Dell poweredge 1650 and norton ghost
I am trying to use norton ghost and a bootable floppy disk to image a hard drive on a dell poweredge 1650 server. The operating system that has been installed on the machine is windows xp (for now). When I boot from the floppy disk I get the error message that the NDIS enviroment is not configured correctly as the boot disk is seeing the two network cards (intel pro 1000 cards) on the pe 1650 but cannot decide which card to connect to. I get the advice to add SLOT= either device 0x0022 pr 0x0024. I tried it in a few places in the protocol.ini, but nothing works. What I am doing wrong and how to I fix this problem?
Okay, hate to answer my own question. Where I got confused was with the protocol.ini file that is used in Norton Ghost on a boot disk to load the network information, including the network protocol to be used (netbeui in this case) and what network card was to be used. Thus the last part of the protocol.ini file is where I needed to add the missing information. I needed to add the slot = required value to identify what one of two network cards in the dell PowerEdge 1650 was to be used to connect to the ghost server (in this case, the two cards were idenified by a number such as 0x0110 and 0x0120). The strange thing is that I also noticed that there is a third network port on the back of the server, but I am not sure if it is active or not, but nothing came of as of yet. But I am now happy to report that I can connect to the ghost server to image the machine I need to image.
Edward
Posted on Nov 20, 2008
Where is poweredge 1800 display led connector
http://www.dell.com/support/troubleshooting/us/en/19/KCS/KcsArticles/Print?he Embedded System Management (ESM) log - also called System Event Log (SEL) or hardware log - reports potential hardware problems in Dell PowerEdge servers. Sometimes, simply turning off the server and disconnecting it from the electrical outlet will remove the error message. Wait approximately 10 seconds, and then reconnect the power cable and restart the server.
Other times, you will need to clear the ESM log to remove the error message. For instance, error code SEL FULLindicates that you will need to clear the ESM log. (You will lose the server's event history.) There are different ways to clear the ESM log.
To use DSET to Clear the ESM Log
  1. Download and open the DSET utility.
  2. Click the plus (+) next to System, and then click the plus (+) next to Logs.
  3. Click ESM to highlight it.
  4. Click Clear ESM Log located in the upper-right corner of the page.
To use OpenManage Server Administrator (OMSA) to clear the ESM log
  1. Start OpenManage Server Administrator (OMSA).
  2. Log in to OMSA by entering your username and password, and then press Enter.
  3. Click the Logs tab, and then click Hardware.
  4. Click Clear Log located next to Options.
To use Dell IT Assistant to clear the ESM log
  1. Start IT Assistant.
  2. From the middle System Tree bar, select your server by clicking it.
  3. Click the Logs tab, and then click Clear Log in the upper-right corner of the page.
Find your Dell PowerEdge server model in the chart below for other ways to clear the ESM log:
PowerEdge server model How to clear the ESM log 2300, 2400, 2450, 2500, 2500SC, 2550, 4300, 4350, 4400, 6300, 6350, 6400, 6450
Use the Log2Txt.exe utility to clear the ESM log:
  1. Start your server to the Log2Txt utility.
  2. When you see the ESM Log main menu appear, press 2 on your keyboard to select Clear ESM log.
  3. When the ESM Log main menu reappears, press 5on your keyboard to exit the utility.
1650, 1850, 1800, 2600, 2650, 2800, 4600, 6600, 6650, 7150, 6800, 6850, R900
Use the DRAC or ERA to clear the ESM log:
  1. Type the IP address of the Remote Access Controller (RAC) in the web browser address bar, and then press Enter.
  2. Log in to the RAC.
  4. Click Clear Logs located in the upper-right corner of the page.
1850, 2800, 2850, 6800, 6850
Use the program BMCCFG.exe to clear the ESM logs:
  1. Download and extract the Dell OpenManage Deployment Toolkit here.
  2. Go to x:\Dell\Toolkit\Tools, where x is your primary hard disk drive.
  3. Copy the file BMCCFG.exe to a bootable floppy disk.
  4. Start the server from the bootable floppy disk.
  5. At the command prompt, type bmcc - clearsel, and then press Enter.
    The message "Clearing SEL" will display while the log clears.
