Question about HP Photosmart C4280 Aio Printer
Usb cable not connected to hp
The hp keeps saying usb cable not connected
    Master:
    Sergeant:
  • 449 Answers
Hi!!!
try to replaced the usb cord
Posted on Nov 19, 2008
How do i connect to a printer
Hi Jenelle
I think we will need more information to be sure to fix this problem, like the model of the printer and are you trying to connect to it with USB cable or through network (with LAN or with wifi).
in most cases anyway make sure the wires are connected correctly (USB) and download the below link to identify and install your printer if it's not installed correctly.
press the identify now button after connecting it with USB.
HP Support Software Drivers
May 23, 2016 | IBM ThinkPad Computers & Internet
HP LaserJet 2430 Printer Will Not Print since USB Power Surge Error
INSUFFICIENT POWER - USB PORT
If you get an error message "Insufficient power to operate USB device" when you plug a USB device into the computer's USB port or the un-powered USB hub that is attached to the computer's USB port, then this device is drawing excessive current that the USB port cannot supply. The maximum output from an USB port is 500mA. In case such as this, you need to purchased a powered USB hub and connect this hub into the computer's USB port and then connect the USB device into this powered USB hub.
Feb 19, 2013 | HP LaserJet Office Equipment & Supplies
Replacing HP 7580 all in one scanner fax with HP 7590 all in one scanner fax. I did not have install CD for 7590 so downloaded drivers from HP site. Error message keeps saying that does not recognize...
first Step - Try another USB Cable.. If this does not solve, try the steps below.
Power off the Printer
Disconnect the USB Cable from Printer to PC ( from PC )
Disconnect the power cord of printer frmo wall outlet
Power off the PC
Disconnect the Power cable from back of PC and from wall outlet as well
wait for 10 minutes
Connect the PC power cables to PC and Turn on the PC
When you login to your Desktop, Turn on the Printer
Connect the Cable,
It should get recognised.
Regards,
Ron
Feb 22, 2011 | HP Computers & Internet
Hp 5500 keeps saying cannot communicate with computer?
You can try to:
- Turn the printer off then turn it back on - Unplug and replug both ends of the usb cable connecting your printer and computer - Turn off the firewall - Reinstall the printer driver and software - if it still wont work, try a different usb cable
Dec 31, 2010 | HP Photosmart C6180 All-In-One InkJet...
It says HP psc1315 printer is offline and won't print. how do i fix? wont change back to online also one document at front of queue wont delete
Reset your printer. To do this, turn off the printer using the power button, remove the cartridges, unplug the power and the usb cables. Press the power button for several times. Connect the power cable and also the wall jack, power on (don't connect the usb cable). While the printer boots up, keep pressing power button several times. Leave it for few minutes and again switch off. Now connect the usb cable as well and insert the cartridges. Shutdown the computer. Power on the printer and also the computer (Note when you power off/on, use only the power button). This will fix your problem. If possible, please reinstall the drivers for your printer before you restart it with the pc. Good luck. Thanks for using FixYa.
Jun 02, 2010 | HP PSC 1315 All-In-One InkJet Printer
HP DESK TOP 840C PRINTER CONNECTION
They do make adater cables for such problems. Here is just one such example: Parallel to USB Cable
Make sure you get the correct 25 pin cable. They have this type also:
Parallel to USB Cable 2
You can search the web for more companies. Google parallel to usb printer cable.
After saying all that and checking your printer info, I see that the 840c has both a parallel and a USB cable port. See page 21 of the manual: HP 840c Manual
If you go that route, you will need a standard USB cable. The shorter the better, but no longer than a 6' cable. Make sure you follow the iinstallation instructions for the USB setup in the manual.
Thanks for using Fixya.
Apr 14, 2010 | HP DeskJet 840c InkJet Printer
My HP Photosmart C4480 was working fine last time I used it, but now the mini-display isn't lighting up, the power light is blinking on and off, and my laptop says the printer is "offline". What do I do?
HP photosmart C4480 power on but screen blank and nothing flashing - keeps asking to connect usb cable, this has been checked and new cable tried but still not working
Sep 22, 2009 | HP Photosmart C4480 All-In-One InkJet...
My hp photosmart C4280 keeps saying the USB cable is not hooked up to my mac. when it clearly is
It seems that the USB cable might have problem pls try to replacethe usb cable ...
Aug 11, 2009 | HP PhotoSmart C4280 Laser Printer
Printer keeps saying usb cable not connected
1)right click the my computer icon
2)click properties and then click hardware n go to device manager.
3)uninstall all usb ports and then scan for hardware changes
4)ur pc will detect your printer and ask for printer drivers
5)re load drivers and your pc will communicate with your printer
6)for reloding install the cd follow the instructions on the screen and click next
7)restart when the printer is loded.connect the wires and cords properly.
Nov 19, 2008 | HP Photosmart C4280 Aio Printer
HP Photosmart C4280 Aio Printer Logo
157 people viewed this question
Ben Johnson
