I cannot connect my xbox 360 to my liksys router
What you have to do is go on to one of the menus on the Xbox and find your connection on there. First you have to link the wireless network adapter to the back of your 360 (around £45) and then its done!
Posted on Jan 04, 2009
I cant set up xbox live
Connect to the Internet The first step is to connect your Xbox 360 console to your Internet connection. Here's how:
  1. Plug one end of a network cable into a port on your router or gateway. You might need a long network cable, depending upon on the location of your router or modem.
    Note If you do not have a router, you can plug the network cable directly into your modem.
  2. Plug the other end of the network cable into the back of your console.
Verify your setup Your setup should look similar to one of the following:
Router connection
connect_router_300px.gif Your Xbox 360 console and computer are both connected to a router. The router is connected to a modem, which is connected to a cable wall jack.
Modem connection
modemsetup_300px.gif Your Xbox 360 console is connected to a modem, which is connected to a cable wall jack.
Jul 27, 2011 | Microsoft Xbox 360 Console
Tip
Setup your Xbox to a Wireless Network
Xbox game consoles can be connected <span style="text-decoration: underline;"></span> to a router<a href="http://compnetworking.about.com/cs/routers/g/bldef_router.htm"></a> for wireless access to the Internet and Xbox Live. Follow these instructions to set up the Xbox or Xbox 360 connections to a wireless home network.<br /><br /> <ol> <li>Connect the appropriate wireless network adapter<a href="http://compnetworking.about.com/od/hardwarenetworkgear/g/bldef_adapter.htm"></a> to the console. On the Xbox, a Wi-Fi adapter that connects to the Ethernet sometimes also called a wireless network bridge must be used. Alternatively, the Xbox 360 is also designed to work with certain Wi-Fi <i>game adapters</i> that connect to a USB port.<br /><br /></li> <li>Turn on the console and navigate to the wireless settings screen. On the Xbox, the menu path is "Settings -&gt; Network Settings -&gt; Advanced -&gt; Wireless -&gt; Settings" On the Xbox 360, the menu path is "System -&gt; Network Settings -&gt; Edit Settings."<br /><br /></li> <li>Set the SSID (network name) on the Xbox to match that of the wireless router. If your wireless router has enabled SSID broadcast, the SSID name should appear pre-selected on the Xbox display. Otherwise, select the "Specify Unlisted Network" option and enter the SSID there.<br /><br /></li> <li>Specify "Infrastructure" as the Network Mode. (Infrastructure is the mode used by wireless routers.)<br /><br /></li> <li>Set the Security Type to match that of the wireless router. If your router uses WPA encryption and the type of adapter connected to the Xbox does not support WPA, you will need to change your router settings to use WEP encryption instead. Note that the standard MS Xbox Adapter supports WPA while the standard Microsoft Xbox Wireless Adapter (MN-740) only supports WEP.<br /></li> <li>Save your settings and verify the network is functional.<br /><br /> On the Xbox, the Wireless Status screen displays whether a connection has successfully been made with the wireless router, and the Connect Status screen displays whether a connection has successfully been made through the Internet to Xbox Live.<br /><br /> On the Xbox 360, use the "Test Xbox Live Connection" option instead.</li></ol> Tips: <ol> <li>Even when your wireless connection between the Xbox and the router is working perfectly, you may still experience difficulty connecting to Xbox Live. These issues can be caused by the quality of your Internet connection or the firewall and Network Address Translation (NAT) settings of your wireless router. Additional troubleshooting may be required in these areas to achieve reliable Xbox Live connections.</li></ol><span style="font-weight: bold;">Troubleshooting</span><br /><br /> The built-in diagnostic of the Xbox can help with any falure.Navigate to the <i>System</i> area of the Xbox Dashboard, select the <i>Network Settings</i> menu option, then select <i>Test Xbox Live Connection</i> to run the test at any time. If the Xbox 360 built-in network diagnostic fails with the following message: <br /> <ul><i>Technical configuration error. Please contact Xbox Customer Support.</i></ul> This indicates a network issue requiring further investigation. The Xbox 360 network diagnostic contains the following tests run in the order listed below. Steps for troubleshooting Xbox 360 connectivity issues depend on which test reports the failure. <br />If you have an original Xbox 360 console, you need to attach an Xbox 360 Wireless Networking Adapter before you can connect your console to a wireless network.