1950, 2900, 2950, DP500, DP600, NF500, NF600
Use the BMC/BIOS to clear the ESM log:
  1. To open the BMC menu, press the Control + Ekeys during POST.
  2. From the list, select System Event Log, and then press Enter.
  3. Select Clear System Event Log, and then pressEnter.
=8590&doclang=EN
Jun 09, 2014 | Dell PowerEdge 1800 Server
Install of windows 2003 server
1) is it an old server, perhaps the DVD drive needs cleaning 2) Perhaps the Windows DVD needs cleaning, check for scratches. 3) is the Windows DVD an original? if it is a copy or download, maybe the DVD is not bootable or the image is damaged 4) is the installed Drive definitely a DVD, the drives in that server were optional so are you sure it is not just a CD drive that is installed.
How about downloading or creating a bootable USB image and try booting from that. Look online, Win2003 Server USB images may be available for download
Aug 22, 2013 | Dell PowerEdge R300 Server
Dell PowerEdge R710 Installation error I have the same problem while installing Windows Server 2003 installation process reach to the step asking press F8, when pressing F8 it says no Hard Drive were...
ok you will need to get the windows 2003 drivers for your raid controller and put them on a floppy disk. when you first boot off the cd you will see a prompt to press f6 if you need to install any additional drivers. insert the floppy disk and select which driver you wish to load.
you should be able to see the hard drives now to partition/format.
Mar 09, 2011 | Dell PowerEdge R710 Server (D263K)
Poweredge 1800 server
Hey,
I looked over the spesifications for the poweredge 1800 servers, go ahead, it will work perfectly but there is one problem in the windows XP setup, you will need to insert / load SCSI or SATA drivers for the hard drive With a floppy disk, or if you don't have a floppy drive your going to need to create a custom windows xp setup cd and add the drivers into it so it can start the SCSI or SATA hard drive and finish the install. without the drivers it might not find the hard drive.
Aside from that I don't see any other problems. You should be able to get the drivers, and everything ese from dell site
http://support.dell.com/support/downloads/
Actually I looked over the dell downloads, I see only windows 2000 on the list with windows server 2003, and 2008 and linux distributions.
This could be a 2nd problem, drivers might not be avaialble, or work with xp, but we might be able to get it to work.
So two problems, SCSI or SATA drivers in windows xp / windows 2000 setup
2nd problem is in windows xp drivers, you could try windows 2003's drivers and 2000's and see if they work, if not, then we would have to look for drivers ourselfs from the internet.
So xp might cause headache but we might get it working, windows 2000 seems to be supported perfectly.
Let me know how the project goes
Thanks,
Ekse
Jun 03, 2009 | Dell PowerEdge 1800 Server
Setup can not find any hard disk while installing win 2003
During setup you must specify any raid drivers that are required. Have the raid controller driver on floppy and insert when prompted.
Mar 31, 2009 | Dell POWEREDGE 1950 Server
I need a recovery disk for my Vista OS preinstalled on Acer Aspire T180. Can I create it by myself? (Recently my system crashed and I had to a tecnichian for using his recovery disk)
You can use a hard drive imaging program such as Norton Ghost to create a recovery DVD(s). Norton Ghost is available as part of System Works or as a stand alone program. Power Quest's Drive Image is also an alternative, however it is too old to be compatible with Vista - you could do a Drive Image outside of Windows - booting off the Floppy.
Sep 09, 2008 | Acer Computers & Internet
Ibm thinkpad T40 Hard Drive change out
After fdisk and format you need to ensure that operative system is installed into yor hard drive. Using ghost you restore the image disk by booting from ghost image CD if you made a bootable image disk. Ensure Bios is set up to boot from CD.
If you used Norton Ghost ensure you captured the image of full bootable original hard disk drive for same computer. If it does not boot after restoring ghosted image, than the image it is probably not complete. If hard disk image is not good, easiest thing to do is using Windows install CD to installl again operative system, then you eventually restore ghost image.
Aug 17, 2008 | IBM ThinkPad T40 2373 Notebook
Ghost dell 2500
Just run Ghost in windows and follow the wizard to create a bootable floppy for your hardware
Feb 20, 2008 | Dell PowerEdge 2500 Server
Disk copy
yup... norton ghost should be able to copy the failing disk onto a new disk, Disk -> disk copy
Sep 28, 2007 | Dell PowerEdge 1650 Server
Computers & Internet Logo
406 people viewed this question
Alun Cox
David Payne
David Payne
