Question about Casio Watches
Casio watch recovery indicator flashes - Casio Watches
My Casio Pathfinder 3070 (B) suddenly went blank and all I see now is a tiny "C" flashing. I put my watch under a light source for several hours but still the same. Can someone help me?
The flashing C indicates the battery level is at 4. (1 is the ideal, and 5 is dead) The manual says that it could take 46 hours under fluorescent light to charge to the next fully functional level. 1-5 hours in varying degrees of sunlight.
My watch was blank and flashing C this morning, but has come back with no help from me, except for random button pushing.
Mar 02, 2013 | Watches
My new Casio atomic watch indicates no radio signal but displays a tiny E at the base of the radio signal strength indicator.
Hi,you need to look at the user manual..
just in case ,if you need soft version of the user manual pls visit the URL below..
Hope this helps! Take care and please Remember to rate/vote and give me
4 Thumbs Up for me to continue for Helping out the Community :)
Thanks
CASIO Watch User Manual Archives
http://world.casio.com/wat/download/en/manual/
Use this page to download a copy of CASIO watch manuals in PDF format.
To download a PDF file, enter the four-digit (or three-digit) module number marked on the back cover of your watch.
Jun 03, 2011 | Casio G-Shock MTG900DA-8V Wrist Watch
How do I adjust the length of the bracelet (watch band) for a Casio EF106D-2AV bracelet watch?
  • Select a clean, flat work surface where you can perform your watch band adjustment. Put down a piece of felt to protect the face of your Casio. Turn on a lamp near your workspace to better illuminate the watch components with which you will be working.
  • Lay your Casio face down on the protective felt. Look for the small arrows on the back of some of the watch links; these arrows indicate the removable watch links and the direction their pins should be removed.
  • Locate the pin hole above the arrow on the removable watch links. Insert the tip of a watch pin removal tool, or push pin, into the pin hole. Apply pressure to the link pin, in the direction indicated by the arrow, to free the pin and remove the link. A pair of needle-nose watch or jewelry pliers can be used to help pull out stubborn link pins. Remove as many links as necessary for your watch to fit perfectly.
  • Reserve the links and link pins that you remove from your Casio Edifice watch. Store the removed watch components in a small, clear, plastic zipper bag. These components can be used when repairing or expanding your Casio watch band.
  • WARNING:Casio recommends that customers have their watch bands sized by an authorized Casio watch dealer. Sizing the band of your Casio Edifice yourself may void the manufacturer's warranty on your watch. Contact Casio customer support for more warranty information.
  • Aug 21, 2010 | Casio Edifice EF106D2AV Wrist Watch
    I have a g shock riseman g-9200, what does the letters PS mean(just to left of hour in time keeping mode, also is there any indication that i am getting a atomic time keeping signal?.......Thanks.....syd
    PS means the watch is in power save mode if there is an indicator under the PS on your watch. this means the watch will go into a sleep mode when it is left in the dark for extended periods. change this setting by holding the top left button until a city code starts flashing, then press the bottom left button until "PSON" is flashing , you can switch between "PSON" and "PSOF" in this way by pressing the bottom right button. i, and casio recommend leaving the watch in the powersave mode though to help extend battery life. I got all this info from my G Shock manual.
    Jun 12, 2010 | Casio GShock Riseman AltiTherm GW92001...
    I lost my owner's manual for my Casio SGW-100B. When I try to use the compass it asks me to please calibrate
    Above link no longer valid. Here's the current one:
    http://ftp.casio.co.jp/pub/world_manual/wat/en/qw3157.pdf
    Also, the key was inputting the correct #, in this case 3157 - NOT the 100B - at the following page:
    I had almost given up when I looked again at the back of my watch and found the other number.
    Sep 16, 2009 | Casio SGW100B-3V Watch
    Cannot set the analog time on the Casio 2747.
    In timekeeping mode press bottom left button 6x to enter setting mode.
    Then hold down top left button until digital time flashes, which indicates your in analog time setting mode. press bottom right button to set the time.
    If you hold down bottom right, it will set time at a faster speed.
    Hope this helps
    May 25, 2009 | Casio AW80-7AV Wrist Watch
    Waveceptor watch WVA 105H. Reception indicator had disappeared from the display this morning, so I attempted a manual receive. After about 5 minutes the flashing display was replaced with...
    I have a wave ceptor casio watch 2734 model WVA 105H, however I've lost the manaul. I have a problem, the digital time reads correctly but analogue time is incorrect. How do I move the hands to the correct time? If you could find a solution it would be most appreciated.
    Aug 15, 2008 | Casio Watches
    Casio Triple Sensor Pathfinder PRG60-1AV
    Like anon129 I had the same problem. Those "outdoor" functions need more battery power than just telling the time and the stopwatch do. When the rechargeable lithium battery gets old and tired - which they apparently sometimes do for no very good reason - it can't provide enough power when required to, so it goes into recovery mode. It's very annoying but if your battery level indicator is already showing H the only solution is to replace the battery.
    My second battery seems to be lasting better, but I'm not leaving it charging in the sun for ages this time, as I think it overheats it when the battery is full. I'm also not using the outdoor features as much, and the light hardly at all.
    Apr 13, 2007 | Casio Triple Sensor Pathfinder PRG60-1AV...
    Casio 2654 mtg 901
    sounds like it might not be getting enough sunlight. If it has the solar cell in it tape it to the inside of your window for a weekend. If it doesn't charge up the battery enough to make that bar quit flashing then you may need to have the battery changed.
    Jan 02, 2007 | Casio G-Shock MTG900DA-8V Wrist Watch
    Watches Logo
    106 people viewed this question
    Top Casio Watches Experts
    Kazim ERGUNEY
    Kazim ERGUNEY
    Ansel Alberto
    Ansel Alberto
    Are you a Casio Watch Expert? Answer questions, earn points and help others
