Question about Microwave Ovens
Kenmore Microwave Model 721.67601790 lights don't work!
The two light bulbs on the bottom side (underneath) of my 900 watt microwave will not work. The bulbs are fine.....but they will not light up. The fan works, the light inside works, the turntable works,everything about the microwave works EXCEPT these two bulbs. This is crazy.
  • Microwave Ovens Master
  • 9,098 Answers
This seems to be happening to this model a lot!
We see (and repair) this a lot. The problem is on the control panel, whichwe regularly repair nationwide by mail for $39.95 postpaid in about a week.
Atour site, we have a video available showing how to remove a typicalover the range control panel assembly in under 5 minutes.
This light failure often occurs when a bulb goes out and the filamentshorts, or when the bulbs are removed or installed without firstunplugging the oven from the power line. Either can cause such afailure on the controller.
This can often also affect the exhaust fan operation, too. The lights and fan can be inoperable or stuck on too.
Details of our service and critical safety information and disassembly information is at our site, and our link is at our listing here on FixYa.
Feel free to contact me directly (and please remind me of your model number) for more information & help.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Posted on Nov 21, 2008
FGMV205K cover removal
Good Afternoon Friend,
I understand that you want to know how to remove the cover on your Frigidaire microwave, model# FGMV205K. There are two different covers that you are able to remove for access to two different light bulbs.
If you are trying to change the Microwave Oven Light for inside your microwave:
    1)To replace light bulb, first disconnect power to your microwave oven at the circuit breaker panel or by unplugging it.
    2)Remove the louver by removing the three Hood Louver Screws.
    3)Push in the upper tabs and pull the louver away from your appliance.
    4)Remove the light bulb and replace with a new 20 watt light bulb. DO NOT USE BULB LARGER THAN 20 WATTS.
    5)Close the Oven Light Cover by carefully pushing into place. Push the louver back into place (engaging both the bottom and top tabs) and change to hood Louver Screws.
    If you are trying to change the light bulbs underneath your Microwave:
      1)To replace light bulbs, first disconnect power to your microwave oven at the circuit breaker panel or by unplugging it.
      2)To open Light Cover, remove the screw on the light cover.
      3)Replace the light bulbs with new 20 watt light bulbs. DO NOT USE BULBS LARGER THAN 20 WATTS.
      4)Close the Light Cover and secure with screw removed at step 2.
      If further troubleshooting is needed, I ask that you please let me know the error codes displayed on your appliance. Hope this is helpful.
      -Best Regards-
      WP
Jun 07, 2014 | Frigidaire Gallery FGMV205K 2.0 cu. ft....
How do you change the light bulb under the microwave?
put the bulb of microwave down . and then install a new bulb on it .before do these .you should turn off the switch .
home light bulbs
May 02, 2012 | GE JVM1650 1000 Watts Microwave Oven
I have replaced the bulbs underneath the microwave, but the lights are still not working.
HELLO.
This is the solution to the problem as detailed below.
instruments needed
* Appliance bulb
* Screwdriver.
Unplug the microwave. Remove the lamp cover by unscrewing the mounting screws. Turn the bulb to tightly screw it in. Then plug the microwave back in to test the light. If the bulb still will not illuminate, it is likely broken or defective. Replace it with another 20 to 40 watt appliance bulb.
Sep 24, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
Replace interior light on a model 8921
To replace the interior light, remove all screws holding case together. There are screws on the back at the top, down the sides, and possibly underneath. Once all screws are removed, slide the outer case off and you will then be able to access the bulb.
Jun 16, 2010 | Montgomery Ward MW8997BEC MW8997WEC 900...
This is actually a common problem which we repair on a regular basis.
We regularly repair these control units for customers nationwide by mail for $39.95 postpaid in about a week with a one-year guarantee.
At our site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
William E. Miller
prototech@usa.net
Nov 19, 2008 | Microwave Ovens
Underneath Light funtion stopped working on Kenmore 62642 model
We see this a lot. The problem is on the control panel, which we regularly repair nationwide for $39.95 postpaid.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
Details of our service and critical safety information and disassembly information is at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
We're happy to help and we appreciate your thoughtful rating of our answer.
Feb 17, 2008 | Kenmore 62642 / 62644 / 62649 Microwave...
Replacing interior light bulb in m/n 63694
On many recent models, it is necessary to remove the mircowave from the wall, then remove the cover to change the cavity bulb. They suggest that only an authoirzed servider replace them, in order to avoid liability. You can enter your actual, full model number (63694 is not enough) and get helpful exploded view drawings and order parts at http://www3.sears.com (the three is correct). Do not handle the bulbs with bare skin, it will shorten their lives. Use a clean dry cloth or gloves.
Apr 29, 2007 | Kenmore 63692 / 63694 / 63699 900 Watts...
Microwave Ovens Logo
446 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Marvin
Marvin
Are you a Microwave Oven Expert? Answer questions, earn points and help others