<br /> <b>Note</b> You can use an Xbox 360 Wireless Networking Adapter with the Xbox 360 S console. If your wireless router is not near your console, you may get a better wireless signal by using a wireless networking adapter. When you connect an Xbox 360 Wireless Networking Adapter to an Xbox 360 S console, the console will automatically use the wireless adapter instead of the built-in Wi-Fi.<br /> If you have an original Xbox 360 console, you need to attach an Xbox 360 Wireless Networking Adapter before you can connect your console to a wireless network.<br /><br /> Step 1: Attach an Xbox 360 Wireless Networking Adapter to the back of your Xbox 360 console.<br /> Step 2: If a network cable is plugged into the back of your console, unplug it. Step 3: Check the light on the Xbox 360 Wireless Networking Adapter.<br /> If you're using the black adapter with two antennas:<br /> <ul> <li><b>No light:</b> The adapter is not receiving power. Unplug the USB connector, and plug it in again. Still no light? Try plugging the adapter into a USB port on the front of the console.</li> <li><b>Green:</b> The adapter is connected to a wireless router, gateway, or access point.</li> <li><b>Flashing green:</b> The adapter is attempting to connect to a wireless network.</li> <li><b>Red:</b> The adapter is not recognized. Try plugging the adapter into a USB port on the front of your console. </li> <li><b>Flashing red:</b> There is a problem. The adapter might be experiencing a hardware failure.</li></ul><br /> Configure your wireless settings Go to <b>My Xbox,</b> and then select <b>System Settings</b>. <br />Select <b>Network Settings.<br /></b>Select <b>Configure Network</b>.<br /> <ol> <li>On the <b>Basic Settings</b> tab, select <b>Wireless Mode</b>. <br /> <b>Note</b> If Wireless Mode is still not available, there might be a problem with your hardware. <br /></li> <li>Select <b>Scan for Networks</b>. </li> <li>Select your wireless network name. <br /><br />If your wireless network is not listed, try either of the following:<br /> <ol> <li>Try improve the router signal by moving the router position.If you are not broadcasting your wireless network name, select <b>Specify Unlisted Network</b>, and enter your wireless network name and security type. </li></ol></li><br /> <li>Enter your wireless network password, and then select <b>Done</b>.</li> <li>Press the <b>B</b> button on your controller, and then select <b>Test Xbox LIVE Connection</b>. If you successfully connect to Xbox LIVE, you'll see this screen:Choose <b>Yes</b> when you are prompted to update the console software. <br /></li></ol>
on Jan 18, 2011 | Video Game Consoles & Games
Im programing my x box 360 it needs me to program the wpa net work to get this new x bow to work. im new at this expain things very clear , thanks
Follow these instructions to set up the Xbox or Xbox 360 connections to a wireless home network. These instructions assume the wireless router is already installed with a working Internet connection. If after following these instructions you are unable to network your Xbox with the wireless router, see - Connecting Xbox to Wireless Networks - Why Things Go Wrong
Here's How:
  1. Connect the appropriate wireless network adapter to the console. On the Xbox, a Wi-Fi adapter that connects to the Ethernet port (sometimes also called a wireless network bridge) must be used. Alternatively, the Xbox 360 is also designed to work with certain Wi-Fi game adapters that connect to a USB port.
  2. Turn on the console and navigate to the wireless settings screen. On the Xbox, the menu path is "Settings -> Network Settings -> Advanced -> Wireless -> Settings" On the Xbox 360, the menu path is "System -> Network Settings -> Edit Settings."
  3. Set the SSID (network name) on the Xbox to match that of the wireless router. If your wireless router has enabled SSID broadcast, the SSID name should appear pre-selected on the Xbox display. Otherwise, select the "Specify Unlisted Network" option and enter the SSID there.
  4. Specify "Infrastructure" as the Network Mode. (Infrastructure is the mode used by wireless routers.)
  5. Set the Security Type to match that of the wireless router. If your router uses WPA encryption and the type of adapter connected to the Xbox does not support WPA, you will need to change your router settings to use WEP encryption instead. Note that the standard Microsoft Xbox 360 Wireless Network Adapter supports WPA while the standard Microsoft Xbox Wireless Adapter (MN-740) only supports WEP.
  6. Save your settings and verify the network is functional.
Tips:
  1. Even when your wireless connection between the Xbox and the router is working perfectly, you may still experience difficulty connecting to Xbox Live. These issues can be caused by the quality of your Internet connection or the firewall and Network Address Translation (NAT) settings of your wireless router. Additional troubleshooting may be required in these areas to achieve reliable Xbox Live connections.
