Question about Brother MFC-9420CN All-In-One Laser Printer
Line in the scaned pages
When I scan / copy multiple pages from the top it will have a line right in the middle of all the pages but if I scan/ copy from the tray doesn't have line!!!!
  • 78 Answers
You have a dirty scanner lense. when you lift the top cover, as though you were going to do a copy from the platten glass, you will see there is a smaller glass to the left hand side of the scanner. look very hard at this glass and you will see there is a dirty mark on the lense. clean the cglass thoroughly with some quality window cleaner and you will find you line will go away.
Posted on Dec 10, 2008
A black line on the scaned page
If light going around the paper, and if upper white paper don't cover it, this part will be black. Try to cover with some part of white paper around. If you have black line in the middle of scan, you have hardware problem with scanner (or old buggy driver). Try to update scanner driver.
Aug 24, 2011 | Office Equipment & Supplies
The receiver of my FAXes says that there is a black line down the middle of each page. The FAX is a good copy-clear, etc.... but this line has to go. What can I do? Thanks, Donna
Dear Donna,
When a document is scanned from the top portion of the printer, it will loop around and output from underneath. The scanning glass on the far left side will have some debris on it. Lift the the lid exposing the glass portion, inspect for "stuff" on the glass, perhaps pen or white out. You can use a mild soap and lightly dampened cloth to remove any debris.
Good Luck,
Jan 14, 2011 | HP OfficeJet 6210 All-In-One InkJet...
My HP 7210 puts a line down the middle of the page, but there isn't anything on the glass. I think it is on the light, how can I check it?
I am assuming that you are talking about scaning or copying somethign when you mention glass. The line can be from memory or a driver, Try setting the scan quality down to see if it goes away.
Nov 03, 2009 | HP Officejet 7210 All-In-One InkJet...
Black line is present when copying document; not
This sounds as if you have some ink/contamination on the small scaning glass that sits to either the left or right of the main glass on the copier.(Depending on the model/make)As your original is scanned over this thin piece of glass the scanning device will see any spots and this will result in a black line down the page.Please clean the glass with a soft rag.
Oct 12, 2009 | Office Equipment & Supplies
Scanning/copying problem (Lexmark 6500 series x6575)
please just you scan the object to resuleasion in and dp is 600 to 12oo select and you scane object and aply print is dark is ok.
Sep 17, 2009 | Lexmark X5150 All-In-One InkJet Printer
I have a line in the middle of the scaned images and I don't know how to get to the 'mirror'
The area where you place your document to scan does open up. They do on all fax machines. The whole control panel will open either from the top or bottom of the control panel. you should just have to pull up on it. After you get it open you should see the scanner. I it may be under a long roller? The is probably ink on the scanner glass that needs to be cleaned.
Sorry I couldnt be more specific to your model number but this should get you in the right direction.
May 16, 2009 | Lexmark F4270 Plain Paper Inkjet Fax
Black line down the middle of scanned documents.
Try leaving the cover open and run a test scan, once with a fresh sheet as the item to be scanned and then a second time without anything on the table.  You may see what is blocking the light source or possibly a defect in it.
Scanning is done left-right, left-right across the width of the page and the vertical stripe indicates that the blockage is present during each scanned line.
In servicing copiers and multifunction machines, I have found a number of curious contaminents, one of the most annoying was a moth, still alive, that would randomly sit on the lamp, causing some pages to come out OK, others not.
If your copies and printouts are coming out fine, then only the scanner can be at fault.
Jan 13, 2009 | HP Photosmart 2575 All-In-One InkJet...
Line down middle of page
Click on the link to get step by step guide
If it even marks on the print state
Please don't forget to vote!
Nov 12, 2008 | HP Officejet 5610 All-In-One InkJet...
Scanning multiple pages
Hi there
This could be one of many problems, i will tell you a few solutions that i know of, check the lid and see if there is a bulge in the middle of the lid (is the lid uneven in anyway?), if it is, i would suggest that you return your printer to the place where you bought it. This could also be a setting on your printer, the setting could be to scan a book or to scan two smaller pages.
If you would like a manual on how to sort this out (if the problem persists), please e-mail me at
Kind regards and good luck
Dustin Ellse
Jun 26, 2008 | Samsung SCX-4725FN All-In-One Laser...
Brother MFC-9420CN All-In-One Laser Printer Logo
127 people viewed this question
James Cagle
James Cagle
Jim Keysor
