 10, 2009 | Aprilaire Humidifiers
General Humidifier Model 1042-L leaking water
Check the bottom of drain tube (tube connected to the bottom center of the bottom tray). Does water freely flow out the tube when the humdifier water feed is on?
If there is no flow from the tube and water is leaking from the bottom tray when the humidifier water feed is on then the tube or bottom tray is clogged with hardwater minerals or other material.
If the unit has not been used in a while it's possible a spider has take up residence by spinning a web in the bottom tray or tube.
The last poissible reason is the tray is cracked. You may order the tray from multiple sources on the web. Simply shop for model and price.
Jan 16, 2009 | General Filters 1042-LH Humidifier
I have a General Humidifier Model 1042-L that is leaking water out of the bottom pan. How do I fix this?
Check the bottom of the drain tube (tube connected to the bottom center of the bottom tray). Does water freely flow out the bottom end of the tube when the humdifier water feed is on?
If there is no flow from the tube and water is leaking from the bottom tray when the humidifier water feed is on then the tube or bottom tray may be clogged with hardwater minerals or other material.
Also, if the humidifier has not been used in a long while it's possible a spider has take up residence by spinning a web in the bottom tray or tube. Tell the spider to find a new home.
Another possible reason is the tray is cracked. You may order the tray from multiple sources on the web. Simply shop for model and price.
And lastly, is the unit installed properly, parallel to the ground? If tilted, water flowing through the unit may catch the sides and flow out where it should not.
Water Leak
there is a nozzel at the end a black tube at the top of the hummidifier that has come off or the tube is cracked
Dec 24, 2008 | Aprilaire 550 Humidifier
Honeywell HE220A1019 Whole House Humidifier Humidifier Logo
741 people viewed this question
Top Honeywell Humidifiers Experts
Dennis
Simon Benzekri
Level 1 Expert
Bill Long
Are you a Honeywell Humidifier Expert? Answer questions, earn points and help others
