Question about Sony KP61XBR200 TV
Error with red color
Our Sony KP61XBR200's red color isn't working right anymore. It looks sort of like the 3d comics where you have to wear the special 3d glasses. When doing the auto focus for the tv, it comes up saying: Error E10R Trying to find out how to repair this ourself since it would cost around $200 to have someone drive out, another $200 or so to have them look at it, then whatever the replacement parts would cost.
  • Cory Krumlauf Dec 27, 2006
    More info:
    The red convergence is not functioning, and no adjustment can be made via service mode. I replaced both convergence IC's (part number STK392-020), and still have the exact same issue. The E10R error code description is "sensor output level low", and indicates sensor number "0", which is the top center sensor. I've swapped the sensor out with another, and still get same error code, so I'm not sure how valid this error is. Looking for ideas.
    Scholar:
  • 119 Answers
I've never had to fix this problem before, but give this a try, it might work. remove the front bottom panel of the tv, their should be 2 to 4 screws then the panel should come off. it might need a little prying & sometimes they use velcro to hold it in place along with the screws. now remove the small plastic or wodden panel, another 2 to 4 screws. now in the upper right side you will find the screen/focus block ( 6 controls). i think the top 3 are screen & the bottom 3 are focus. you will need to adjust the screen control., use a flashlight to read it. now the center is the green tube, i do not remember if the red is to the right of left. the screen control is like the master brightness, which sould help with the low sensor output. if you turn up the red too high you will get small red lines on dark picture/or in a dark room. good luck.
Posted on Dec 27, 2006
What color cloak should I wear for a superman's costume? Red or blue?
He usually wears red, but it depends on the comic or movie he was in. Sometimes he has it blue also
Jul 04, 2013 | Clothing Accessories
Unsuccessful autofocus followed by E15R code--red curves out at corners
this is a problem of the crrt tube inside your tv..... there wil be major problem this tube,..... only because of this, the pictures r noyt clear....
http://www.devicemanuals.com/guide/Television/Sony/Sony-TV-Projection-KP61XBR200-User-Guide-TXpRNE9UZz.html
dwnld the user manual frm here and change the crt tube
Jun 07, 2008 | Sony KP61XBR200 TV
There is an arcing bow across the screen and image, text doubling in red and green, images look like an old 3D comic print.
Please do us a favor and rate this solution after reading.
Projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Here are more details and solutions for both. Repair kits with instructions are also avail from www.TvRepairKits.com
Common Problem #1) Convergence has gone out
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems.
69189a5.pngSOLUTION #1
For more more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Common Problem #2) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
69189a5.pngSOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Feb 06, 2011 | Sony KP-46WT510 46" Rear Projection HDTV
The picture is wavy with the image looking like 3D when you aren't wearing 3d glasses.
Projection TV sets are known to have two common problems. The first problem that is common to these sets is convergence failure. When this happens the TV will usually look 3D, Wavy/Distorted, etc. It may also shutdown and blink an error code.
The second common problem with Projection TV sets is dull video, halos around objects, white looking video, or red overpowers the screen. This is commonly caused by the fluid in the lens being clouded over.
You can find more details and solutions here on Fixya at the following link below. Or click HERE
3d884ac.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Oct 28, 2010 | Sony KP-51HW40 51" Rear Projection...
My TV is red and green in 3D--what needs to be
Below are two of the most common problems encountered with projection TV sets.
Problem #1 - CONVERGENCE PROBLEM
Convergence problems are very common on all Projection TV sets including Sony, Samsung, JVC, Philip Magnavox, Panasonic, Akai, Pioneer, Hitachi, Zenith, and others. You can get a Sony convergenece repair kit from the link below.
  • Screen looks 3D
  • TV shuts off after powering on - TV may also make a chirping noise.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a solution
93a1209.pngCONVERGENCE SOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses.
This is a a fairly easy DIY job if you know what you are doing. If you have never done this before we would advise calling a shop or if you want to do it yourself get a complete kit with instructions and support from TvRepairKits.com
Their kits include a step by step instruction guide, original OEM Sanyo2_bing.gif STK chips, convergence resistors, pico fuses, thermal paste, email/phone support, etc.
Problem #2 CRT Fluid is Cloudy
Projection tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around video.
Pic of a set that needs the fluid changed. Notice how dull the colors are and how white the screen looks. The screen may also look red, orange, dull, etc.
BEFORE
Set after fluid change. Notice how bright the colors are now. Everthing looks crisp and sharp again.
AFTER
93a1209.pngSolution #2 - CRT FLUID FIX
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from TvRepairKits.com . It includes replacement coolant,step by step instructions, support, etc.
Feb 07, 2010 | Sony KP-46WT500 46" Rear Projection...
My Sony Projection TV middle of the screen curves down on top and curves up on bottom. Picture looks dubble like 3D, screen looks like concaved. Left side of the screen color is light green and blue, right...
This is a very common failure on Projection sets. Its called a convergence problem.
You may have one or more of the following symptoms.
Screen looks 3D
No Audio / No Video - Makes Chirping Sounds
You can see some examples and find a fix here...
Sep 26, 2009 | Sony KP-51WS510 51" Rear Projection...
Toshiba 43A10 projection television
http://www.digitalhome.ca/forum/showpost.php?p=564268&postcount=220
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Dec 04, 2007 | Toshiba 43A10 43" Rear Projection...
Sony KP61XBR200 - More info...
If a output IC is bad it will usually open a pico fuse. These IC's do fail a lot. These fuses are near the IC's.
Dec 13, 2006 | Sony KP61XBR200 TV
Sony KP61XBR200 TV Logo
114 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