Feb 27, 2011 | Computers & Internet
Cant connect Xbox 360 to this wireless router
Turn on the console and navigate to the wireless settings screen. On the Xbox, the menu path is "Settings -> Network Settings -> Advanced -> Wireless -> Settings" On the Xbox 360, the menu path is "System -> Network Settings -> Edit Settings." Set the SSID (network name) on the Xbox to match that of the wireless router. If your wireless router has enabled SSID broadcast, the SSID name should appear pre-selected on the Xbox display. Otherwise, select the "Specify Unlisted Network" option and enter the SSID there. Specify "Infrastructure" as the Network Mode. (Infrastructure is the mode used by wireless routers.) Set the Security Type to match that of the wireless router. If your router uses WPA encryption and the type of adapter connected to the Xbox does not support WPA, you will need to change your router settings to use WEP encryption instead. Note that the standard Microsoft Xbox 360 Wireless Network Adapter supports WPA while the standard Microsoft Xbox Wireless Adapter (MN-740) only supports WEP. Save your settings and verify the network is functional. On the Xbox, the Wireless Status screen displays whether a connection has successfully been made with the wireless router, and the Connect Status screen displays whether a connection has successfully been made through the Internet to Xbox Live. On the Xbox 360, use the "Test Xbox Live Connection" option instead.
If you need more help post back! Thumbs and testimonial are welcome!
Jan 15, 2011 | Linksys WRT160N Wireless Router
I have a Cayman 3347w wireless router and I am trying to use one of the wired slots to connect my xbox 360 to the internet. the xbox will not connect. is this router xbox compatable?
Please try the following steps below;
To make a router connection to Xbox LIVE:
  1. Before you connect any cables, turn off your router, modem, PC, and Xbox 360 console. (Unplug your modem from its power source to turn it off.)
  2. Connect one end of an Ethernet cable to the Ethernet port on your modem and the other end to the Ethernet input port on the back of your router.
  3. With another Ethernet cable, connect one end to one of the router's Ethernet output ports. Connect the other end to your PC's Ethernet port.
  4. With the third Ethernet cable, connect one end to another of the router's Ethernet output ports. Connect the other end to the Ethernet port on the back of the Xbox 360 console.
  5. Turn on your modem, then your router, then your PC.
  6. Make sure your PC can access the Internet. If not, you may need to configure the router for Internet access. For help configuring the router using your PC, check the instructions that came with the router.
  7. Turn on your Xbox 360 console and sign in with your profile.
  8. If this is the first time you've turned on your Xbox 360 console, see Create Your Gamer Profile to get started with both the Xbox 360 system and Xbox LIVE play.
If you're unable to connect to Xbox LIVE, you can try to diagnose the problem right on your console. Go to My Xbox and open System Settings, then select Network Settings (setup XBOX using Automatic Configuration DHCP), Test Xbox LIVE Connection.
Hope this helps!
Mar 28, 2010 | Netopia Cayman 3347W-Ent Wireless Router
My wireless adapter for my xbox 360 stays on red light
You can try fixing this using Xbox360 repair guide that covers almost all xbox 360 problems, you can get a copy from here
http://xbox360repairguide.com
Jul 10, 2009 | Microsoft Wireless Network Adapter Xbox...
Xbox 360 netgear router
that happens alot when one or more device (for instance, the xbox 360 and a cpu) are trying to use the same ip address make sure you have the xbox 360 and all other devices (cpu's/printers) that are connected to the router set to aquire ip address automatically
Feb 05, 2009 | NetGear WIRELESS-G WGR614 802.11G WIRELESS...
Xbox 360 live on wireless router
In theory you should be able to "share" your internet connection. I use a Linksys WRT54GS wireless router and I have a Linksys Game adapter on my son's 360. He has not complained about lag or slow server times unless other intensive bandwidth is being used.
Nov 09, 2008 | Microsoft Xbox 360 Console
Router
You need to know how to change the MTU packet size on the XBox?
Jul 10, 2008 | Compaq (CISCO7204VXR-DC-RF) Router
Why isnt my xbox connecting? i plugged the cble into the rouder and then put the other cable into the xbox and its not letting me connect.
To make a router connection to Xbox Live:
  7. Turn on your Xbox 360 console with no disc in the disc tray.
  8. If you've already used your Xbox 360 system for offline play, the Xbox Dashboard will open to the Xbox Live area. Select the Xbox Live banner. When you see the Xbox Live Marketplace you'll know you're connected to Xbox Live.
Jul 02, 2008 | Video Game Consoles & Games
Computers & Internet Logo
David Payne
David Payne
