Question about Zenith B25A10Z 25" TV
Turns itself off
Initially happened with an especially bright image.
became more frequent especially when cold.
the picture skews in from the sides (variable depending upon the brightness of the signal image) - then shuts off.
have had to watch snow for 10 mins to "warm it up", then could switch to a signaled channel.
now will not stay on.
What do you think?
  • 1 more comment
  • Anonymous Nov 24, 2008
    Power button no longer works. Many starts and stops of pushing the button before I might get it to turn on. IF I can get tv on, after a variable amount of time, the screen goes wonky and then shuts off. RC will not turn the TV on either
  • ostringer Dec 02, 2008
    tvjoseph,
    Your advice is a bit vague. Please clarify.
    Thanks.
  • ostringer Dec 04, 2008
    Thanks tvjoseph - I'll try what you suggest.
  • 121 Answers
Screen control. pict to bright. normal to shut down. when this happens. ****** screen control.
Posted on Dec 01, 2008
  • joe wertenberg Dec 03, 2008
    sympton you describe. pulling in on sides and shutting down is caused by excessive crt drive,  find screen control
     back apron ****** same or re adj r g b guns. could have circuit problem causing over driving of crt. if so would require tech services.
Mitsubishi TV 65 inch rear projection. WS 65809 I went thru the convergence ic chip replacement years ago. Love the TV. My problem now is that the brightness goes from full bright to full dim then...
The old Mitsubishi units had a super capacitor in the logic circuit instead of a backup battery. This capacitor became leaky over time, causing the problem you describe among others. Number one symptom is set has audio and dark or black picture when powered up. As the super cap charges to full voltage, picture comes and goes.
Nov 27, 2014 | Televison & Video
TV no sound, picture bleached and skewed
model. serial numbers would be helpful.
Apr 19, 2014 | Televison & Video
My phone turns itself off, what's the problem?
Perhaps you try this question in the category Phones or android devices?
This question became between camera flashes, you know the things that give a bright light for a short time, when a picture is made.
Nov 13, 2013 | Samsung Galaxy S4 Zoom Android Camera...
Dell LCD Monitor Pictures, Dark Colors Course, Fuzzy, Pixelly
You might find a BACKLIGHT FLUORESCENT BULB on eBay.
Jul 04, 2009 | Dell E173FP 17" LCD Monitor
Screen does not show images
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open).
To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see the following for further info and a simple fix that may help:
http://camerarepair.blogspot.com/2009/05/simple-fix-for-stuck-shutter.html
Jun 27, 2009 | Canon Powershot SD450 / IXUS 55 Digital...
Bright white light
I have had the same problem with my F-700
After calling Fujifilm Custom support here in Spain, I've noticed that camera series had a common failure at CCD SENSOR, NOT THE SCREEN.
IF THE PROBLEM IS CCD (IMAGE SENSOR) FUJIFILM WILL REPAIR IT FOR FREE!!!!
I AM NOT KIDDING. I'RECEIVED A MAIL FROM FUJI SPAIN ABOUT THAT
ALSO CHECKED THAT AT FUJIFILM USA THEY REPAIR IT FOR FREE
I guess the problem is CCD (at least in mine) because:
1- Started with
intermitent colour distorsions (dissapearing from time to time)
2- The problem became more frequent as time passed by
3- THE IMAGE IS PERFECT WHEN I PLAY PICTURES FROM THE MEMORY CARD
GOOD LUCK !
Fernando
Nov 05, 2008 | Fuji FinePix F700 Digital Camera
Too bright pictures
Try doing a test of the same image using different "modes" and compare the results - it may just be that you've got the wrong setting.
Jun 03, 2008 | Samsung Digimax D53 Digital Camera
Blue color spread over the pictures
This sounds classic to a thermo problem where a part(s) are becoming thermo sensitive with aga and use. When the set is cold and then warmed up, the defective part(s) is changing characteristics.
Some components became thermo sensitive that are driving the display. Or an embeded component in the display itself became thermo sensitive. It is very possible that the fault is on the board that does the X - Y addressing or on the backplane electronics of the display screen itself.
Using the set with defective components is a bad idea. If the part(s) fail completely and go shorted or opened, other more costly damage can be done.
The service rep for the manufacture of your set is equiped and trained to be able to troubleshoot and service your set.
You will have to take the set in to have it serviced.
Jerry G.
Apr 17, 2008 | Vizio GV46L 46 in. LCD Television
Snowy Picture, Toshiba 42HP84 plasma tv
Similar problem with my Toshiba. I was told it was the power supply and that it would cost about $900 to replace parts and labor
Nov 21, 2007 | Toshiba 42HP84 42 in. Plasma HDTV
Samsung DLP HLR5668W has mostly dark picture + grinding noise
Pix looks like a light pipe issue, inside the Light Engine. as far as the shutting down, could be a bad fan causing the grinding and when stopps the DMD turns the set off.
Jul 08, 2007 | Samsung HL-R5668W 56" HDTV
Zenith B25A10Z 25" TV Logo
110 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
