Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
Whirlpool Ultimate Care II keeps taking water.
My whirpool ultimate care II machine keeps taking in water and it keeps draining out without starting a cycle or even filling up the washing machine.
  • trulyblues Nov 26, 2008
    I have the same problem - works just fine on the actual wash cycle, but on rinse the machine fills part way and then just drains as fast as it fills.
  • auntkayc Nov 29, 2008
    washer keeps filling and water drains out at beginning of wash cycle
    President:
  • Whirlpool Master
  • 2,651 Answers
Ck your drain nose/drainline, chances are you have along hose, perhaps even draining along the floor behind hte unit, into a "closed" drain system. in which cawee the wwater is syphoning out during the rinse cycle, youlll needt o raise the drain hose to above 48" and have it drain into a stand pipe to prevent siphoning effect
Posted on Nov 20, 2008
Stops in the middle of wash cycle
Hi!
If the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
Please do rate this solution as FixYa and revert for further assistance.
Thanks
Rylee
May 29, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool Washer - Imperial Series Quiet Wash 2
your washers drain hose is too far down the drain pipe which is causing a siphoning action pull the washers drain hose out pipe some you should be able to hear water dropping into the pipe the reason it only happens in the rinse cycle is because the water from wash is being drained and before the water vacuum is broken the rinse water comes in causing it to keep draining
Dec 30, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Washing machine will not cycle
I have a Whirlpool Ultimate Care II. My washing machine would not cycle once it filled with water. I purchased a lid switch from partselect.com. The installation took five minutes. This corrected the problem. I hope this helps.
Nov 05, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Washing machine stops working
I search in the internet on regards to the problems with the Whirpool Ultimate Care II and found out that many others had the same problem as I did. Some solved this issue replacing the switch, so i decided to do the same.
I opened the machine and saw that the switch was not working properly, it was not doing any contact, so whenever I open or closed the lid, nothing was happening. I did a house fixing, with some duck tape i was able to make the system work, and now the machine is washing everything again.
Nov 03, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirpool Ultimate care II
your lid switch is broken you need to replace it look on the lid of the unit you will see a plastic pin that pushes down on thwe switch when it closes there are 2 screws holding the switch in place but you will have to remove the cabniet to change the switch
Jan 21, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Ultimate II is refusing to go into agtation/wash cycle
It sounds like a bad timer unit, and possibly a lid switch.
As far as the water overfilling, that may be an unrelated problem, such as the water level switch... but most likely the timer.
I have the same model, and it wouldn't drain.. and it would try to spin when full of water... an interesting sight to see!
Jan 07, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
The load won't start.
It sounds like you have a bad lid switch.It's an easy fix.You can get the part at your local appliance supply.
Dec 09, 2007 | Whirlpool Ultimate Care II LSQ9549L Top...
Remove top of machine, you will find lid switch or 'sensor' there. I would say its faulty ,and needs to be replaced.g,luck.rate me
Dec 06, 2007 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
253 people viewed this question
Dan Webster
Dan Webster
Sal De GO PATS
